crazylong127
Everything posted by crazylong127
yeah that picture was before i beat on them some more. they are 235/75/15's. 28" diameter. now they only rub on big bumps. i like the way it makes it look.
well i got my wheels drilled and mounted up. they still rub on hard turns and big bumps. much better than before.
will a speedo from an 88 gl fit into an 87 dl? i am asking because my dl doesn't have a tach and the gl does. would it be a direct swap? thanks
yeah i searched for a little before i posted, then after i searched more and found what i needed. one of the vacuum connections is broken. thanks for the help
i have an 87 dl. it has push button 4wd. and lately the 4wd hasn't been engaging. what all could cause this? it used to work all the time.
thank you very much. this will be very helpful. by the way nice picture.
ok so i just got a set of 6 lugs that will work. now my question is what size of bit do i need to drill the holes? i have access to a drill press on base. so what are all the tools that i will need to do this?
ok so i just got some new wheels. they are 15 inch steelies off of an izizu trooper. with 6 tires ( 4 that are brand new goodyear wrangler at's 2 that are about half worn) and 5 of the tires are mounted on rims already. all for a grand total of $175. now i cant wait to put them on. pics will follow
ok another question. has anyone used 16" wheels? i just found a good deal on some gm half ton 16 inch 6 bolt wheels. also what is the largest outer diameter you can use without lifting. cutting fenders is fine.i am currently looking at 3 tires there outer dia. is 26.1 27 and 28 with an 8.7 croos sectional dia except the 28" that has a 8.6
yeah i know 31's are big i won't be using them. i just wanted the wheels and the tires came with them. i don't think it would be that hard. weld the holes that in them now then drill the 4 holes in the correct spots and i would enlarge the center hole to match the subaru one. and they would have to be balanced anyway when i get the new tires on there. was also thinking cut the center part out of one of the 13's and use it as a templet on the 15's??? i have an extra wheel so if it didn't work i would still be good. any ideas on that?
havent measured them yet. if they are 6x4.5 how possible would it be to just weld up the holes real good and drill 4 new ones in the correct spots?
ok i just got home from the junkyard and i got some wheels off of a dodge dakota. they are 6 lug so i hope i will be able to use them. and they came with 31x10.5 tires. all for 59 dollars. one of the tires is bad though. i will try to post a pic of them. i know that those tires won't fit without a lift. i will just get some regular tires untill i lift it. [/img]
i am stationed at offutt afb next to omaha
yeah i am going to a junkyard tomorrow and find some 6 lugs. what car or truck should i be looking for? or just any 6 lug?
what if i just put some 15's on it with some all terain tires? what would be the biggest tire i could fit without too much trouble, as i said before not worried about trimming fenders. would these fit? http://omaha.craigslist.org/pts/683795042.html
not much, they are pretty rusty
it is an offroad/winter car. i have another car that is daily driver
ok so yeah i will look at body lifts then. "stearing shaft must be lengthened (not offered at SJRLIFT )" how do you go about doing that?
so what is the best way to lift my 87 wagon? should i do body or suspension? i want to lift it so i can go mudding with my friends. also i want to get bigger wheels. should i go 14 or 15?
Subaru Lift Kit, Wheels and Skid Plate Group Buy
crazylong127 replied to Allied Armament's topic in Products for your Subaru
depending on the price i am interested -
choke problem/question please help
crazylong127 posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
ok so i am going over my motor making sure everything is good. ( 87 suabaru dl wagon 1.8L 5 speed)the only thing i really have left is a problem with the carb. as of right now the only way that it will run right is if the choke is almost fully closed. if i open it up and give it gas it will just suck air. i have been meaning to hook a gauge to the fuel line but haven't had time yet. what are some other ideas you guys have?maybe adjust the float?? -
muff;er replacment question
crazylong127 replied to crazylong127's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so it is 1.75?
