Everything posted by Crabman
Nice 79 brat in CA $700 !!!!!!!
Yes it does look nice. Looks like its a case of 'just add engine'. Looks like it even has the original winch.
Gen 1 Gas mileage
I do 80 miles on the highway everyday. I am getting around 24 or 25 in my '79 Brat. I'm a bit heavy footed, and also have to deal with a lot of stop and go LA traffic. Jon, you mileage sounds excellent! What speed do you usually drive at?
EA71 Camshaft Lobe / Lift Specifications???
I know I know, Forgive me, I'm a bit stuck on camshaft issues lately. Trying to figure out if I pulled a reground cam out of this modified EA71 I tore down. The only way I know to tell for sure is by measuring the lift on the lobes. My manuals have specs for the journals, but I can't find any specs for the lobes. Does anybody have EA71 camshaft specs in their manuals?? If so can you tell me what the normal range is for intake and exhaust lobes on an EA71? If not, does anybody have an old EA71 camshaft lying around that maybe they can get some quick measurements on? Any close up pictures would be helpful too say of the normal lobe duration profile. Thanks much in advance, Crabman
1979 DL cv joint
Don't know if their the same, but I bought two excellent complete axels of ebay for my brat. Only $35 a pop.
Dissection of a Very Modified EA71 - Please View
Thanks for the pics! I could make this engine run if I had your new cam! It's not that the lobes are in different spots, is that the high spots on the lobes are at different places. I'll try to explain better. If you orient either one of your cams to point the same direction as the cam in my picture, try turning your cam so that all of the high spots in the lobes line up with all of the high spots in the lobes on my cam. You wont be able to. This is because those lobes open and close the intake and exhaust valves at very specific times. And since this cam is from an engine that originally had exhaust valves in the center of the head, you couldn't expect that this cam would be compatible with an engine that had exhaust valves on the outside of the head, because the specific times that those valves should be opening and closing would be completely different. Having said all that, some information from you would really help me out. Do you have a part number for that new cam? Is there a number on that cam, between the first and second lobes like in my picture? Do you know where to find another one? Thanks in advance! Crabman
Finished the tear down a while ago. Some good, mostly bad. First off - This case is definitely garbage. Correct me if I'm wrong, but the dark spot is probably some sort of JB weld repair? Other side The deep oil pan is kind of neat. But probably only compatible with sand rails and what not. Any idea what those little hinged doors are for? All four pistons are in decent shape, but the rings were totally shot. The manufacturer is "ARIAS", and I think the model is 353. I found a website for Arias pistons and emailed them looking for compression info, but they got back to me saying that they didn't have any info on this model because it was too old. Finally the cam. And this is where the real mystery is. Because according to my book this cam is from an EA71. The EA71 has exhaust valves on the inside of the heads. These EA63 heads have exhaust valves on the outside. Which indicates to me, that this engine probably never actually ran in this configuration. Perhaps this explains that JB weld repair, and whatever catastrophic event happened to the case? I'd really like to hear what you guys think. If you see something I don't. I am looking for an EA63 cam (from a 4 exhaust port engine) right now. But at this point, I'm not even sure that you can put an EA63 cam in an EA71 case. So it's still totally a question mark, what I can use from this engine and what I can't. Let me know what you think. Cheers, Crabman
Superoo 72 GL racecar
Is that the battery in back?
What's it worth?
I second this response. Beautiful old soobs are a hard thing to place a firm value on. If I had room, and was looking for an around town soob for the wife and kids, I would pay up to 4K for that beautiful wagon. But to the collector, for the guy that is looking for this specific soob in great condition, it could be much more. Because it is slim pickins out there.
WOW! Looking good! You'll be done in no time.
Does anyone Have Info on EA63 Cams? Check Shop Manuals Please
Yep you are right about the valve arrangement. Early EA63 dual exhaust port heads required that the exhaust valves be on the outside. The later EA63 single port exhaust had the exhaust valves on the inside. What I am asking is how can you tell the two different cams apart from the two different set ups.
I know that the issue of the differences between the early and later EA63 cams has been discussed in the forum before. But I need to renew it right now. For those of you who aren't familiar with it. The early 1400s had dual exhaust port heads, the later 1400s had single exhaust port heads, and this difference necessitated very different cams for the two versions of the EA63 Can anybody tell me any way to identify the different versions of the cam? Can you look into your old books or manuals? Maybe you have a couple of cams sitting in your garage? My chiltons book tells me that the 1600 cam has a 51 stamped on it. The 1800 cam has a 79 stamped on it. No info though for the 1400s. Are there stampings on the 1400 cams? What should they be? For more background info, just check my other thread about tearing down that modified EA71. Any help is much much appreciated.
