Timing Chain Replacement - Do I or Don't I
2007 Outback with the H6 engine. Over 295,000 miles, mostly (80%) highway. Oil and filter changed religiously (every 5,000 to 6,000 miles) I've just developed a dripping oil leak at the bottom of the timing cover. I have two philosophies: 1) Preventive Maintenance is good 2) If it ain't broke, don't fix it. I have hear somewhere that Subaru timing belts should be replaced at 300,000 miles, but I cannot verify this. The shop manual (yes, I have the official shop manual) only gives service intervals for timing belt, not chains. Other sources say only replace the chains if I am overhauling the engine. I am not having any timing issues, nor am I hearing any rattling sounds coming from the engine. So, do I simply remove the cover, clean it and reseal with 3-Bond (and replace the crank seal), or should I replace the chains at the same time? Your thoughts and experiences are greatly appreciated.😀
Propeller Shaft - New or Rebuilt
2007 Outback LL Bean Edition. I need to replace the propeller shaft -- front u-joint is going out. My dilemma is whether to purchase new from dealer (just shy of $700.00, including tax and discount) or a rebuilt unit from Cardone (via Rock-Auto) for half the price. I've previously had good luck with Cardone rebuilds, but a few months ago replaced my front CV axles with new OEM from my dealer, primarily based on what I've read in this forum.
Do I need a new battery?
jimbo747 replied to jimbo747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurns out it was the battery after all. It took four months, but the battery finally quit. When I replaced it with a new one, the problems I was having with my audio system went away.
jimbo747 replied to jimbo747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope. Original starter and alternator. It's starting to look more and more like the unit itself.
jimbo747 replied to jimbo747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX@ OneLuckyTexan -- Yes I do have the original alternator. Sorry I didn't see your post until just now.
jimbo747 replied to jimbo747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, Justin To answer your question, I only lose the presets after I start the engine. If I turn the key on, everything is fine; once I start the engine, the radio resets. Someone else pointed me to the Legacy.gt.com site where I found detailed instructions on installing the aftermarket stereos. I have found a company in Lakeland, FL that does factory stereo repairs. I may check with them and see what it would cost to have this unit repaired.
jimbo747 replied to jimbo747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks again. Your points are what is giving me heartburn over this. Losing radio presets doesn't seem to be a big enough symptom, which is why I posted the question in the hopes that someone else experienced similar issues. I was just out on ebay looking at new audio systems. There are some that really caught my eye (a backup camera would be awesome), but my LL Bean edition (I used to ask myself, "What kind of pretentious d-bag buys the LL Bean edition?" until I saw this one on the lot for a great price) has the automatic air conditioner system. All of the kits I've seen online are for vehicles equipped with "manual" air conditioners. If it comes to that, I may be making a new post on the forum... Thanks again for everything!
jimbo747 replied to jimbo747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for your inputs. A co-worker also suggested the dead-cell theory. Given the fact that the battery is 3 1/2 years old and I (and the car) reside in Arizona which is notoriously hard on batteries. I'll have it checked out.
jimbo747 replied to jimbo747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEverything is factory orignal
2007 Outback w/3.0 H6. When I turn the ignition on, everything comes up as normal. I can start the car no problem. There is zero hesitation indicating a weak or weakening battery. However, after it starts, the audio system completely resets. Presets lost and everything. This happens on the 1st start of the day; and occasionally on subsequent starts during the same day. Problem started about a 2 weeks ago. Battery (Optimal Red Top) is 3 1/2 years old.
Running Hot
I've got a 2007 Outback 3.0 H6 with 170,000. I live in the Phoenix Metro Area, where daytime highs have been exceeding 105 degrees for the past month. When outside temps are below 100, the temp gauge is right in the middle, where it should be. But when temps are above 100 and I'm driving on the highway (65+ MPH), my temp gauge creeps up -- not to redline (yet) -- but around 3/4 to 7/8 of the way there. I tried draining and refilling the coolant, but no change. 1) Should I be concerned or is this normal? 2) Should I try a cooling system flush (like Prestone?) 3) Could it be a thermostat issue? Thanks
So Long!
After many years and over 325,000 miles of faithful service, I have traded in my 1993 Loyale for a newer (2007) Outback. I want to thank all of you in this sub-forum for all your help, advice, and sometime humor in helping me keep my ride rolling. Perhaps I'll see some of you over in the "Current Generation" forum. Again, thanks for everything! Jim
Loyale more trouble than it's worth?
I also have a 1993 Loyale with an EA82 with 254,000 miles. 10 years ago I had a shop reseal the engine, then I did it myself about 4 years ago. It's leaking again and I'm considering tackling the job again this summer. Mr. Loyale said "I think Subaru is Japanese for 'leaky engine'." Another common joke is that Subaru's don't leak oil, they mark their terratory. Mine has marked the entire block. I read a thread several years ago entitled "Why I hate Subaru." In short, the poster had obtained one to use as a farm vehicle and would drive it until it died. The problem was, it wouldn't die. It was leaking oil, blowing smoke, and making all sorts of ungodly sounds; but it started every time and did what he needed it to do. The OP said he was apparently going to have to drive it until it rusted apart. He then went on to say that he felt sorry for those of us (like me!) who live in the desert southwest. We are stuck with our Subaru's forever!
Does Anyone have a CARFAX or Autocheck account
Thanks so much!
Show off your roos Mileage!
My 1993 Loyale has 235,000. All the way to the moon! Now, just like the NASA technicians on Apollo 13, I'm trying to bring it back home.
