Everything posted by pitstain
	Well I did an oil change today, only 3 quarts drained out, I suppose the rest leaked out of the front or rear main seals, and burnt on the exhaust as usual. But I was greeted by alot of what looked like yellow teflon shavings, and a few ant sized chunks of metal and a couple little spirals of metal shaving....... The damm car still runs strong though....? Where would I go about finding a good EJ22 for my ol' brighton? Ebay and the local junksyards are already being checked, but maybe a JDM import or some super secret stash is around that someone could point me to? I really appreciate any help, I love my lil subie and don't want it to die. Thanks guys, Ian
	Well guys I took it to my guys at Jifflyboob and handed them a quart of Lucas sythetic oil stabilizer, and had them fill the rest with standard 10w30 pennzoil.....I have to say my noise had dimished greatly once warmed up, and my mileage also went WAY up, I did 230 miles to PA. and got maybe 20MPG and post oilchange on the way home 230 miles i made about 28MPG.... she still smokes like a bitoch once parked after getting off the highway, but that is expected since the cat gets soaked by the slow oil leak.
	Thanks guys, I have to put it in for service sooner or later so I am adding all these items to the list....LOL the maintenance is gonna cost more than this car is worth....though I did a 500 mile round trip to PA. and back and averaged about 28 miles per gallon on the way home, as opposed to the 15 I get in the Lightning.....I guess the lil subie earns it's keep.
	lifters eh? that dont sound too fun, can i just leave them as is? the car performs fine the knocking noise sounds "larger" than valvetrain noise i like to think. either way when it goes in for a timing belt i will have them checked out. Also are there any good subie shops in the nyc area that you have heard of? thank for your continued diligent dessimation of knowledge it is greatly appreciated Ian
	Hey i am on enough forums to know when i see one of the "brains" in a forum.....I am in the bronx and just acquired a 1998 leg brighton 2.2 AT with 138,000 miles on the odo....it needs some help...you may have seen a few of my other posts. 1) I changed the plugs (ngk laser plat) wires...generic, also the fuel filter, air filter, pcv and its hose, both accesorie drive belts, and some chevron fuel cleaner in the tank......this thing runs STRONG now.....but the previous owner understated the oil leakage problem, and also FINALLY told me she never did the timing belt change...NOT ONCE...LOL 2) I sprayed the bottom of the motor and cats while i was doing an oil change and then took the car to the pressure washer and sprayed underneath.......i drove about 15 minutes home and got a flashlight under there.....i saw the oil on the bottom of the front timing cover AND ontop of the cat below what i assume the rear oil seal area. 3) when making sharp turns i notice a bit of chatter from the diffs....i had this chatter in the rear of my f-150 when the tractionlock diff was going on me.... So.....I would love, at least a reccomendation for a good subie mechanic in long island or the nyc area....OR if you do this work for a living I would love to give a good forum guy the business. Thank you, Ian "pitstain" schwartz this thing i get but the legacy is somehow intimidating me
	ok guys the bottom of my oil pan and the cats and lower front crossmember are SOAKED WITH OIL...... FYI build date oct-97 I dont really see any oil anywhere else.....and it barley looses a quart in 3000 miles.....please help..... Hopefully your solutions will include me putting some gasket sealer here or there as i really dont want to drop alot of loot on this car. I already did acesory belts (both), ngk laser plat. plugs, wires, pcv, fuel filter, air filter,silverstar bulbs, new wipers, and synthetic air in the tires. thanks alot peoples i appreciate any help
	it is a 98 brighton according to subaru customer service it was built october 1997.....I don't know where it was built. ok so I did the fuel filter, pcv valve, air filter, and am putting in new ngk laser patniums tonight, the engine makes a bit of a clanging deisel sound or two stroking noise though........
