2.5 Head Gaskets
1 reply to this topic
#1 WannabeWrxOwner
WannabeWrxOwner
    New User
  • Pip
  • 2 posts
  • Seattle
Posted 26 March 2006 - 02:06 PM
Hey guy's, I'm replacing the headgaskets on my 98' GT. Do you guy's have any tips for me? Should I use sealant with the headgaskets? Or just use plain gaskets?
Any tips would be great.
Thanks
#2 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 26 March 2006 - 03:34 PM
NEVER NEVER NEVER use sealnt on a headgasket. This has been covered on previous posts. The decks of the Cylinder and Cylinder head haave to be completley clean. The Cyl Head surface has to be Flat (which requires a machine shop check as most people dont have the micrometers to check this) with no runout. The Headgasket deforms a bit to make the seal. You have combustion pressures of 15-18,000 psi and coolant pressure of ~14psi. Any dirt and the two of them will find a path to leak. You also have engine oil under pressure.
There is also a specific sequance to tightening the Cyl Heads bolt that you need to follow as the manual states.
nipper
