Everything posted by jrgaylor
	Plant manager closed the shop for today because of the snow and ice , but now I will have to work saturday. Joe
				rear defogger relay location?
jrgaylor replied to jrgaylor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Once you push the buttom for the rear defogger it stays on for set time before turning off, it is in the wiring diagram but i do not know its location. Joe -
				Need a P/S Pump please help
jrgaylor replied to dave valiant's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I also hav a P/S pump for a ea82 located in WA, if you need it let me know. Joe -
I did the search earlier and it did not help, I have found 4 relays in a line above the fuse box,and I have a empty socket near the fuse block that looks like a relay may go there. A new question I have is where is the rear defogger timer located at? Joe -
	Where is the relay for the rear defogger? Joe
				EA82+weber+power steering?
baccaruda- where is spovegas,wa? I am thinking of ditching the power steering and AC, I do not need either one and I have found a donor vehicle for the manual steering, and alt.brackets for a non a/c, p/s car, I would save a tiny bit of weight and HP, not much though plus it would be easier to work on the engine. Joe -
	I almost had my weber installed and the electric choke hits the back of the power steering, anyone have this problem before? Joe
	What is the normal range for compression? On my 87 wagon I have 125# I have read that if the cylinders are within 10% of each other not to worry as compression varies from car to car. I know 1 head gasket is blown. Joe
	I am in the process of replaceing my friends head gasket and before I started I did a compression test on the other head and it has 75# in both cylinders 2&4. So I am assuming the compression should be around 125# and that this other head gasket is also bad, correct? Joe
				EA82 Wagon suspension mods?
jrgaylor replied to Subafreak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I do not know if any of you have tried this or if it works on subarus but on my explorer I have removed both the front and rear sway bars and it increased my articulation by a couple of inchs on both ends, it took alittle while to get to use to the lean on corners. Joe -
				Tahuya ORV park, WA Dec 26
jrgaylor replied to jrgaylor's topic in Meet n' Greet. Your USMB Welcome Center
So how did the day go? great for the first 20 minutes, then a blown head gasket ( can you say hydrolock ) ended the day early, My friend decided to run straight through the middle of the puddle and that was it. I think a snorkle would be order,needles to say now I am replacing a head gasket this weekend. Here is a link to the video http://madproject.com/vcontroller.php?id=86 Joe -
I will be away from the computer toady so if any ones to come along, leave a post here and meet at the belfair safeway at 10:30 Joe -
	If zapar does not want then I will buy it. Joe
	What are the gears in the diff? and how much? I am a certified welder at the job. There is a company (http://www.offroadlockers.com/index.html)that is coming out with a line of auto lockers, I am waitng for one or two for my explorer I have sent them a line and see they want to make one for the subaru. FYI (everybody) this "autolocker" is locked all the time, but it will allow one wheel to go/spin faster, but not slower, cost is $200 Joe
	Is this a problem with the welds? Joe
	Don't froget it was named after a locomotive in the early days "T9O" I was goofing off when I got high centered, I was watching my tires to see how they spun and how the diff. worked, so I was not watching where I was going backwards. I have found that with my explorer that has fords trac-lok (aka posi/limited slip) that when the wheels start to spin out, I can get into 4LO and put my brakes on and power brake myself out of some places, what this does is help equalize the power go to all the wheels because none of the tires will spin. This is what I was doing when I got stuck. Joe
	Rooinater- who is the manufactor of that locker? How much? Joe
My friend has a nearly stock 88 5spd D/R hatch, he has a stainless steel exhaust. We went out a few weeks ago and he could go everywhere I took my explorer. When it gets closer to the 4th we will see what is going on. Joe -
	A buddy and a I are going to tahuya on Dec 26 if anyone else is interested let me know and we can meet up. Tahuya is near belfair washington. I will be taking my explorer as my subaru is not ready yet and my friend will have his 88 hatch. Joe
	I want to thank everyone that has gave me input in this thread. Joe
	snotrocket- I found one of the vacuum lines that go to the secondaries on the carb was on wrong, once I connected the line top the right port on the carb the engine started to respond how it should. So the engine is running fine but I still have the funny vacuum reading. Joe
	So if the intake valve is sticking open or maybe the valve guides are worn, how much should I expect to pay to have the heads reworked. Joe
