David C
Everything posted by David C
  1. Hi, What parts should be replaced when replacing timing belts? thank you
  2. Hi I am looking for timing belt tensioners cam and crank seals oil pump seal. Who's the best on line seller of subaru parts? thanks
  3. I pulled the water pump, seems the person before my got in a fight with the metal pipe that comes out of the the water pump. Pump got beat up bad. I found a piece of 25mm rubber hose stuffed in as an O-ring. I am just wondering what other things I should look at before putting it back together????
  4. Thanks, do I need to pull the timing belts to remove the water pump? If so I mite as well get the belts on order. My local auto parts dosen't stock much subaru stuff here in the land of BUICK.
  5. I may have screwed up, what do you think? I removed the fan clutch and now the water pump is leaking. Did I do this? I removed the fan clutch by tapping on the shaft, back and forth with a wood block. I installed small 6mm bolts to hold the pully on. checked everything and now I have water dripping from behind one of the timing belt covers right under the waterpump. any ideas
  6. I removed the four small nuts but the fan clutch still seams like it is on there pretty tight. Do I need a puller to remove it. Thanks
  7. Can anyone tell me where I can find the parts to convert from drums to disks on the rear of my 88 4x2 wagon? thanks
  8. Do you know the part no. or type of NGK plug to run?
  9. What are some of the, most bang for the buck ,ways to increase the power output of an ea82? Thanks
  10. I want one, how do I get one?
  11. Are there any large sellers of used Subaru parts? The junk yards in my area are out of old subaru's and finding an xt fan clutch is not going to be easy here in Florida.
  12. From radiator barn
  13. Just put a new radiator in my 88 wagon and now the fan don't fit. I was warned this mite happen with the two row radiator but wanted to try. Are there any options for clutch mounted fans or does this have to go. thanks
  14. David C replied to David C's topic in Off Road
    Thanks for the info! I just bought my 6th subaru, an 88 DL wagon. It is the old lady, only to church on sunday, show room perfect 800 buck deal. Could not pass it up. It will be my wife's car. She always loved the ea81 and 82 wagons we have owned and is sick of her Merced%&$$$s.
  15. David C replied to David C's topic in Off Road
  16. David C posted a topic in Off Road
    Is there a lift kit for the DL GL wagons.
  17. Is there a way to tell which one you have?
  18. Hi, I have an 88 DL wagon that needs a new radiator. Can anyone tell me the difference between a one row ,and two row. There are different radiator options and I am not sure which one I need. Thanks
