Everything posted by Legback
	When I googled this topic I got one result that made any sense at all. It was at just answers.com by an auto tech by the name of Mike V. He said that after 18 hours of trying to isolate this very problem he found an open clip under the drivers seat intended to power up low tire pressure sensors. But the 06 outback doesn't have that feature so it is just an open clip. When it gets corroded it sends funny signals back to the integrated control module. To fix this he suggests clipping the green wire with a yellow stripe on it. Sound crazy? I did it it worked. My blinkers no longer work with out the key in the ignition and there is no more ACC flashing on my clock display. Thank you Mike V at just answers.com!
	Hey , The clock is in the center of the dash with the thermometer and MPG display. Came out of the store today to see that my blinker was still going. Keys were in my pocket!! Wierd? Very. Called the Sudaru experts I got it from. They said its rare and they'll have to hook it up to the big diagnostic computer to be sure but, most likely the whole computer will have to be replaced. 600$ part two hours of labor. Tried unhooking the battery to see if that changed it. When I hooked it back up, the trunk wouldn't unlock with the in car unlock switches. Only with the trunk button on my keyless entry remote. How's that for wierd? Trev. Nothing in the owners manual about this.
	I bought a 2006 outback sohc in march and they did the HG's etc. Knowing the animal, i look in tje overflow tank regularly and recently noticed the oil line starting in the tank. They said just clean the tank out and refill it. There are no bubbles in the tank when at temp. The question is can oil get in the coolant if there isn't a big problem in the engine? And. Should i worry about this? Ive put about 6000 miles on it. Bought it at 94000 miles.
	I'm really telling what I know. I used the term evenly in my second post to describe that the bounce was not from the rear or front. I asked you to describe these things because my word " bounce" wasn't getting my point across and I needed a new word. It feels to me like the carrier bearing is worn and the whole Drive line is slightly bouncing. I would love to know what words would describe that feeling. Thanks for help. Looks like its a not a super easy common thing and a pro should see it. I figured if we're a real easy thing a real easy answer would fall out. Thanks for your time!
	Ok. It bounces evenly 35 mph and above going straight. Other times over the same stretch of road it rides flawlessly. One of the wheels has a whole pile of balancing weights on it but the tires are equally worn. I don't have a lot of history on the car as I just got it used but from a reputable Used Subaru place. They did a lot- hg's and all associated parts when I bought it before I picked it up. It so random,I'm reluctant to call it to their attention. The steering also has a random shutter. If I stop and put it in reverse and spine the wheel quickly it will get very hard to turn for a second and then to go a pulsey/ shuttery feeling. Maybe they're related. I'm hunching the driveline is making me bounce at random.
	At first I thought it was the spring roads. I'm realizing now that there is no obvious pattern in why it happens. The whole car is shimmying up and down or bouncing at random. It has 94000 miles on it and ive had it for under two months. And no hydraulics are present in my suspension:). It would drive anybody batty! Have any experts experienced this? Thanks, trev
	Replaced pressure sensor and forgot what it was called. Sorry for the confusion. There is no question it is leaking again after being replacing about a year ago. Did the separator plate etc. HG"S etc. 12000 miles ago and right valve cover still weeps a bit. Is this an part that must be Subaru or else? 98 legacy outback 2.5