Oh man now I'm really confused. I got into the case tonight and got the cam out. It's got a number '51' stamped on the side. And according to my Chilton's book, this is a very normal EA71 cam. I also saw stamped, the letter G on the cam, but I could not find out whether or not this meant anything. But here is the kicker. This EA71 block (and cam) is running the EA63 dual exhaust port heads. This goes contrary to everything I've read. EA71 heads have exhaust valves on the inside of the head (as well as the exhaust port). EA63 dual exhaust port heads have exhaust valves on the outside of the head (just like the exhaust ports). MEANING, if you are going to use EA63 dual exhaiust port heads on an EA71 shortblock, you have to run an EA63 cam from and engine that had the dual exhaust port heads of course, because the lobs will be in completely different places. I really need to see some pictures to be sure of all this. Does anyone have pictures of any of the different EA63 cams? Does anybody know any of the identifying features of those cams? Does anyone have pictures of the piston side of the different EA63 heads? I'll try to post some pictures of everything I found tomorrow, but we are getting ready to go out of town soon, so this thread may be on temporary hiatus.
One more request. Do we know, are these heads 'shaved' for sure? Does anyone have pictures of any EA63 or 1400 heads, preferably dual exhaust port for comparison? Much appreciated, Crabman
Uh, OK, I am definitely getting outside my comfort zone here. :-\ There's no way I am going to build an engine that will only run on race gas. Can anyone tell me how to measure the "ccs of the head and volume of the piston dome", or otherwise, can anyone tell me how to accurately estimate the compression. And furthermore, what's ratio's take it into the race gas only zone?
These are great suggestions, thank you. Planning on opening the case tonight, will post more pics if anything interesting.
A Memorial Day Subaru Adventure Like No Other
I'm sorry this is too funny, because I basically live in Torrance, work in Irvine, and I'm stuck out here for a while!! Would much rather be in a small town, maybe not bullhead city. Well if you see any nice gen1's out in those desert wrecking yards, let me know. Things hold up very well out there.
Yes I do believe so. Just outside Kingman. We stopped at many out there. Most closed. Could have been 'Dan's', but that was a long day. I may be wrong about that. You are from AZ? I used to live in Prescott about 8 years ago. Crabman
Has anyone seen an "M" on an EA engine serial number before? Were some engines modified at the factory? New question: Cylinders appear to be 'sleeved'. Is this normal? Possible to resleeve the case? Subaru360 - Agreed, this was probably on a sand rail at one point. And although some work into that deep oil pan, It will definitely won't work in my Brat due to the position of the cross member. Love to see some pics of those pushrods and rockers you mentioned. Well if the cylinders are shot and can't be repaired (reasonably), I also have another EA71 in my garage. It's a JDM fat case. Less than 40,000 on it. Still in the crate. Was planning to keep it as a spare, but now I am thinking I should take the best from both of these engines, and build something really super. Going to be very busy through the weekend, but hope to find some time in the week to get into the case. I love tearing down an engine. Each one has a story. Keep those comments coming fellas. I'll put up pictures of the open case when I've got them. Cheers, Crabman
Yes absolutely, lets see some pics!
Thanks Kostamojen and Zefy. Engine does turn over. So what I'm hearing so far: 1. Heads may need to be rebuilt, valve seats might be poor due to rust. 2. May need new shortblock because of rust in cylinders I'll try to take some pics of the pushrods and exhaust ports. I'll also try to finish up the tear down in the next couple of days too. Still a couple of question marks left about what's in the case. The webers that those heads are set up for are insanely expensive, and may be flat out cost prohibitive, or at least make this a very long term project. http://www.webercarbsdirect.com/product_p/wk328.htm They sure look mean on an engine though. Here's a pic of what they look like on an old bug. I may look into some kind of adapter for the intake manifolds, so I can run a cheaper VW dual carb set up. Money is tight right now! Looking forward to more comments. Thanks guys! Crabman
Yes I hear you Shawn. We we smart as possible and had no bad intentions. Just had to get a better look, I've personally never come across a gen 1 in a wrecking yard before. Just had to know if it would be worthwhile to come back. To tell you the truth, there were a few pieces I needed. But theft was not an option. Too many karmic consequences. I will admit, we knew there were no dogs after walking the perimeter and making a little noise. However at one point, a couple of black birds cawwed, and it was startling enough to send us sprinting to the outback.
