Everything posted by GlTurbo1987
87 gl no start....
Well we looked at it, and it isn't getting spark like we thought..... any thoughts? coil is new, cap/rotor are new, wires are relatively new, plugs aren't bad... other than the ignitor, could it be out of time? any other thoughts would be helpful
87 gl no start....
Right underneath? I did see it I think, I'll have to go out and check tomorrow to see if any wires are loose... I do have to say though the coil looked like the original one that came with the car!
87 gl no start....
Alternator is good.... It does seem to throw a code right when it fires up, i'll check tomorrow to see what it says... where is this igniter? In the disty?
87 gl no start....
Its an ea82t, ran fine before it sat for 2 days, then it wouldn't start. Changed the cap/rotor and coil, plugs and wires are relatively new, and it is still getting fuel. It wont stay running, it starts, RPMs jump to around 3k, then dies. Any suggestions? I'm trying to find out what to do next.... Thanks
wierd cold start issue
Fuel filter was just changed about 1500 miles ago, and it happened before that.... also, it doesn't matter if its under boost or not, and it doesn't throw any codes when it does it... Could the spark plugs be causing it?
first off its a EA82T... I'm getting a weird cold start issue, but only when its below about 40 degrees or so... It starts up fine, idles fine, but once I start driving and the temp gauge starts to rise, it will start bucking like it isn't getting enough fuel. It doesn't do it with the clutch disengaged, it only happens when the engine is loaded. It will go away after the engine warms up a bit more, and I don't have a problem after that. Any ideas? Could it be the clutch slipping when because it is cold? or maybe the IAC? I tried searching the forum to no avail. Thanks in advance........
Putting another on the road, a few quick Q's
those connectors are in the right place.... my 87 has them there too
Got a bunch done on my coupe
Nice coupe........ I got dibs on your passenger door if you make your own and decide to sell it!
Hi, I bought a 1986 XT GL-10!
in the words of borat, Very Nice!
Transmission noise question
they had a tsb long ago about noise through the gearshift... something about the cup the shift rod goes into...... i cant remember now, but i know that mine does it also
wats your mpg old soobs?
87 gl EA82T 2WD 5spd... dont know the mileage on the engine b/c it was a junkyard unit i got from subeman90 i usually get around 26-30 mpg with a mix of city and highway cruising at 65 mph... i did get around 34 on one tank though
shift up?
Yeah they are annoying most of the time.... i have a diesel jetta that tells me to upshift at idle, and also when im going 65mph in 5th gear... i think it thinks its funny....
How to Adjust Idle Speed
there is a little screw by the throttle body that adjusts the idle speed... i had to partially remove the top manifold to get to it, but it isnt a big job
Want a good laugh?
what about this one at nasioc? http://forums.nasioc.com/forums/showthread.php?t=1352211 really..........
Somebody save this RX!
its already in the craigslist forum, but i have to say if i wasnt in school and dead broke, that rx would be mine
Ea82t
im pretty sure the owner's manual in my gl says 87.... not 100%, but im pretty sure
check engine light.....
no upgrades.... and because money is tight right now, im running 87 w/ lucas fuel additive in it... i'll use some 93 next fill up and hopefully that helps too
thanks.... ill give it a try on sunday... i just hope it isnt hurting it... this is the 3rd engine in it
87 gl turbo, mpfi.... usually the idiot light flickers at idle, it stays on maybe 3 - 4 seconds and will flicker... it doesnt usually come on above 3k rpms... i got a code in u-check and i think it was 22, which would mean the knock sensor, but im not 100% sure, because the light wont stay on long enough most of the time... when it comes on, the idle jumps about 200-300 rpms... when it comes on higher in the revs, the car seems like its losing power.... any help would be greatly appriciated.... i need to figure out how to do the d-check.... thanks
Allied Armament Update 300 Hp Wagon
that hood scoop is wicked sick...... that is one mean machine:headbang:
swap upgrade help
I think it was a brat with an ej20 from a wrx... i saw it too a long time ago
Rat Smell from heater. Need Help.
that happened to my gl.... there were so many nests in there, because it sat in a field next to a horse stable... they also ate the air cleaner and had made a nice nest on top of the throttle body.... just ripped all the ducts out and washed them thoroughly.... it doesnt stink anymore...
DIY Boost Controller!!!
my friend has one on his cyclone... its a fast beast... hes pushin a bunch of boost too
Unique wheels found for 4x140 pattern?
well i'll be damned.... that page has everything!
I found a set on ebay Canada.... 8 Hours left http://cgi.ebay.ca/4-new-RW-Macho-wheels-14-X-6-4-on-114-3-Gold_W0QQitemZ110040109634QQihZ001QQcategoryZ43954QQrdZ1QQcmdZViewItem
