Posts posted by subaruplatt
My 2002 Forester came equipped with P215/60/R16 tires, and stock wheels with a 55-mm offset.
I bought the same size snow-tires 5-years ago, and mounted them on steel-rims with a 42-mm offset. I've had no clearance problems at all.
I bought the steel-rims at Canadian Tire (Item No.09-6099-8, which I now cannot find on their website).
I keep my snow-tires on all winter - anytime when the ambient temperature is below about 5C (40F). The softer rubber on the snow-tires makes for much surer road handling, even on a dry pavement. On a snow-covered road, the AWD plus snow-tires are amazing.
I see from the weather forecast that Ontario is being blasted with cold weather and snow. You'll love those snow-tires.
6.5jj, offset 48, bolt pattern 5-100
2005-2004 X, XS, XT
2003: X, XS 215/60R16 94H M+S 6.5 jj, XS, XT, alloy, offset 48 (1.89)
2002: L 205/70R15 95S M+S 6jj, offset 48 (1.89)
2002: S 215/60R16 94H M+S 6.5jj alloy, offset 48 (1.89)
2001-1998: S 215/70R16 94H M+S 6.5jj alloy, offset 48 (1.89)
2001-1998: L
1998 standard 205/70R15 95S M+S 6.5jj, offset 48 (1.89)
My buddy had his whole front end replaced by a subaru dealer. 2003 forester like yours.
There is a suspension recall on them. Don'y worry you will get either free rustproofing or a new suspension.
Are you sure that it's not worth doing at the dealer?
Yes Price is $8k seems like a good price I can't find one for that price out west cheapest is about $11 - 12k
it is a lot of miles but Subaru's are reliable cars so I hope it will last a while My 1990 Legacy has served me well got a lot of miles on it.
8 grand is golden!
Remember that for another 4 grand you could do the head gaskets, timing belt-water pump,valve clearance, re-seal water pump? maybe.new koni shocks etc.
prices for used subarus are reasonable no doubt !
2006 Impreza wagon.
Car runs richer initially then idles down quicker and I feel the car warms up quicker as well.
Seems like it took a while for the ecu to trim. Initially the exhaust had a rumble or louder note when cold. I'm not sure it might have gone away?
Ran fine at 122 KMH for 1 hour. Smooth as silk when I put to bed.
Now the ECU has had time to learn, the start-up mixture is somewhat leaner ( nose test ), and the idle down is quicker. Also I would swear that my warm-up time is sooner, the idiot gauge thermometer rises in just a few blocks. The auto for what it is, also seems quite smooth, is it possible that instead of delaying lockup as was previous for warm up purposes they are revving each gear a bit more instead?
What vehicle was this on?
2006 Impreza wagon.
1 Fuel one way valve gasket replacement.
2 ECM-Reprograme.
3 Inspect and punch test lower control arms.
I had known about the fuel valve recall for some time but hadn't bothered to do it.
The ECM re-flash is the second time the firmware has been upgraded on this car. I was told that this one improves the environmental performance of the car. http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&sqi=2&ved=0CB8QFjAA&url=http%3A%2F%2Fwww.cars101.com%2Frecalls.html&ei=uGCVUI-YHoTfyQHUzYD4Cw&usg=AFQjCNG8kpxIozX9K9-2YU6f8ev853_tpQ
Because my front control arms were "like new" they rustproofed my front end instead of replacing anything.
Nice just in time for winter:headbang:
Ok, thanks!
Edmunds and KBB put the value for a private sale between $9500 - $11500 depending on the condition. The car is in good condition but it has a few small surface rust spots developing on the hood and roof.
Does being in Canada have a big effect on these valuations? Should I expect to pay more than that here? I check the Canadian Black Book website and it put these car at over $16,000! I think there may be something wrong with that calculation....it's not a WRX for goodness sake.
The owner wants $12000 or more...I think that's a bit steep for a car with over 100,000km on it.
These bodies are not particularly prone to rust. But if people let chips and scratches go unheeded this is what happens.
Still takes forever to rust through the panels, which I might add are not structural.
Have a few sections or panels painted when you can afford to.
Also have the engine area steam cleaned and oiled.
There's a 2008 Impreza 2.5i with the sport package (not an outback sport) in my area for sale for $14,000. It's got 102,000km on it and appears to be in good shape. Although I have not run a report on it myself yet, the owner says it's clean.
Is $14k a bit on the high side for a car that's 5 years old and has over 100,000km on it?
UC
$11-12k is more like it, but then again it is the newer although not newest body style. These cars got esp.
At 60 K km I found my front pads half way and my rear pads wearing on an angle (sticking pads).
I replaced all four and didn't touch the rotors.
At 100 K km my rotors are still pretty nice. Then again they don't owe me anything any more.
Not sure but I think subaru now uses a different pad compound for replacement as it's less spongy.
O yea and standard procedure is to drain and replace brake fluid every 2-3 years. INMHO
If you can suck some gas line anti freeze through the EGR.
Good cheap fix.
Stange some times I think mine is over idling.
The glide or momentum you feel is in fact computer simulated.
