pheonix165
Posts posted by pheonix165
What are these rims and tires, anyone know?
http://img.photobucket.com/albums/v384/subyrally/DSCF0378.jpg
nissan pathfinder 15" 6 bolt
you should be ashamed...steeling someones show car. my god...
has it even seen dirt?
ok, sure...
1)it looks like i'm bringing my 87 sedan, + helmet (even though the car may be rwd by then)
2)i will be tenting it!!! and i hope to be getting there friday night, so obviously i will be bringing my tent + sleeping bag. couple changes of cloths.
3)not sure yet what car my gf will be bringing so we may have a non-subaru (not really my choice)
4)bringing one of those camping bbq things but apparently i have to by fuel for it once i cross the boarder...
5)spare set of tires and tow strap...
6)cooler...i cant bring any food across the boarder either so i have to get that when i get there too.
7)yes i will have cash
wheres the nearest walmart?
when do the gates close on friday night? i was reading in the wcss9 thread that the gates will be open for early arrivals.
i know i'm forgetting a bunch here
not quite what i meant but thanks
its my first show so i want to make sure that i'm not missing anything when i get there...so...
what do i need to bring?
and what should i bring?
nice car...is it even possible to make those things that low?
i've towed a fair bit with both of my cars. what i encountered was two things, first, primary front drive meant that i was using 4low to get going sometimes...and second, the breaks may not stand up to a lot of sharp stops.
some may tell you to watch you temps and what not but usually i only tow in the winter so i've never had an issue with that...
but then i guess if your pretty much just looking for a hitch anyways...
its official, i won't be going...i failed to get the barrier between the trunk and cabin finished this weekend (which i need to make the car DOT legal ).
well i will be down there for wcss with helmet in hand :-\ ...
happy belated ed...sorry i didn't know
with the interior now out of my car that puts me in rally prepped?
woohoo, good thing i only do it for fun otherwise the hole 70hp thing would really be getting to me
still not actually sure if i will be going as my car is curently not dot legal :-\
nice car...kinda in bad need of an lsd or locker
thats funny, when my wife says "do whatever you want" its usually fallowed by "but...":-p
imho, the white looks very good. makes the wheel look a little bigger to me...
great work, keep it up
i see that you have a 87. if its a dual range it will make all the difference.
actualy i have an 86 and an 87 i just haven't changed my profile, but yes both are d/r 5 speeds and i should have my tow strap with me (normally i use it to pull other people out of trouble so to use it for myself would be a first:eek: )
in my experience, soobs don't really as high of exhaust temps as other vehicles do, in addition to that...as long as you don't remove the heat shields or the remaining sound deadening you should most definitely be fine.
i don't have carpet in my sedan and while it is louder...its also worth pointing out it you can also utilize the drain plugs that are in the bottom of the floor.
how far would a factory stock ea82 wgn with oversize tires (25 1/2") make it on some of the trails? as i understand it some of them are quite mild.
okay, delta got back to me quoting 72.50 usd per side plus i need to ship them cores...not bad i guess, i'm just not sure its the way to go anymore
i didn't even know it was that bad!!!
thanks, i might have saved me a bit of money.
still sucks though.:-\
ouch...
while i agree that cost per hp is going to be better with an ej swap...i refuse to deal with customs more then i have to.
last time i picked something up from the states they stripped my car, its just not worth the effort there guys.
what i think i need to do an ej, would cost a hell of a lot...even bargain hunting it would still exceed what i payed for the car...soo...cams it is
an ej is going to cost me a hell of a lot more then just a couple of cams lol
especially around here. if you find one thats high millage and maybe on its last legs it will still set you back at least 1500, couple of cams 200 tops.
but then on the island thats just the way it is...
delta is the only one that hasn't gotten back to me yet (its been about 7 business days)
finding someone local is like pulling teeth. if they don't laugh at you they just assume your not worth the business, which is horrible considering i'm in the parts business myself.
but yeah, i'm down to two companies...one that didn't know what an ea82 is but is willing to do all the research and go through the trouble of finding the cores to do the grind on in the first place. or a second company that is apparently to busy...
i'm researching having some cams grinded somewhat locally but i've been asked for things that i don't know, so if you guys could help that would be great.
what i have is an 87 ea82 n/a
what i'm looking for is: casting number, lift, duration
trying a search yielded no relevant results (as can happen with a sometimes cluttered board)
Common power sucking culprits?
Posted
coil? vacuum lines? is the carb sticking?
