Everything posted by Havoc_66
I broke a wheel stud! How do I fix it?
Havoc_66 replied to Havoc_66's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, I've got the damn drum brakes on the rear. I really appreciate the advice! But looks like this is gonna be a pain.
Well, like the topic says, I broke a wheel stud. I don't want to pay les Schwab $250 to fix it, so I was hoping someone could give me some pointers. I think I have to take off the brakes and pound the old one out, but it's on the rear wheel so that means drum brakes. Do those need to come off? Any advice is welcome! Thanks!! OH! The car is a 94 Impreza in case it makes a difference.
Odd Question...
No that was great, thank you!!!
oil everywhere!!
If it's a head gasket your oil would look like chocolate milk, and so would your coolant. Also is there bluish white smoke coming out the tail pipe? Also a tell tale sign of blown head gasket. Any chance you might have over filled the oil and it came back out the dipstick? It happens a lot actually!
Odd Question...
Which way should the fan on the radiator spin? Pushing air out of the car, or pull it in?
Let's revisit the ignition wiring problem...
....wow. Um, weber it is! No, it's a 4 pole. It has start and acc. Along with batt and on and starter. So I guess 5 poles all together. It's got me confused.
Eh, then it can stay. California sucks.
Yeah, but those sensors get costly in the long run. I need it for now, but later?
Definately, I think that fan is our problem with the overheating issue. I didn't know the starter was staying on, You never had it on that long. My fault. But with the fan, I'm assuming it's 12v, we should find out for sure. I'd rather have it run constantly than not at all. We should investigate those "mystery wires" from the fan. I'll get a new sensor. Is there any way to get rid of the California emissions s**t?
Ok, we have a $10 shucks ignition. It works and turns the engine over, but the on and the start positions seem to be synonomous. The "idiot lights" do come on when we turn the key, but the car also turns over. There seems to be no accessory position. I have the opinion that if the car starts, then it works, but we have no acc option, meaning the car is on or it's not. There is no steering lock. Is there any way to fix this? Are we wiring it wrong, or are we gonna have to live with this for ten bucks?
Yep, here I is. Better question how do you fix the original factory ignition?
EA71 Hitachi carb running rich
Very good question, since it is my car (well eventually) I'd like to know too. Is it the blatant screw under the air cleaner that you can see without really having to remove it completely?