You find this out when you drop it in neutral.
After two major impacts my 06 impreza is yet to need an alignment.
Sometimes after an impact the car gets new paint and things like new rads.
it's an upgrade!
Changing a fender is no big deal, they bolt it on.
I would drive the car.
Just make sure the left one is tipped down a bit more than the right one. Not much say six inches at 10 feet.
THIS IS A LEGAL REQUIREMENT TO PREVENT BLINDING ONCOMING MOTORISTS.
The lights work in pairs and shouldn't iluminate past peoples trunks into the windows. Thats your right beam limitation.
Figure out what your safe nighttime following distance is and set your lights so you don't illuminate the inside car in front of you
That being said this best works with lensed ellipsoidal projector styled lamps
with a projected aperture.
Regular headlamps get turned down lower than the ellipsoidal kind because of the blinding factor.
What does anyone think of this head gasket?
http://www.smart-service.com/blog/2010/03/which-head-gasket-is-best-for-a-subaru
My 06 impreza 2.5 NA threw a valve at around 59000 KM.
Both heads were replaced by Subaru with new ones.
I recommend that the first maintenance you do would be to have the valve clearance adjusted and or checked. This is a simple procedure.
Mine seemed to benefit from new plug wires too.
Also check and or replace rad cap. I took mine off:clap: and cleaned the seal.
But I'm picky.
All in-all I would say it's pretty smooth and quiet engine and has yet to leak a spot of oil.
Dito
But check the hubs for concentricity too.
I for one absalutely love what I have seen and know about the BRZ so far.
The essential car for our times !
Another 50 + grand dream machine just isn't making as much sense as it used to, at least to me.
The STI was always too expensive for me.
For me the overriding aspect of this car is that they kept the price down, so mere mortals like me could at least dream of owning one.
I would inspect the valve clearances at the very least even if you determine that the valves are good.
The car in front of me swerved to avoid it.
I drove over it. I was amazed that the clearance was just enough.
The mattress made a "crrrunch" sound as the car effortlessly whizzed over it.
The body made no contact. No damage to tires either.
Really I can hardly believe it myself!
If the mattress hadn't laid so flat and wasn't just a modest single unit it would have made contact with something other than the wheels.
I was driving along and I went to open my glove box.
It slams open and busts the two cheesy plastic stoper pegs on each side completely.
Now I have a self emptying glove box. I't surprised me at how porely this particular part of the car is made.
Guess I need a new one and I also conclude that this is a dealer only purchase?
Are there any fixes other than replacement?
Thanks!
06 impreza
1 drain and fill every 60-100 K. This freshens up the chemistry and is really all you need.
It's only 4 litres that need replacing if my memory is correct.
The Japanese spec fluid has something + in the 100 degree spec for maintaining viscosity.
Warming up the automatic transmission fluid becomes the problem.
The all wheel drive clutch pack shares the same fluid as the trany.
I assume that the clutch pack is not as kind to, or as effective with lesser fluids, especially when things heat up.
The Yokohama Advan Envigors are the best deal in town $.
A fine hot dry tire with a beautiful turn in.
Fantastic wet tire that leaves you thinking they are actually better wet!
They are a little noisy when new and are absolutely useless in the winter.
Never the less, they are as I have said, stelar in hot and fantastic in wet.
So I still recomend snow tires as these things although technically all seasons really don't cut it for winter.
True all seasons are tires like the good year triple treads, highest rated are nokian wr, but don't expect to really hook up in the summer even as well the lowly envigors, not nearly! Although I would be curious how the new low profile triple treads are performing?
2006 impreza wagon 4300 55 watt HID H7 in the Low Beams
Posted · Edited by subaruplatt
As the title says my 2006 impreza wagon now has 4300 degree Kelvin 55 watt HID H7s in the Low Beams.
The short story is that they still have a really good cutoff they aren't blinding and they are brighter.
These bulbs appear to me to be 100% compatible ! I have a standard conservative DOT beam pattern! Perfect!
The H7 HID bulbs are a direct fit for the OEM low beam projector lamps, including arc gap etc...
The 55 watt HID bulbs actually run cooler than the 55 watt halogen bulbs they replace.
HID bulbs give off more light in the visible and ultra violet spectrum and less into heat/infra red region, but with halogen more than two thirds of their total energy gets wasted in the non visible infra red spectrum, fact.
HID 3 times brighter per watt. They are busier making light than they are making heat.
No they are not as bright as your typical uber riche mobile. This is simply because the factory lens and reflector system in the lamp is smaller, from simpler times.
I got the 55 watt ballasts but didn't require the canbus version. I did require capacitors to keep the daylight running voltages from causing visible flicker.
Note... Get bigger capacitors for 55 watts as most of them will be made for 35 watt.
This advise should also apply to the identical 2007 impreza. The 2006 sti which had HIDs as an option used a very similar almost identical headlight assembly but the bulbs they use are 35 watt D2S base.
Cheers!
I spent money on every thing I could and including a very professional/clean installation it came to 180$ + tax.
I got it done at https://www.facebook.com/jvghid
JVG Auto Customs Inc.
