Everything posted by Murthius
1996 OBW caliper guide pin
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh! That explains it thank's so much. I just ordered the bracket and pin from Autozone's website since the cost difference isnt very much after the shipping is added, and I figure if I have a problem I can just take it right back to the store instead of having to worry about shipping back to rockauto. But now im confident it should work fine. All I need to do is get the 17mm bolts that hold the bracket on, since mine are rusted and stripped lol.
So a while back I posted about how i stripped the threads in my caliper bracket, and the guide pin was not able to stay in. I'm about to get a new bracket and guide pin since the pin fell out somewhere, and i noticed something interesting: I have 15 inch wheels, however the guide pin that I know my caliper uses is listed as being for 14 inch wheels on rockauto.com, and the one they have for 15 inch wheels is completely different! Here is the one that matches the one I had[Edit: it's the gold one.]: http://www.rockauto.com/getimage/getimage.php?imagekey=3054534&imageurl=http%3A//www.rockauto.com/info/Carlson/14075.jpg Here is the one they say is for 15inch: http://www.rockauto.com/getimage/getimage.php?imagekey=307720&imageurl=http%3A//www.rockauto.com/info/Raybestos/H15165-1.jpg I also noticed that the ones that look different from mine both have "Outback" in the description while the one that looks like mine doesn't. Were the brakes on the outback different from other legacy's and maybe someone put normal legacy calipers on at some point? Should I just get the one that I know fits? Thanks for any help!
96 OBW EJ25 resonator
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for the suggestion, I have the muffler and pipe on their way and found an exhaust shop that's going to install them for me so they can do some custom work to hook it to the cat. Main problem was most places won't use my parts and want to charge 4x the cost just for the parts, let alone labor. So lets see where this goes!
So I was driving home from the store and heard something dragging, pulled over and turns out my mid-pipe was dragging. pulled it off and shopping around for options, but it looks like the cat isn't a OE/direct fit so a new resonator won't just bolt onto it. I was wondering if there are any options other than welding to attach it, or should I just buy a new cat for $140 from Rockauto along with a direct fit resonator so I can just bolt it all together and not have to do anything to make it fit. Even with getting the cat and pipe and doing it myself, it's cheaper than just having any of the shops I called do it.
96 OBW progress. EGR, 02 codes, and frayed ECU wire?
So I'm continuing work on the 96 OBW 2.5 4EAT. Got my 12v plug wired up and it works great, got some vice grips and new bolts for my little caliper problem, and then I'll be moving onto my CEL codes. I have: P0400: Exhaust Gas Recirculation Flow P0135: O2 Sensor Heater Circuit (Bank 1 Sensor 1) P0141: O2 Sensor Heater Circuit (Bank 1 Sensor 2) EGR system itself seems to be fine, the hoses and valve are undamaged and hold vacuum, but i've heard the 02 sensors may effect how the ECU determines if the EGR system is working properly. So whatever is causing the P0135 and P0141 could potentially be setting off the P0400? I'll be getting in there tomorrow to check for problems with the wiring from the 02 sensors, but other than that and the sensors themselves needing replacement, is there anything else I should be looking for? Wondering about the likelihood that both sensors are bad. Also (and probably totally unrelated) I noticed a frayed wire coming from my ECU. Looking at the pinout it seems to be the camshaft position sensor. Wondering what that would effect. Ah, and my headlight issue. I'm about to search for some threads now about it, but i've noticed the wires that go to the headlights were cut and about 3 inches of black wire (so who knows if they are even on the right contacts) spliced to them. Nothing leads anywhere it shouldn't, so maybe it was a headlight mod that was removed after and re-wired incorrectly? Basically I can flash the high beams, but they won't stay on. Also, one light or the other will randomly turn off (tapping on the light or slamming the hood turns it back on) and sometimes the high beam indicator light comes on when low beams are on. O.o Also I've found what appears to be a 3 prong power outlet sticking out from under where the battery sits. I'm almost scared to touch anything. Haha. But after all that, some new side mirrors and some body work, it should be good to go. Not including the re-seal that the engine clearly needs, as it seams to be slowly leaking from... well everywhere it seams. Transmission pan has a slow leak as well but that's easy.
