martimus919
Everything posted by martimus919
  1. Well it's been some time since I've updated this. I have since given up on trying to get the original engine working after finding out the EGR was plugged and once hot would basically force the car to fall on it's face. Furthermore, I also found out that the head gaskets were puking coolant. So, instead of put more money and a lot more time into that engine, I decided to just get ride of it and do a EJ swap. I had the parts, I had the wiring, so why not. So out with this thing New beginnings. Short block is a EJ25D from an 1st gen Outback, heads are EJ22t using the 2.5D head gasket. Should make for some fun. I don't think the 2" spacers I bought from Anderson Fab did quite the job fixing my camber so I decided to drop the subframe and create more problems for myself farther down the road. New engine set in place. Now to start wiring. When I thought I was all done with the wiring. To try and make this a little easier then when I swapped my Brat I got a radiator and had a shop modify the inlet and outlet to allow the same hose sizes as the EJ engines use as well as put on an extra nipple for the turbos breather tank (which I forgot to specify which side to put it on and so now it goes to the cold side instead of the hot side where it belongs). Went down to a local hose and fitting shop and made a new power steering line so I could use the stock lines to the rack to try to make this as seamless and possible. I have since driven the car a few times around the neighborhoods and have found that I have leaky head gaskets again. This time it's oil and appears to be coming from the front of the engine for some reason. I'm a little confused by this but I am already thinking I might rebuild one of my semi-closed 2.5 turbo blocks and use another set of 2.2 turbo heads I have and building another long block and paying a little extra attention to head gaskets this time.
  2. I am well aware of the tricks to get a vehicle to pass emissions, I actually have 2 emission testing licences. But the problem is not it blowing within the limits, it's being able to get through the test without cutting out.
  3. I think I've about had it with the stock engine. I keep messing with things to get it to pass emissions and it works for a while until I go to take the test. For some reason once I get it warmed up it starts to fall on its face while driving. It won't hold 2500 RPM, it will cut out and rise back up while holding the throttle steady. It does hold 2500 RPM once I disconnect the throttle possition connector. I've tried 2 different good TPS sensors, played with timing and idle, changed plugs, wires, and cap and rotor. I even changed the temp sensor for kicks. I'm tired of fighting this with the limited time I have, so I'm going to get things ready to put in one of my EJ22t engines from my Legacy and be done with the old EA.
  4. Unless he labeled them wrong I should have them on right. D=Drivers side P=Passenger side, arrows indicating to front of car. It is a little better but there is definitely still positive camber. I haven't aligned it yet, so I don't know the exact numbers. That's the only wheel I think they could be. I've never seen Peugeot steelies, but it's the only one that makes sense to me. I can tell you that they were real annoying to mount to the balancer.
  5. I've had to put the Turd on hold for a bit. Finding time to work on it has been hard. But I've got all the codes eliminated and It's driving really well now. While testing the speed of the car I forgot I don't have the hood latched down and that they tend to come up at speed. I realized this was not the first time this had happened since there really was no new damage to the hood. Just need to put the front back together and install the hood release cable. Also the front camber problem was not resolved with the front lift spacers I got from Anderson Design. Any one else had that problem?
  6. I drove the car around last week and pulled a couple of codes, (Codes: 31, 33, 35, 42). What concerns me the most now is the Throttle Position Sensor (TPS) which I can concur theres are issues, it does not drive well any more... like at all. In Reno there was only 1 Loyale Turbo in the junk yards, so I went to pick up the TPS and they decided to crush the car early. I was able to jump the fence and go see if the sensor was still intact, but of course it wasn't. So I'm now in desperate need to find a TPS for a reasonable price. I could also use a Canister Purge Solenoid Valve if any one has one or can get of these items I would really appreciate it.
  7. A lot happier with how the wheels look now, I'm painting two more today. But yeah, I did some organizing last night and forgot to double check to see if the pics still showed up from photobucket.
