Everything posted by sprintman
Octane
sprintman replied to CROSSTBOLT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe dont have 87 octane. I think 92 is our lowest. 9 cents a litre difference between them. Oh and never buy fuel with Ethanol in it. Low mileage and other problems too numerous to list
Octane
sprintman replied to CROSSTBOLT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use 98 octane and nothing else. It actually works out cheaper with the additional mileage.
2004 Subaru Forester gas mileage issue
sprintman replied to ksarkisian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere a few easy ways to improve this 1) Use quality fuel (I use 98 RON) with a UCL of some kind and a fuel burn catalyst (I use FPC) 2) Put Nitrogen in the tyres and run at say 36 psi 3) Get a proper wheel alignment from a specialist, not a 'tyre dealer' 4) Replace the crap OEM oils in trans, diff and engine with a lower CF oil (I use RL and worth say 6% improvement) 5) Use a/c only when necessary
No More Oil Leaks!!!!!!!!!!!!!!!!!!!!!!!!
sprintman replied to Oscar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTheres a much easier way. Get a bottle of Auto-Rx and follow the instructions and if the seals arn't torn or damaged most leaks go away. Theres an RX test underway by a BITOG member Aaron and pictures etc are available at http://www.rms13.com. Also checkout what id did for his compression in 1500 miles!
Regularly crunching reverse
sprintman replied to csomole's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgbhrps I Redlined my OB trans, diff and p/s. A whole new ballgame now particularly when cold.
sprintman replied to csomole's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe TSB is on this forum somewhere. IT decribes your symptoms exactly and has the list of replacement parts
sprintman replied to csomole's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtHERES A tsb FOR DODGY CLUTCH SLAVE CYLInder and related parts. Dealer just did mine and crunching a thing of the past.
Advice for a potential new Owner
sprintman replied to andyhaussler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had clutch/slave cylinder done free in my 2000 OB (real Japanese one) and vehicle is now perfect. Subaru in Australia win the quality survey every year now. Can't beat these guys for service and value for money
Sticking accelerator 00 Outback 2.5
sprintman replied to sprintman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo I think its computer or something. Tapping accelerator makes no difference. Fine afte say 60 seconds running.
I have the symptoms of a sticking accelerator when cold. Don't think it's actually sticking just same symptoms. Change gear at say 3,000RPM and it hangs there or rev's higher even. OK when warmed up a bit. High quality 98 octane fuel, recently Techron in fuel so injectors are clean, 75,000kms ony on odo. Any ideas?
Can a 2.5 OB be converted to 2.2?
sprintman replied to soldierrsb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the 2.5 engines made or assembled in the US or imported whole from Japan?
Clutch judder...cable tired??
sprintman replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFind a new dealer! Mine did clutch and slave cylinder TSB 6mths after warranty expired for free.
High REV before shifting
sprintman replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck http://www.auto-rx.net. autotrans get dirty and gummed up over time. Cheap solution but mandatory to do a full flush with something like T-Tec that are everywhere in the US I'm told.
Clutch problems
Theres a TSB for this. New slave cylinder and hose/pipe I believe. Had mine done a week ago and fixed same problem as you describe. Got a new style clutch a few weeks earlier too so there are two seperate problems. Sube dealer did both for free even out of warranty. That's why I have a Sube!!
Larger Quality Oil Filter for 2.5
sprintman replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood post commuter. There are filter flow/pressure drop figures available on BITOG forum. I use PureONE on my other vehicle (Mazda turbo) but I don't think it's a great flowing filter. Can't get Mobil 1 filters here but thats what I'd use if I could. K&N have a good oil filter, can't say the same about their air filter. Users always have high Si numbers (dirt) in oil analysis.
To Synthetic or not to synthetic that is the question
Turbo bearings like a syn (group IV or V, not III) to prevent coking. Get some miles on it with dino before changing. And most importantly use a 3oz maintenance dose of Auto-Rx with the syn. I can't disclose the reasons yet as under secrecy obligation so you'll have to trust me on this one.
sprintman replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTks i'll look into it...s
Oil question
sprintman replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDelvac 1 is an excellent shear stable oil many regard as Mobil's finest product. Doug Hillary who posts on BITOG from Airlie Beach Qld Australia has Delvac 1 in his Outback , 12 semi's (trucks), and his Porsche. I ran it in my Outback from day of purchase but currently doing Auto-Rx clean and dino a better choice. D1 is CI-4/SL rated, oils don't come much better than this IMO.
Oil question
sprintman replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have OEM from Japan but would definitely use the Amsoil but at a much bigger 'ouch factor' than ever here in Oz. I'm interested in what oils other Subaroo owners use??
Oil question
sprintman replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot so much the Pennzoil (an excellent dino now by the way) but the Fram filter. Cardboard end caps and shoddy anti-drainback valves you don't need if you care for your Sube. And yes M1 5/10W30 is a 'thin' 30W (10.0 cSt @100C). Interesting that the 0W30 is slighty higher in viscosity at 10.3 cSt @100C
Oil question
sprintman replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats Transmission medic site but same product. See http://www.auto-rx.com for engine site (there are three in total)
Oil question
sprintman replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can change to syn and back to dino as often as you like. That you can't is one of the 10 main fallacies about syn which just won't die off for some reason. Don't change without doing an Auto-Rx clean to remove contaminants in order to get the max benefit of the M1 or whatever. Rember M1 XW30 is formulated at the low end of the 30W range and I'd be looking for something with a little higher viscosity for summer use IMO.
sprintman replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBigger than the piddly OEM one. It's a joke!!
Redline Transmission Oil
sprintman replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemember it's two different oils for trans and diff. Do not use 75W90NS in the diff.
sprintman replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgreed
