timstiles Posted April 11, 2008 Share Posted April 11, 2008 Is there a trick to getting this cap off? I removed the bolts and the cap won't come off. About all I can do so far is get it to rotate by tapping on it with a long extension. Don't want to break anything so I bolted it back up and decided to ask here before continuing. Thanks, Tim 96 legacy 2.2 Quote Link to comment Share on other sites More sharing options...
EVOthis Posted April 11, 2008 Share Posted April 11, 2008 wow....i just got done doing this not 4 days ago on my 96 Legacy....yeah the o ring seals a little tough......i took a screw driver and stuck it behind the cap and gave it a few taps with a hammer and it started coming out.....be careful not to nick anything though...... Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 11, 2008 Share Posted April 11, 2008 just keeping tapping alternate sides like you said you did...basically turning it back and forth. should loosen up so you can do that turning by hand and then simultaneously pull out, and it will come. go easy, it's all aluminum back there. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted April 11, 2008 Share Posted April 11, 2008 I just kept twisting and wiggling it by hand it came out. If you pry, do it only a little evenly on each side at a time. It fits in there fairly snugly. Quote Link to comment Share on other sites More sharing options...
timstiles Posted April 12, 2008 Author Share Posted April 12, 2008 Thanks for the replies and pics. I can go at it now without worrying about breaking something. Even though I walked into the dealer with the correct part number below it turns out the guy gave me an oring with close to the same part number but ends in '6020'. I wondering if it will even fit. Same parts counter guy that gave me the wrong bulbs for the hvac unit during the same visit. Quote Link to comment Share on other sites More sharing options...
