Water running/Gurgeling sound from under dash!!
:confused: Is it normal to hear water, or whatever it is, running through the heater core? I hear it gurgeling when I am at idle. I assume it is doing it all the time but I just can't hear it over the engine and air noise. But is this normal? Do any of you experience this as well? --GoatBoy
My Car did the Same Thing When i Had an Airbubble in the coolant, park your car on a slight up hill and run it till its warm with the radiator cap off, squeeze the upper radiator hose and the air should work its way out, this is how i do it, maybe someone else around here has another way
