torxxx
Posts posted by torxxx
  1. calipers dragging can and will cause warped rotors. I've seen many warped rotors on EJ series cars.. And I've seen just as many on EA series cars. I drive mine for about 4 years (ignoring the slight wobble back and forth during braking) and then I end up changing them. But I buy the cheapest rotors napa has and I use the cheapest pads.
    Driving style is another major contributing factor to rotors warping. I drive VERY aggressively so I tend to use my breaks and engine braking more than most people do. Not to mention people who drive somewhere with long downhills seem to warp rotors more commonly.
    I refuse to have rotors turned. The ones for my car cost 21 bucks and having them turned is 35 bucks.. you do the math, but I think its cheaper to replace than repair :banana:
  2. If you dont know the history of it, you would have to replace bent valves and head gaskets and put it all together and take the chance of it being a major piston slap engine or not.
    If you can get the engine for a "core" like 50 bucks or something say do it. sometimes junkyards will sell them for just parts if its a bent valve engine. I've bought several EJ25D's for 50 bucks each because they had broken timing pulleys and the valves were trashed.
    Ur lookin at about 20 dollars a valve to have them replaced. plus a head set, head resurface, fluids. If you did the work yourself, I'd say 600 bucks should cover everything. If you pay a shop to do it, 1500-2000 dollars
  3. From what I was told from a Tech. at the dealer here in town, if it has the immobilizer system, there is nothing you can do to bypass it. (I know this guy personally, hes not just talking to a regular customer that came in the door at the dealership. he's taught me ways to bypass the older sec. systems in the past) If you dont have the chipped key, the car will not power up. theres no way around it.
    Maybe in the future an aftermarket company will make a conversion system to do away with this security junk, but for now its all tied into a security module which tells the ECM and ignition systems to power up.
  4. fixed! found the relay. I had to sit upsidedown in the drivers seat stick my head up by the pedal mount just to see the relay. Wish these manuals, all data, mitchell etc actually had the REAL locations of components. they all said it was bolted to the dash crossbar support above the fuse box.. LOL I checked about 20 04+ soobs today and none of them had a relay there.
    On the other hand, it could have been a lot worse. could have had the immobilizer system on it.. 600 dollar chipped key..
  5. the JDM will most likely not have a EGR pipe and yours will. So you will have to take out the second plug down on the drivers side head. Even though the JDM comes with an intake, they are not plug and play. You have to retain your intake/wiring etc for the engine to be proper.
    JDM wiring is different, they use different parts for some stuff because they are the non-detuned version of the cars we get. So a lot of times to detune them they will put a cheaper "non" performance part on the engine like a TPS.
  6. make sure you pull the oil pan off too and clean the pickup screen off. Also replace the timing belt and check all pulleys and tensioner. And my rule with JDM engines is just use the long block. Take off intake, alternator, power steering pump, ac pump. while you have it out, put new exhaust studs in (use red locktite.) Wouldnt hurt to slap new plugs and valve cover gaskets on it too while its out since the EJ25D is a sl0t to change the plugs and vc gaskets in the car.
    wow a 30 day warranty.... a bit sad. foreign engines in Lynwood has a year warranty but they are a bit more spendy.
    Ohter than that it is a EJ25D, it will bolt up to your outback. Make sure you use the engine mounts off your old engine. JDM engines tend to have different style mounts than North American Cars
    If you have any other questions about these engines shoot me a pm, I've become very very familiar with these over the last few years.. done over 500 and counting
  7. Ok, I went out again today and fiddled aroudn with the car some more. Corrosion is a major issue with this car. Since its 04+ I dont have any references, manuals or anything on this car. I do have my alldatapro acct, but its so vague that its not even really worth using.
    I spent 3 hours cleaning connectors/relays/fuses etc. I still cant find this security interupt relay that alldata says is there. I'm 90% sure thats what the problem is. the only power the car is getting is basically body electronics. Power locks work, Interior Lighting, Horn and thats it. basically what the security system uses. I pulled the ignition switch out of the column and tested it with a MM and a test light and no power anywhere on that circuit. I unplugged the bulkhead connector thats above the fusebox and all the terminals there looked good..
    Is there anyone in this forum that owns an 06 Soob thats had issues with the sec. system? If so post or pm me please. I need tog et this job taken care of asap
  8. 2nd what GD said. Also if you are really serious about rebuilding an EJ22 N/A you might want to start checking on availability of the parts. Some of the stuff may be Subaru factory parts only.
    The EA82, EJ18, and EJ22 were designed to be easy to work on, get 300k miles on them and then get thrown away. You will find that your bearing surfaces in the block are going to be scored up. There is no way around it with aluminum blocks. I took apart a 5 speed manual this week that had 75k miles on it and I couldnt reuse the case. the bearing surfaces were worn that bad that it was pointless to put back together.
    What me and GD are getting at, you tear into an engine, order up all these parts etc just to find out that a bearing surface is fubar'd and that its a 50/50 chance that it goes back together and runs for another 100k or it grenades in 5k miles because you disturbed the surface and put a new part in it.