Caliper - stripped threads
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh nice thanks, didn't realize that. Well I went for a drive to the store and clearly heard that bolt fall out and roll on the ground on the way there hehe. I pulled over to look for it but couldn't find it so I'll be hitting an auto parts store to get a new pin as you suggested. Thanks for the help you guys I really thought I was screwed for a bit there, and was planning on getting a whole new caliper. /facepalm
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh wait I just read that again and I think we are talking about different bolts. The threads I stripped are the ones that the long bolt goes into which allows you to swing the caliper up to change the pads, not the ones that hold the bracket on. Still ok to drive? Sorry for the confusion.
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk thanks, that at least makes me feel better about driving it haha.
So I changed out my pads today and when I was putting the bolt that goes into the bottom that allows you to swing it up, I tightened it a bit too much, and took out about half the threads from the inside of the caliper. put it as tight as I can by hand (no tools at all) but any farther and it just goes right back around. I figure if nothing else the wheel itself would keep the caliper from sliding up, and the bolt is kinda in there too. Is it safe(ish) to drive it like this? At least until I can get it repaired? At low speeds maybe?
12v dash outlet in 96 Legacy Outback
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh sweet thanks everyone. Gonna go out and wire it up tonight feeling pretty safe that I'll be doing it right after the replies and someone telling me black is always ground so im sure ill be fine sticking green in the middle and black on the outside especially if thats how its supposed to be for 95-99. Now I just need to figure out how im going to plug that in after the radio is in the way haha! Figure ill have to squeeze my hand in the small opening just next to the lighter.
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso black to the center and green to the side?
96 Legacy Outback EGR cleaning
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh thanks. Hopefully the light stays off after I do that and clear the code, I've seen a lot of posts about the light coming back on after a few days even after getting a new valve and cleaning out every part involved lol hope that doesnt happen to me!
So I have my new outback and one of the things I was going to tackle was hooking the 12v outlet back up, it appears it was pulled out when the previous owner took their radio out. I looked up how to hook it up (black wire to the center pole white on the side) but when I went in to do it, I was a bit confused at what I saw for wires and am hoping someone can help me out! Basically it looks like there are 4 wires (2 black, 1 white, 1 green) the 4 go into a small mess of electrical tape and at the other end of that is a black and green wire that have female connectors that will go onto the outlet, and a black and white wire that seem to have male connectors. At first I assumed the black should go to the center still and the green on the side in place of where the white would be? But then I decided to look it up before I mess anything up, but I can't find anything.
So I just got a 96 OBW 2.5L Automatic and it's throwing a few codes, O2 sensors (P0135, P0141), knock sensor (P0325), and blocked EGR passage (P0400). I've read alot of threads about the P0400 code and almost dread the run around that may be associated with trying to fix the issue, but my engines performing quite poor so I am going to try everything to get it running better. I Haven't tried anything yet, just getting prepared and I was wondering, if it comes to cleaning out the vac lines, is it ok to just spray carb cleaner down the tubes and let the engine spit the gunk out the exhaust or will that make things worse? Or option 3, is that not even how it would work and I'm talking out of the wrong hole? Haha. Theres a host of other problems I need to tackle but so far I think this will be the most confusing, so if anyone has any info, it would be greatly appreciated!
Key stuck in ignition!
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a 93 Impreza automatic. Sorry, I always seem to forget to give enough info lol. I've tried all the basic stuff, but I have noticed that when I press the button on the shifter it doesn't make that click sound it usually does and I understand thats the sound of the key being released.
This might be easy to fix but I've tried everything and I'm kind of a newb. Went for a ride today and when I got to my destination my key would not turn all the way back to the lock position, and will not come out. it goes forward and starts the car just fine, just won't go all the way to lock! Any ideas?