  8. Got the replacement turbo in, axle boots replaced, and patched a tire. Figured while the tire was off I'd paint the wheel real quick so it doesn't look so much like a collage of vomit coloring. For some reason I kept the white walls out, maybe the paint will flake off... Hopefully. I also got front spacers from Anderson Design & Fab so I can fix my camber:
  9. Yeah paint is one of the last things on my list, I obviously didn't buy it cause of the sweet looker that it is haha. But if I ever do I'm probably just going to buy a can of tan or army green Plasti-Dip and just spray it with a gun real quick. I pulled out the turbo yesterday and... well it's definitely bad: Put it side by side to one of my VF11 turbos and it seems almost identical. I might play with changing out the exhaust housing on my replacement turbo so I can run one of my catted downpipes from the Legacy turbo or WRX.
  10. They are 225/70-14. Should be a good size until I do a bigger lift and tires.
  11. Tire's are pretty decent, the front have a lot of camber wear but it was sitting for a few years. I am rather surprised how good of condition they're still in though. But they did spray paint the tires... and bumpers... and, well yeah. I think they gave a rattle can to a kid and said to have fun. Got it running this morning, pretty sure I can hear the turbo screaming from not having oil running through it for a while. I'll get a new one in after next weekend when we go back home where I've got another factory turbo for it. The only turbos I have here are a VF11 and TD04 and I don't really want to try putting those in yet.
  12. I guess my wife feels bad that we had to leave the Brat back in Utah when we moved to Reno or something because she let me buy this: This is some of the handy work from the previous owner. Bypassing the turbo by disconnecting the oil and coolant and of course, the waste gate vacuum line, but definitely NOT the exhaust. Should be some fun playing with this until I get the Brat back. Need to fix the lift, did a straight spacer lift with no camber correction. Car doesn't start still. Got a new fuel pump and have to fix timing that was really changed to somehow assist the turbo being, "Bypassed". A few cosmetics like lights but all in all pretty good shape.
  13. The 91 Legacy Turbo was the only one equipped with a LSD from the factory unfortunately.
  14. Soooo I feel like a complete idiot. So I charged the battery that never gets used, or charged and now I have head lights! Drove it to my new place to store some more.
  15. So I had this donor legacy and so I decided to swap some parts over. The ECU did the trick, purs like a kitten now. But I have no head lights now and when I turn on the head lights with the car off key out, I hear the fuel pump turn on... Sweet! So whenever I have time to I have been trying to cut open the wiring to see where they're fused.
  16. Yes I do, I've been wondering if the o2 sensors bad though I haven't had the time to check it since I thought of it.
  17. Ok I finally got back to working on the Brat after parking it last summer. I have it really close to passing emissions but the C.O. fluctuates constantly from 0.06-5.00% everything else is great, help please. Also anybody have a P/S rack? The one I got from the junk yard turned out to be bad. I'm about ready to just get one from rockauto.com But I need to get him done soon. He's going to be my commuter so I don't eat through tires on the wife's car.
  18. Ya numbchux I just read over that spfi conversion again about the gauge cluster. I guess i just assumed they meant VSS... I'm retarded. So I'm just going to take a wild stab at this and assume I take the Engine tachometer output wire and plug that into the yellow wire instead. Also any tips/ideas on how to put in some RS seats, the Corbeau seat was extremely easy considering i just mounted it to the stock seat rails.
  19. So I got it going now, but I don't have the tach working I believe it's wired correctly. I ran the VSS wire to the tach connector then grounded the other end, nothing.
  20. Got that setup, easy enough. I was able to drive the brat back and forth in the garage with just the rear axles:grin: Now the car won't idle any more, I have not adjusted the TPS or do I have the oxygen sensor set up yet or the exhaust built. Just wondering if there's any other suggestions for what to do.
  21. Are we talking about using an aftermarket switch? Cause I have the factory swtich from the center console and it has 5 wires, are the other 2 for lights?
  22. Yo'j your last post got me thinking, fortunately I saw it right before the site went down. The wire I had going into the ignition switch was in the wrong location so when I turn to the start position it wouldn't have any power, 2 second fix YAY!! So now the brat runs just doesn't move. I'm having my XT6 axles shortened this week, but in the mean time I want to get the can moving. So I'm just going to use the outside ends of the axles to hold the hubs together and wire in the locking center diff on the RX trans. Problem is I'm not sure what I'm doing I've got the solenoids for the vacuum lines I'm just not certain as to where to hook them up to, (mainly wiring) I could use any help here. I'm trying to get this thing driving by the weekend... or next:grin:
  23. Should I run a bigger wire to the ECU to fix it?