    I understand what ur saying about making more junk to have laying around, but on the other hand you could always scrap out the engine and sell the aluminum to a scrap yard :grin:
  9. A naturally Aspirated 2.2L is not worth rebuilding. When you are all said and done rebuilding it shortblock up, you could have bought 3 or 4 used 2.2L's from the junkyard.
    theres a reason why not very many ppl rebuild the EJ22 and EA82's. There is a million of them around the world and they are dirt cheap
    And not to mention some of the questions you've asked about reusing gaskets and seals.... if you are going to half rump roast a rebuild, its not worth doing. if you are going to split the case, might as well do new pistons/rings/rods/main bearings/wristpins, have the cylinders re-honed. Go all out, or nothing at all
  10. temp cv axle boots = roll of duct tape. clean off both sides of the broken boot. start the duct tape on the small size of the boot (with the car jacked up ofc) and then have a friend put the car in first gear. spin on the duct tape til the boot is fixed.
    ran a rear axle like this all through mud season this year. changed it a few weeks ago. lol duct tape pwns
  11. on my 86 lifted wagon - over 500k miles. stopped keeping track 9 months ago when it hit 500
    second engine (156k miles on this engine)
    second transmission (trans had 270k miles on it when I put it in. that was over 100k miles ago)
    Only thing original on this car: top half of rear seat, head liner, rear doors and gate. Everything else is off of about 20 diff EA82 series cars.
  12. 699 for a timing belt job is a rip.
    its 2.8 hours book time to do the job and usually around 90-100 an hr labor rate. Its such a low mileage engine that the pulleys etc are prolly fine. if you arent hearing a grinding or whirring noise from the front of the engine, the pulleys are most likely fine.
    The entire test the tensioner thing is a load of crap. I've never done it, never had one fail (done 100's of the 96+ Ej22 and EJ25's). As long as its not leaking oil, and it takes around 2 to 3 minutes to compress it in a vice its fine. you dont wanna just crank the vice closed. it should be stiff and turn in easy on about 1/2 turn on the vice handle, then stiffen up. I usually do 1/2 turns at a time and wait 20 seconds or so and you'll feel it get easy to turn again.
    the recommended mileage for timing belts should ALWAYS stay at 60k miles. 75k-105k is taking a BIG risk on 2 to 3000 dollars worth of repair of the belt breaks just because someone said they last that long. I dont care if the repair manual says 75k miles or 100k miles. Thats under ideal conditions (I.E. 60F to 90F temperature outside, no oil or coolant ever touched the belts, pulley surfaces are 100% smooth)
    And for the seals, quick inspection is all thats needed. you will know if one is leaking. I'd be more worried about the water pump leaking at 88k miles vs seals leaking.
    and this is a SOHC 2.5 gen 2 engine. Very, very easy to do a t-belt on. drain remove radiator, remove ac pulley and ps/alt belt. remove crank pulley, remove covers, set engine with all timing belt notches at 12 oclock remove tensioner, collapse tensioner in vice, use allen wrench to hold tensioner plunger in place, resinstall, slap belt on, put back together.
  13. I talked to 3 dealers today adn tehy all said the same thing. Baja's didnt use the chipped key. The baja's were built with left over legacy stuff. It does have an interrupt relay that shuts down all power to the car when its tripped. I pulled out all the regular relays I could find today and swapped them around and still nothing. I was doing this outside at -20F for 4 hours. I talked to the owner and told him that if I was going to fix it, he HAD to have it towed to my shop or his shop so I could tear into it inside. too much plastic junk to break.
    I checked alldatapro.com for the location of the interrupt relay and they picture they have is horrible, and its not where they claim its supposed to be.
    By chance anyone have a FSM for the MY06?
  14. I say stay away from them. I have a 99 forrester EJ25 SOHC in the shop on an engine stand and I'm fixing a bunch of stuff that they broke when the pulled the engine out.
    My buddy paid 1800 for the engine and then shipping to alaska. so he paid like 1400 for the engine. not worth it considering all the work I have to do to it just to get it in the car.
  15. my boss's best friend has an 06 baja that he got for cheap due to flood damage. it wasn't bad at all we didnt have to do anything to the engine and tranny other than change fluids. water barely got the floorboards wet inside.
    long story short, 2 years later its starting to have security system problems. I'm pretty sure it has factory subaru security system in it. How do I go about disabling a security system like this? I know in the 95-98 outbacks you could just pull the security system module. Are the 2000-2004 the same way?
  16. I think Kristjan will tell you that life is not cheap there but the average wage is a lot better too. Better hone up your fishing skills bro, Its a major industry there.
    Glad to hear I'm not the last smoker in this world too. Although it feels like it sometimes. Can't even smoke in my own damn house anymore!:mad:
    well thats good that fishing is a major industry over there. I'm an alaskan commercial fisherman. did that basically since I could crawl. I seriously might get an airplane ticket and fly up there to check it out.
