Everything posted by LGTSings4u2@aol.com
We replaced the bearing...pressed it out and then oput it back in...but the whole steering wheel moves pretty freely...so i think it's the whole assembly that needs replacing...is steering knuckle the proper part name? I'm not stupid...just refer to it as the hub and maybe that's why I'm not finding it....? Thanks a lot, Angel
Montana, Our friend did the fuel pump and the brakes. We replaced the fuel pump with a Master pump from Auto Zone...but he put it on for us...we have done our own brakes before on another car and have not experienced the sound we are now...we're thinking of having a look at them ourselves...we do not know how to bleed the brakes and we are wondering if that could be a problem... Angel
Hey Guys, We just replaced our fuel pump and the thing is making an odd noise. It is pumping fuel but making alot of noise. Any help or direction would be welcomed as we are doing all of our own repairs now...One more question: We replaced the rotors and brake pads and now it sounds like scraping even when the brakes are not applied...any ideas? Thanks for the help, Angel
Nipper, Thank you...can't quite get what you mean though...we definitely do not hear the click anymore but I searched through the posts you hyperlinked for me and I'm not finding a solution...except to take apart the gear shifter assembly around it...it works when we press the button at the base...could something have come apart under the gear shift assembly? Angel
Hello, My name is Angel. My husband Phil and I own a 93 Subaru Legacy L sedan. We bought it used about 7 years ago and we are having a bit of difficulty with the car now. It seems that whenever we try to go 60 or above the car struggles. It seems as though the engine is pulling back.The whole car shakes. We changed the air filter and now it seems worse. Also, the air blower motor works a little bit only, Phil took it off and cleaned it and it seemed to respond well but after about a week it is back to working only sporadically and then very little air at all. Any suggestions or ideas would be well appreciated. Thank you, Angel Terry
