Silentpal
Posts posted by Silentpal
I would have to agree on that!
i think it won't fit.. anyways, it would help to ask a trusted mechanic or the dealer if that carter carburetor would fit on a 1987 subaru gl. this way you'll have more info.. good luck
My friend just got his Acura high performance parts last week... He was pretty excited to do his upgrades... Maybe it has also parts for a 91 legacy wagon, I forgot though to ask him where he purchased it... Maybe you can just try what jaml said... Sorry if I was not much of help.. Goodluck!!!
I will rule out a possible weak battery since you said it is new. Problem like yours sound likely caused by a bad alternator, clogged fuel line, a dirty carb.
To add, when you had an engine rebuilt always make sure you replace the freeze plugs as well.
If your muffler is not welded use a chisel to cut muffler off of pipes. Do this by cutting the muffler inlet and outlet tubes on both sides. Once the inlet and outlet tubes are free, you can now remove the muffler.
Since most mufflers have an inlet and outlet end, make sure they are pointed in the right direction.
I believe it does weaken after sometime.. Not sure though if there's a set of alignment kits for that.
I recently got my cargo liner from a Napa store. you could check em out.
you can also look at ebay for parts... check also these Subaru parts its from carpartswholesale, their products are not that pricey..
much better if you changed the same thing whenever they goes for pair. better upshot from both headlights if you change them together. if you go for the new one and the other is old, well, they won't perform the same lighting either..
i got some parts at wholesale price from carpartswholesale, when we had to do a project for a friend. thought you might want to give it a try and you might find windshield for your car.
well just go to a reliable dealer that won't charge you with lots bucks for your windshield. good luck.
how much does the mudrat baja bumper cost, and about how much does it weigh
well, bumper costs really depends. with regards to weight i'm not sure..
it might be a exaust leak or the little hose going to your breather element isn't attatched properly.
I was just tol that I have a leak in my rad. Last month I had a new water pump put on. Has anyone ever put in any stop leak stuff in? The dealer said he can not find the leak but when he put it under presure it leaked out on the bottom. Money is tight and I am going to need to replace the RR axel, and the charcoal canister too. I'm looking at over 1000.00 and most of that is the rad. at 440.00 installed. Anybody have an opinion
checked the hoses? anyways, there are lots of stores where you can find radiator, just look for a reliable dealer that won't charge you with lots of $$$.
yeah, i'd rather replaced it.. there are lots of stores where to find these fender, just look for a reliable dealer so that you wont spend much $$$.
you can check partstrain.com or other parts stores online.. or ebay.. i'm sure you'll find one.
Symptoms of a clogged catalytic converter.....
Posted
if the engine is out of tune up; excess fuel entering exhaust; oil or anti-freeze entering exhaust; bad spark plugs or spark plug wires; bad 02 sensor.. are some of the possible causes why subaru catalytic converter fails.. so better check on those things..
