ben--ny
  1. good to here hows that motor running for ya??????
  2. gd, can ya put solid lifter and matching cam in a hydro block???
  3. gd, so the cam is the same too
  4. i'm looking for some help, is the ea81t crankshaft any stronger or different then a standard ea81??????
  5. ok maybe i'm wrong here but useing commonsense here tubro takes 1300 egt throws it down the carb, supercharger takes takes ambient air and throws it it to the carb??? whitch is hotter
  6. jon dont tubrocharge it, supercharge, it think about it, when you use a tubro you just dumping hot exhaust back in the motor to get hotter!!!!!!! know wonder the heads crack??? check this out www.rotrex.com
  7. ej2.2 wieghts in at 300lbs ready to run at 130hp ea81 80hp ready to run weight 175lbs 2.2 = 50hp more = 125lbs more in weight if it was me i'd skip 2.2 and go right to 2.5 weight in a 315lbs for the 15lbs in weight diff you get 35 more hps. if weighty matters ea81 if it don't 2.5
  8. jon, nope looking for the whole motor this time
  9. tristan, i'm looking for a dual carb jdm ea81 got any???
  10. i'm hoping to get strated on one myself soon
  11. anyone make a supercharger for ea81????
  12. gd does that go for ea81T HEADS TOO
  13. hows the motor running more power with the duel port heasd??
