brighton98 Posted February 6, 2007 Share Posted February 6, 2007 I finally replaced the 98 Brighton propshaft with a new(used) one; no more slop in the u-joints. However, I'm still getting vibrations when accellerating, especially from 25-30 and 35-40mph. It smooths out in the cruise and once you let off the gas. BTW, no torque bind, if that matters. Maybe CVs or mounts?? Thanks. Quote Link to comment Share on other sites More sharing options...
Skip Posted February 6, 2007 Share Posted February 6, 2007 CVs will most likely make noise when turning sharply and accelerating, have you tried that? DOJs** on the other hand will exhibit the problem you are having. ** Double Offset Joint - other end of the half shaft - next to the transaxle. P.S. might be a kewl idea linking to your previous posts Quote Link to comment Share on other sites More sharing options...
nipper Posted February 6, 2007 Share Posted February 6, 2007 How about the drive shaft universals and carrier bearing? they are usually the source of untraceable vibrations nipper Quote Link to comment Share on other sites More sharing options...
brighton98 Posted February 7, 2007 Author Share Posted February 7, 2007 Propshaft=front-rear driveshaft U-joints & center bearing are smooth and tight; same symptoms as before so I'm assuming it's not the central driveshaft. Quote Link to comment Share on other sites More sharing options...
nipper Posted February 7, 2007 Share Posted February 7, 2007 Rotate your tires and see if it changes nipper Quote Link to comment Share on other sites More sharing options...
