Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Block heater/tank heater/radiator hose heater?
#1
Posted 20 December 2008 - 10:11 PM
#2
Posted 21 December 2008 - 12:36 AM
block heater
search
#3
Posted 21 December 2008 - 03:35 AM
Its also the easiest to install. Can be done, with a cold engine, in about 20 minutes.
#4
Posted 21 December 2008 - 09:39 AM
I personally prefer the In Line heaters with pumps. They circulate the warmed antifreeze thru the entire engine, and because of the radiational affect, it also warms the oil. And because of the coolant bypass system that all cars have, the coolant thru the whole engine, radiator, heater core, will be warmed to about 90 degrees. It also means less snow clearing in the hood area.
What particular model heater and where do you end up putting it, under the spare, in the heater hose?
#5
Posted 21 December 2008 - 07:01 PM
http://cgi.ebay.com/...p3286.m20.l1116
Yes it does go into the heater core lines. I do not like the ones that go into the main radiator hoses. Silt, and other things can form on the heater elements over time, and drasticly reduce the coolant flow. In the heater core lines, you will notice a slight diference in the amount of heat that comes out of the vents as the silt builds, but will not affect how the engine is cooled.
If memory serves me right, we bought 5 feet of heater core hose from a parts store, and took the old one out completely. Mounted the pump/warmer in front of the strut tower with a strap. Then used the new heater core hose to connect it all together.
This was on a 94 legacy, so there was no spare tire under the hood. Althou I imagine it could easily be mounted under the spare tire, using the spare tire carrier shelf as a mounting point.
#6
Posted 21 December 2008 - 09:13 PM
I have yet to find one with a pump
400W block heater works great
#7
Posted 21 December 2008 - 09:14 PM
#8
Posted 22 December 2008 - 12:25 AM
for ea71 and ea81 the plug is on the front of the block to the left of the crankshaft
for ea82 the plug is on the bottom of the block below the oil fill tube
use a 14mm bit to remove
the plug is 36mm thread
BTDT on ea71 ea81 ea82
#9
Posted 22 December 2008 - 12:42 AM
#10
Posted 22 December 2008 - 10:21 AM
it's not a freeze plug!!!!!
Ahhh....ok, I shall take a peek.
#11
Posted 22 December 2008 - 12:29 PM
#12
Posted 22 December 2008 - 12:54 PM
Make me an offer and I can pull it from my spare engine and send it to you . You will save a bunch over buying new. I can even submerge it in a bucket of water and make sure it is fully functional.
Mike
#13
Posted 22 December 2008 - 09:06 PM
Now....what to use to take the plug out. :/
#14
Posted 23 December 2008 - 12:51 AM
#15
Posted 23 December 2008 - 01:06 AM
Anyone make a tool for plug removal?
#16
Posted 23 December 2008 - 01:09 AM
Maker - ZeroStat
Part # 33080002
Was like 50 bucks, this is the warmer, with a circulation pump.
#17
Posted 23 December 2008 - 01:10 AM
It comes with clamps, some fittings, and a mounting bracket. It's 110v for cold nights.
Maker "Five Star MFG. Co. 'Kat's Heaters'" part number 12100
I'm in the same boat, it's -2 F outside, and I need it badly, but really really don't want to deal with installing it in the snow.
Oh, I'm a newbie to the bbs, hello to everybody.
Edited by Txakura, 23 December 2008 - 01:13 AM.
#18
Posted 23 December 2008 - 01:12 AM
Anyway we look at it, its going to be a sucky job. :/
#19
Posted 23 December 2008 - 01:13 AM
#20
Posted 23 December 2008 - 01:14 AM
cornwell recommended as it was the shortest due to limited access
Mac is a nice medium length bit
#21
Posted 23 December 2008 - 01:21 AM
#22
Posted 23 December 2008 - 01:33 AM
thanks subiemechanic85
so for an EA81 i just have to find a block heater with 36mm thread
YEAH:lol:now Hero can wake up
#23
Posted 23 December 2008 - 12:47 PM
if so i'm going to replace the thermostat at the same time
#24
Posted 23 December 2008 - 01:36 PM
ok be sure to use a t-stat with a juggle pin STANT SUPERSTAT works great
best way to drian block is to remove drain plug in head, 14mm socket
#25
Posted 15 January 2011 - 05:03 PM
I'm sorry to resurrect a 2 year old thread! But I need some clarification. The mounting port is 36mm threaded? I can't find any threaded engine block heaters for my 1994 Subaru Loyale, just this that supposedly fits: Kats 11405, however that is the rubber gasket style. Thanks for any feedback, I need to get this guy warm before my daily 5:00 am drives.
Also, I found this PDF that shows where to mount the heater. Is this correct?
Edited by elBradford, 15 January 2011 - 05:07 PM.
