dave valiant Posted February 25, 2008 Share Posted February 25, 2008 My 87 gl wagons heater is stuck on panel no matter which setting I put it on. I do notice that I cant hear the vacuum sound I usually hear when switching from one setting to another so I am going to try tracking the vacuum lines. An interesting side note. The heat that is coming out of the panel is hotter than it has ever been in this car. Quote Link to comment Share on other sites More sharing options...
EvilDead Posted February 25, 2008 Share Posted February 25, 2008 My 87 gl wagons heater is stuck on panel no matter which setting I put it on. I do notice that I cant hear the vacuum sound I usually hear when switching from one setting to another so I am going to try tracking the vacuum lines. An interesting side note. The heat that is coming out of the panel is hotter than it has ever been in this car. Good heat in an older Subaru is a good thing. Is it possible some rodent has blocked up a passage at one point? Or something has gotten loose? Quote Link to comment Share on other sites More sharing options...
SuperchargedRS Posted February 25, 2008 Share Posted February 25, 2008 though I am new to subies I do believe that if a rodent died in a heat duct and had hot air blowing over it into your face, unless you were one pungent individual you would QUICKLY realize something got in there lol Quote Link to comment Share on other sites More sharing options...
Skip Posted February 25, 2008 Share Posted February 25, 2008 I do notice that I cant hear the vacuum sound I usually hear when switching from one setting to another so I am going to try tracking the vacuum lines. This being the case..vacuum is present. Might want to check the check valve in the vacuum storage container on the shelf behind the pass strut tower. (white plastic cylinder) If all is good... My bet is a cable acutator is loose. An interesting side note. The heat that is coming out of the panel is hotter than it has ever been in this car. Sounds like it's stuck in re-circulate mode also. Quote Link to comment Share on other sites More sharing options...
