Still looking for the fuel-pump relay
4 replies to this topic
#1 jimbo747
jimbo747
    USMB Regular
  • PipPipPip
  • 103 posts
  • Chandler, AZ
Posted 14 December 2003 - 01:21 PM
Skip posted earlier that I can find them "above and to the drivers side of the steering col. You must remove the trim panel to see them. "
O.K. I need some help here. Are we talking inside the engine compartment, or inside the car? Which trim panel do I need to remove? Help, Please!
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 14 December 2003 - 01:35 PM
Inside the car. its the trim panel right above your knees when you are sitting in the drivers seat. the fuel pump relay and ignition relay are directly above the left side of the ECU.
#3 jimbo747
jimbo747
    USMB Regular
  • PipPipPip
  • 103 posts
  • Chandler, AZ
Posted 14 December 2003 - 02:05 PM
Thanks
#4 jimbo747
jimbo747
    USMB Regular
  • PipPipPip
  • 103 posts
  • Chandler, AZ
Posted 20 December 2003 - 03:42 PM
One bit of advice that would have been helpful is the fact that I needed to drop the ECU.
After all this work, turns out the relay was fine. Still have know idea what the problem is (was, since the Loyale is starting and running fine, now). :confused:
#5 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 20 December 2003 - 04:54 PM
Yes Jimbo good call, should have warned you,
some models you do have to drop the ECU (it's on U shaped open mounts so you can just loosen the three 12mm nuts)
Some models they are visable, sorry.
Hope it stays runnin'