Fan eating belt?
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh ok, thanks. Oh it's a 93 Impreza btw.
Fan eating belt?
So here's an interesting story; For a few days over this past winter when I would turn the air on (vent, heat, anything) I would hear what sounded like the fan blades hitting something. The higher I put the fan control knob, the faster/louder the sound would get, and then I noticed a rubber smell as well as tiny black pieces being blown onto the dash from the vents! Of course I turned the fan off when this would happen, and that didn't make for very fun winder driving. (no heat or defrost in New England, bleh!) then one day, the sound, smell, and small black bits stopped, and it hasn't happened since! What the heck could that have been! I thought maybe the serpentine belt may have slipped off for a bit somehow, but it looks fine to me and isn't loose and doesn't squeal. Seems to be fine now but, I was just sitting up at 5:30 am and that just popped into my head so I figured I'd share it, and see if anyone else knows about that. Maybe just a freak occurrence?
Part interchangeability
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow yeah I totally left out some important info huh lol. Thanks for the tips and link, my Impreza is an EJ18 AWD Auto, not entirely sure about the Legacy's exact specs but im pretty sure its an auto fwd, could be wrong about that one though not sure. I juse had a transmission and rear diff fiasco last year so the ones in her now are pretty solid so I shouldn't need any of that (I hope, gulp) but it's nice to know the suspension should be interchangeable since that is one of the things my car needs, you can really feel the road in her lol. And yeah, the rims are corroded, I got new all season tires last year and they did the cleaning/sealing then, and they started to leack again recently and theres one thats pretty bad, the other three not so much. They said unless I get new ones, I'd have to get them cleaned/sealed every year so, I got lucky with this legacy falling into my lap lol. At the very least, I'll grab the rims and hopefully the struts if they are in good shape. Other than that hopefully pick some little things off it like thesun visors if they fit =P I've had the passenger visor on the drivers side for years with nothing for the passenger! hehe. Dash light bulbs too, the last 2 behind the climate control dials went a few months ago, making it impossible to see them in the dark and the auto stores dont quite have the right ones, and the suby dealer here said they could look for me but it would be a shot in the dark since they don't stock them.
I know someone who just had their Legacy totaled (bent frame) and offered me any parts off her. Going to take the wheels since mine need to be sealed every so often to stop leakage, and look up other specific parts I'm going to need also but I was wondering if anyone knew of any resources for finding what other parts of a my90 Legacy are usable on my my93 Impreza. Thanks.
93 Impreza Climate Control Back-lights
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAH! Sorry it looks like this is a total redundant post! I saw previous ones in the related posts after I posted, guess I should pay more attention lol. [EDIT] Wait, maybe I didn't find what I needed lol looks like those are for newer Imprezas and Legacys. I need to know which bulb works for 1993 Impreza climate control dials Thanks to anyone that can help!
the last one finally blew recently, and Advance can't figure out which bulb it is lol. They have a few that look the same but are slightly different in size, but their computer tells them they don't have what I need and to refer me to Subaru directly. Anyone know if/where I can find the bulbs? They are the 3 tiny bulbs behind the Fan/Temp/Mode control dials. Thanks.
Restoring tail lights
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHaha yeah I guess I really should get some new ones then eventually. Might try smoothing it out and spraying some of that see-through red staind glass paint on it, then hitting it with clear acrylic so it at least doesn't look as bad as it does now lol. Now the next decision will be, stock, or after market tails next? hmm...
So back when I first got my Impreza my nephew and I went crazy and melted the paint off with paint thinner to repaint it, and some got on the tail lights and appears to have etched them and bleached some of the color off. Any ideas how to make them look less like crap? lol
4EAT Compatibility question.
Murthius replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you for that link! Found an exact match, with a bit under 100k miles for 300 bucks not far from here, it should be on its way wednsday! I just hope nothing else pops up after I get her back on the road lol.
