Brat tail-light speed nut swap
5 replies to this topic
#1 DPDISXR4Ti
DPDISXR4Ti
    Eat, Live, Breath Subaru
  • 342 posts
  • New York
Posted 10 August 2009 - 03:10 PM
Not the most important topic in the world, but has anyone opened up the size of the square holes for the tail-light speed nuts, to the same size as used by the side access panels?
Reason I'm asking, my original plastic speed nuts for the tail-lights are mostly all trashed, and I've got a zillion spares from the side panels, as pulled from junkyard cars over the years. The speed-nuts as used on the side panels are a softer black plastic, that doesn't crack if you look at it wrong. It would be nice to have the same thing all the way around.
I've got a little pneumatic file I could use for the job. Anyone already been down this road?
#2 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 10 August 2009 - 03:26 PM
i don't know what you are talking about?
#3 DPDISXR4Ti
DPDISXR4Ti
  • 342 posts
  • New York
Posted 10 August 2009 - 03:29 PM
The little plastic things that pop into the body panels, and then the retainer screws screw into them. Two different sizes used. Want to use all the same size - the ones used on the access panels in the bed. Any better?
#4 backwoodsboy
backwoodsboy
    vintagesubaruparts
  • Gold Subscribers
  • 1,054 posts
  • upstate NY, in the woods
Posted 10 August 2009 - 03:52 PM
I have spent my share of time cursing out those little white plastic pop-nuts myself.
The ones for the tail lamps were never the issue on my brat. The ones that hold the grille/fascia on the FRONT of the brat were a PITA though.
The idea stopped dead in its tracks when (on a whim) I brought a sample piece to my local CarQuest.
THEY MATCHED IT! :banana:
Very best of luck.
#5 DPDISXR4Ti
DPDISXR4Ti
  • 342 posts
  • New York
Posted 24 August 2010 - 02:04 PM
So back to this question... Has anyone found a junkyard donor that is a match for the 7mm square plastic speed nuts, as used to retain the tail-light screws? I'm sure they're available over the counter, but where's the adventure in that!?:lol:
FWIW, the ones used for the side/inspection panels are 8mm. I've decided it's not worth opening up the tail-light ones to that size when I'm sure 7mm are available.
#6 Brat_Dog
Brat_Dog
    USMB Regular
  • PipPipPip
  • 32 posts
  • Blind in Texas
Posted 24 August 2010 - 04:56 PM
Yup, best bet would be to try to find the matching new part, they're really cheap.
The chrome bed trim has a special kind of plastic nut with an extension on it. in a pinch I have cut a roughly 2"x1" piece of aluminum sheet metal and bent it into an L shape. I Drilled the center of the short leg just big enough to start the screw, popped open the nearest access panel and used the long leg of the L for a handle to reach back and tighten the screw. Maybe the same could be done for your tail light. Just have to make sure not to over tighten.
Good luck!
