Everything posted by mtnbob
ABS not working after working on front brakes???
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the advantage of not having any road salt used in the winter. No rust or corrosion. The sensors appeared to still have the step down ends. They were not rounded off. I haven't had the time to take it apart again will try this weekend.
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok ty will try tomorrow
I recently replaced my front brakes and front strut. I unhooked my front ABS sensors and put them back in during all this. Now my ABS light comes on when I start my 96 Outback and I no longer have ABS. I took them apart again and could see nothing wrong but still nothing. Any ideas?? Thanks, Robert
What extra parts do I need to replace struts and springs on my Outback??
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the input guys!!!!!
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Nipper:banana: yes I'm still alive, just haven't had the time or money to install my Outback lift kit yet:dead: I figured at least I could get started with my brand new struts and Scorpion springs that I have had sitting here looking at me for the last year . My current outback has about 150,000 miles on it and the struts and springs feel great, but I'm not sure what condition the tophats are in. Do I need four of them? or just the fronts?? My neighbor works at a local car dealership, and told me if I took the current struts off of the car, as a complete unit with the springs, he could take them to work and put the new struts and springs together for me. Is it that big of a deal, or should I just rent the spring compressor and do it myself?
I found a neighbor who will assemble my new springs and struts if I take them off of the car as a unit. What extra parts do I need other than the strut, spring, and the strut top with bearing, if I want to replace everything? Or is that not necessary?
Is it tough to swap out the bearing on a 2.5 P.S. pump?
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is the difference between a NGK 6202V bearing and a 6202-2RS bearing?
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAwesome Job TY!!!! Do you remember the model # of the bearing by any chance? Most of the rebuild kits I see on ebay are just the seals.
Frustrated New Outback 2000 Owner
mtnbob replied to elian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi too live in S.C. and I had a reasonable experience with the Subaru dealership in Greenville.
- What does a power steering pump sound like when it starts going bad?
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI still am having trouble pinpointing the noise, but the pump is leaking and when I put fluid in the resevour it is gone in a few minutes. Does that settle it?? Anything special I should know before I take it off? Should I get a new serpentine belt??- What does a power steering pump sound like when it starts going bad?
I'm starting to get a growling noise from the front of my engine. Engine is running good. A/C is running good. Is there anything that I can look for to narrow it down? The noise is not a squealing as much as a growling.- 1996 Legacy wagon/1997 Outback Same Lift Kit?
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe kit I purchased includes lifts for each strut, lift blocks for all attachment points between the transmission, engine and the body, and a steering extension. This along with taller, stiffer springs, and new struts, gives me the ability to put 29" Super Swampers on my car. Overall I'm guessing I'll end up with 4-5" of lift over a stock Outback, but I won't know until I install everything.:cool: Once my job situation gets settled, I'll get to work on it, hopefully. This is what I hope to end up with. Not sure if this one had the King Springs on it, or just the lift kit and Super Swampers.- 1996 Legacy wagon/1997 Outback Same Lift Kit?
mtnbob replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst you purchase a very hard to find, body lift kit, which I did a year ago. Then you get a very expensive to ship, set of King lift springs from Australia, which I also did. Then get a skid plate, which I did. Now I just need to find the time and money to install it:banghead: Maybe someday:(- Allied Armament's old buy thread, you all got your stuff yet?
sorry to hear that meat. I got everything I ordered from them. It took awhile but it made it.:cool:- Ok, Appointment has been made for my Outback Lift!!!!
Sorry I meant next Tuesday:eek: Hell they are still working on my VW:confused: It's gonna happen though, all the parts are here except the super swampers. Woooooooo Hoooooooooooo:burnout:- Ok, Appointment has been made for my Outback Lift!!!!
Now I better hope my 86 diesel VW Golf is out of the shop this week so I have something to drive, while by Outback is getting lifted!!!!!!- Ok, Appointment has been made for my Outback Lift!!!!
Well i'm hoping to get a little better ground clearance and a firmer ride for offroading. I have 2 sets of 15" Alloy rims, so i'll have 1 set of 225-235 70 15 road tires and one set of 29 x 8.5 x 15 Super Swampers:banana:- Ok, Appointment has been made for my Outback Lift!!!!
Next Tuesday my 96 Outback goes in for its lift!!! New KYB GR-2 struts, King Springs heavy duty springs, body lift kit from Allied Armament, Subaru skid plate, and new Super Swampers!!! Pics to follow!! Shop said no problem coming in every day to take pics and to watch if I want!!- 29x8.5x15 Super Swampers Question
29x8.5x15 Super Swampers will fit my soon to be lifted Outback(Body Lift and Scorpion Springs), since a few people on here have mentioned them, But will 29x10.5x15's fit? There are some used one's locally available, but it seems like there would be some serious rubbing issues. Any guesses?:cool:- What tires do I need for my Outback lift project???
The nice thing is that when I bought my 96 Outback, I got a set of 15" Subaru alloy rims with it. So I'm planning on keeping two seperate sets of tires. One for highway use, and one for fun!!!! BB's Bruce?? Your insane LOL. Does it work??- What tires do I need for my Outback lift project???
Cool i'm reading that 29" swampers will fit on my lifted Outback. Any suggestions on where to get them cheapest?- What tires do I need for my Outback lift project???
thanks lol Next!!!!- Legacy Lift Pics
mtnbob replied to scottiegfunk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes i guess they did, do those replace the strut mounts? I guess I just thought the attached to the strut mounts. so the strut is then hard mounted to the frame at the top? do that make it alot stiffer without the rubber in the original strut mounts? - What does a power steering pump sound like when it starts going bad?