I've tinkered with motorcycles a bit, rebuilt one engine. But I am a novice mechanic compared to others on the board. And still very new to the world of subaru. So, apologies in advance for any dumb questions! :-\ I have begun a tear-down of what I'm hoping is a very special engine. I've attached lots of pics to this thread. Please take a close look at your leisure and let me know what you know. This is the first time I've looked inside an EA71, so I'm not sure what's normal and what's not. Firstly some history: I was sold this engine on the premise that it was an E71 with modifed heads (obviously), dual valve springs with stainless valves, modifed rocker arms, deep sump oil pan (obviously), possibly custom pistons, and possibly that it had been left out in weather and held water at one point in its life. Now for what I have learned so far: By measuring the placement of the mounting studs on the intake manifolds I have determined that the heads have been set up for dual VW Weber 48 IDAs. This is a gigantic racing carburetor that is typically on engines larger than 2L. I have a hard time imagining that these would run well on a 1600 engine. I am wondering if the engine has been bored out, but I am not sure how to tell. Furthermore, I am fairly sure that the heads began life as EA63 dual exhaust port heads. From what I have read, this would mean that the engine must also have an EA63 cam. I have not split the case yet, but because of the monstrous carbs that were on this thing, I have my fingers crossed that there is some sort of high performance cam in there. Else again, I just couldn't see the engine running properly with those gigantic carbs. And finally, since the tear down, I can see an obvious water line on the valves, indicating that the engine has definitely held water at one point in its life. I'm not sure how to tell if this has done a lot of damage. So please correct me if I am wrong on any of the above points, and now here are several pictures from the tear down. Is it junk? Is it useable? Is it awesome? Let me know. The collective advice from the USMB knowledge pool will weight heavily my decision on what to do with the engine. The engine as it got home Top-down view Rocker arm - Modified? Intake manifold close-up Valve spring close up Engine front First head - Notice water line Second head First bank of pistons - Are these custom? Second piston bank Serial No. What it looks like now I guess that's it. I'm very excited to hear your comments. Also guess I want to mention the distibutor looks great. Shaft had no wobble, which to me indicates not a while lot of running time. If you guys need more picture to figure anything out, just let me know. I plan on opening the case soon. Thanks in advance! Crabman.
Well I had a very interesting EA71 to pick up out in the desert. And S'ko had lined up an SVX to look at. So we found a couple of wrecking yards between points A and B, decided to fork up the gas money, and we spent 15 hours on memorial day scouting soobs in far off places. The first yard we stopped at. I called ahead, their english was kind of broken. But they said they had two subarus from the 70s. We found this gold brat and an XT, not exactly from the 70s. S'ko scored a couple of things from this car. It was mechanically complete and had the third eye too. I picked up this modified EA71 from the nicest desert dude you've ever met. Gave $75 for it, and am currently in the process of tearing it down, trying to figure out if I got my money worth or not. I'm going to start another thread soon with pics from the tear down. Please check it out and let me know what you think! We didn't realize so many yards would be closed, and there was more than one that we had to walk away from. But at this yard, we walked the perimeter and could see a Gen 1 inside. So what did we do? What would you do after driving all day to find soobs? :-\ Just to get a better look of course. Wasn't much when we found her. She'd been shot and gutted. Didn't spend too much time looking at her. We could hear the dogs on their way ! But I'll tell you, from what I saw she was rust free. If anyone is looking for a body to build on, this one has potential. From the desert to the mountain. S'ko bought this SVX for parts I think. I am currently a 10% owner. In short, this was a seriously great day! Wish I could do something like this every couple of months. Hope you liked the pics. Crabman
Hey if you are just getting it running well, that's a different story. I thought that you might be getting her back into the shape she was in when she was racing. All that EA63 carnage you mentioned sounds worthy of a few pictures. I just picked up a very modified EA71, very cheaply. It was probably raced at one point in its life. Hoping to do some of the tear down this weekend. Hope it looks better than your EA63!
Well I'm not one to tell anyone what to do. I don't know what the owner wants, and I don't know what kind of budget you are working with,... but you gotta keep that supercharger/side draft weber on there!! It looks so mean! I understand wanting to step up the CCs a bit from an EA63, but perhaps you could fit the supercharger set up to an EA81, maybe re-jet the weber? Do you think there is anything interesting in the case? Modified cam maybe? High compression pistons?
