2
Posts posted by SubaruJawn
Plans:
Lift with Forester Struts, Fix Dents, Replace engine with EJ22EA Dual Port heads., Install UEL Header, install a Loud Muffler.
bigger tires.
after selling my Loyale, i decided to get an automatic for easy driving.
found this 1997 impreza L online asking $800 after negotiation i got him down to $600 CASH and he used hi AAA to have it towed to me, since i couldnt drive it home.
Details:
Name: Preza (the 4th)
Train AWD Automatic 4spd
Engine: 2.2L EJ22E
Body: Wagon
Color: 66C Blue Metallic
Mods: Lowering Springs, STI front seats, front strut brace and 16" Rims
Problems: Water leaks out of pump just as fast as you put it in, Speed-o doesn't work, rides like a go-kart and some body dents
so in short ?
not much power gain and cost is not worth it ?
has anyone completed an EA82 with EJ pistons ?
if so a power increase ?
local shop i know said he can bore out the block for larger pistons.
Nice Lookin' Wagon!
Have you found the Culprit?
nope, and for some reason doesnt do it anymore.
ive got an xt6 I'm parting out if you'd be interested in the radiator from it.
how much ?
hey guys
in need of a radiator for my 89 XT6
2.7L H6 Manual Trans
i have a 1997 impreza, could i make this radiator work for my XT6 ?
or is there another option for radiator replacement ?
You can run either phase 2 head. Phase 2 head gasket coolant ports will match any phase 2 head.
Need the phase 2 2.2 head gasket to match the bore size of the block.
so then i need to return the pahse 1 headgaskets and go buy phase 2 gaskets ?
Need to match bore size, and cooling ports.
Phase 2 2.5 heads onto a 2.2 block, you need to use phase 2 2.2 head gaskets.
Phase 2 heads all have the same cooling ports. Need to match the 2.2 bore size which is the same for either phase 1 or phase 2 2.2. Phase 2 2.2 head gaskets get you the ports and bore size you need.
so i need to use phase 2 2.2 heads ? i still have them..
you can put the phase 2 heads on the phase 1 engine. use the HG that came with the block. there are charts that detail what the compression change will be when building these FRANKENMOTORS. Some are slight some are more drastic.
You might want to look into installing an oil level sensor After blowing 2 engines it might be a good mod to add. Wire it to your horn so when you when you run low on oil your horn will be honking non stop
Use the phase 2 gaskets, the coolant ports have to match the heads.
Phase 1 Gaskets or Phase 2 Gaskets ?
which is it ?
dang IT !! i just ordered the headgaskets for 1997 block..
i was told to use the block's gaskets
frankenmotor ?
last i knew that was a 2.5L with 2.2L heads
i'm installing Phase 2 2.5L heads on a 2.2L
yeah, i see that the coolant channels are a bit different..
shame i couldn't use the 01 gaskets, love to use the dual layer steel ones.
Fairtax4me
are you sure ?
ebay shows that headgaskets are not the same, i looked at the pictures and indeed they are different..
if it still works then let me know which gaskets to use, 2001 ? or 1997's ?
ok, i found a 97 impreza obs thought about buying for the engine.
hope these heads are ok, if not i an install the old phase 2 heads..
hey guys, long time been on usmb
i have a 2001 impreza L recently blown due to running out of oil.
i have installed EJ251 heads on my impreza ran great till i ran it out of oil..
i am searching for another engine and would like to know if i could use a phase 1 ej22 in my phase 2 impreza ? change heads ?
like maybe a 1997 or 1998 EJ22? with my phase 2 heads ?
1995 ?
thanksi greatly appreciate the help...
alright, cam pully changed stripped thread reapired...
snd the result is...
still not running, though.. damn threads stripped out of the timing tenstion bolt hole...
gotta get helicoils..
1994 Legacy Wagon
in Members Rides
Posted
hey guys recently got a 1994 Legacy L AWD 5 Speed Manual Wagon
Body is rust Free ! Paydirt ! so i thought...
Long story short my Legacy was Brain dead, got another ECM on it way.
Here He Is
Scubie-Roo aka Scubie
When Bought
Current
Not Going to Lift This Time, Going for Sport..
