hogweed
Everything posted by hogweed
i'm picking this up tomorrow and wanted some feedback on possible causes. PO states the car just shut off one day. no loud noises, overheating or anything it just turned off. he had it towed home and was able to start it when cold but it now runs very rough. he replaced the coil pack, and "a bunch of sensors" but it didn't clear it up so he bought another car. smoking a bit out the back but not terrible (oil smoke) and no pressure in the coolant bottle. any thoughts? thanks in advance G
i just read a write up of this and the fellow had to drill the heads off a bunch of them. when the cover was off i think he was able to grab the studs and turn them out. took awhile from what i remember. pretty detailed post of HG repair is here if it helps. http://www.subaruoutback.org/forums/88-head-gasket-issues/26887-h6-head-gasket-replacement-5.html
hello all. i will try to keep it brief. the problem started w/ blowing the fusible link and hard wiring a fix to get home. after that the car ran fine for a week and then failed to start when warm. i pulled some relays and plugged them back in and after 10 minutes the car started. this happend a couple more time over the nest two weeks. the last time after it started i had a funny brake pedal feeling coming to a stop, the abs light came on along with the trans fluid temp light and the cel. while trying to limp home every time i hit the brake the tach and speedo would drop down to zero (car stayed running), the warning lights were intermittant and the car did not shift properly. now the car won't start on aregualr basis. i replaced the ECU and it didn't help. any suggestions would be helpful. i think i read some post about a serious issue like this being a bad ground. is this possible? if so, which grounds are likely suspect? thank you all again. gregg
