Everything posted by ILOVESUBARU
both sensors are new as of today. gas gauge was still messing up so i thought maybe a wire was loose or bad...nothing appeared wrong put it all back together and BLAM! full tank..( i wish it was that easy some times) i will fill up in the morning and maybe that will reset it. thanks...any other advice would be great too. jeff
i took the instrument cluster off tonite to see if i had a loose wire connection to the fuel gage and now after getting it all back in place i turned the car on and the fuel gage told me i had a full tank ( which i dont have) on the drive home it fluxuated a couple of times down to 1/2 tank and then back up. any advice. has anyone encountered this before? let me know it has me pretty freaked out. jeff
is there anyone in the mt hood area that can help me figure out why my 1996 outback 2.5L auto, is getting 200-210 miles per tank? i recently had the plugs changed along with the spark plug wires. i also changed the air filter. i have been doing all of this stuff to try and solve my problem. i work at Mt Hood Meadows so money is hard to come by so taking it into a shop would bankrupt me. please help. if you have aol instant messenger my name is oversteezed. thank you. Jeff
My 1996 Legacy Outback with the EJ25 has been getting really bad gas mileage, i have recently changed the air and fuel filters and the oil is fresh, plus i am getting a vibration on acceleration between 20mph and 30 mph please. maybe they are connected, maybe not. please shoot me some info. thanks, Jeff
i just bought an 84 Gl 4sp 4wheel hi/lo, i need some tips suggestions on how to make it insane and run strong. i also need some help location the manifold to run to carbs. let me know ...thanks jeff
how can you tell if your clutch cable is bound up?, how do you replace a clutch cable?
thanks alot. now i don't have to worry about not having any tunes while snowboarding.
is is possible to keep power flowing to the cigarette lighter even when the car is turned off?..i need this to charge my ipod while at the mtn.
thanks.
how do i get rid of a code 35; Purge Control Solenoid? my friends car recently started this. please let me know.
recently my 1990 loyale has been getting real hot and will occasionally will blink a 33 code when the check engine light comes on..can some one put these problems together for me?
i have a pair of KC daylighters for 35.00 really good shape...let me know
whats the difference of MAF sensor problems and O2 sensor problems...how can i tell them apart
what are the "symptoms" of a dead o2 sensor? also i have two KC Daylighters for sale they both work. 30.00 for the set
