Olnick
10
Everything posted by Olnick
engine swap
Olnick replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just add a pint to your crankcase oil (make sure you don't overfill the crankcase) and drive around normally for a few days. Or try davebugs' suggestion, "a SPIRITED drive of 10-20 miles after it's warmed up!" When you're satisfied that the lifter tick is gone, change your oil and filter. Good luck. -
engine swap
+1 ^. Try the simple approach before you go tearing into the heads! -
engine swap
HLAs = Hydraulic Lash Adjusters. The MMO (Marvel Mystery Oil) treatment is worth a try, sometimes the oil flow gets plugged and the HLAs lose their prime. -
Ultra Grey is not the anaerobic sealant but it is an approved substitute. Be sure to apply it very carefully--you do not want it to glop out into the oil chamber (and the oil!) Pulling the radiator & fans is an excellent idea, especially for the first time. Makes working on the front end much more comfortable. There are two cam o-rings, one at the rear of the passenger side head and one at the front of the driver side head--behind the cam sprocket. Good luck and enjoy!
Welcome Bryan, nice looking car. Gosh it makes me miss my old GL and DL. Great license plate too, "XKE!" The Older Gen Forum should be a great deal of help for you. And be sure to learn how to use Advanced Search--that's a goldmine of information. Good luck with the car. Enjoy.
Welcome aboard, Kiwi! My family and I have fond memories of your beautiful country and lovely people. Congrats on your Subie. You'll find lots of good help and info here, but of course regular servicing and preventive maintenance are the keys to a happy life. Aloha!
How many miles on the car? How do the tires look--old and worn? If you have alloy wheels there may be some corrosion inside the lips, allowing air to escape. You may need to have the tires demounted and sanded smooth . . . and you may need new tires all around. I doubt that nitrogen would help you at all. Re the brakes: After a bit of driving feel around the hub area of each wheel (carefully!) and see if one feels hotter than the others. That would be a sign of brake dragging. Probably not the flex lines. If you find one hot wheel check the pads & rotor. Make sure the caliper piston is not stuck and (most likely source of the problem) make sure the slides are smooth, clean and well greased. Use high-temp caliper grease on them, of course. Hope that's your problem and not torque bind. Good luck. [Edit: Just re-read your original post and saw that you've already changed one caliper. Oh well, consider what I said as "confirmation"!!!]
You might not have ruined it. You'll need to go back in, pop the piston out and inspect it carefully. If it's scratched or gouged or if there is pitting due to rust/corrosion you will need to replace the caliper. If it's smooth and shiny you can get a very inexpensive caliper rebuild kit that includes a new rubber seal. You will need to bleed the brake lines afterwards. Good luck.
88 gl wagon tranny swap
Olnick replied to snowdrift's topic in Meet n' Greet. Your USMB Welcome Center
Hi snowdrift, welcome aboard. If you post your question in the "Older Gen" forum you'll get more response. And if you try the "search" function I'd bet there's tons of info from the past. Good luck & enjoy! -
Love your Li'l Red Wagon! Looks good. Welcome to USMB, old scooby.
Welcome jtrigger. Sorry to hear about your problems. I know little about the newer engines but am sure others who do will chime in tomorrow. Couple of questions--you said radiator was steaming when you took it in, how long had that been going on? Had you noticed the temp gauge climbing or spiking before the car was in the shop? Coolant level okay? How did the coolant look in the overflow--any bits or gunk in it? Hang in there, I'm sure some helpful input will be coming.
Kabuki idlers?
Olnick replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I seem to recall hearing good reviews of Mizumoauto. Suggest you get in touch with them and ask what gives? Good luck and let us know how it turns out.
