Everything posted by bluebonnet81
The Bureau investigator said that there was a smell of fuel on the dipstick in the fresh oil, and if that was a pre-existing contamination issue that it could break down the lubrication properties of the oil, and could have been a contributing factor. He could not gather any conclusive evidence, so the complaint is recorded, but closed. If anyone is interested in making an offer, I am likely to let the car go. I don't really have a good place to work on the car for an extended period of time, and it will probably just piss my wife off. I will post it in the classifieds section pretty soon, but feel free to inquire.
bluebonnet81 replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, you can call it an antique, and there is some sentimental value. You are probably right about the value. I might pay someone to do the teardown inspection, and then rebuild it myself, or sell it as is. I am driving my truck right now, so the situation isn't dire. I just want to find out what happened so that there is a fair resolution. I just posted a photo of the car.
What I submitted to the Bureau of Automotive Repair: Mechanic reports engine is seized after his repairs : Since Tuesday 7/9/13 my vehicle (Subaru GL 1981 with approx 84,000 miles) has been in the care of So Cal Carburetors in El Cajon, CA. I drove my car 21 miles from my house in Mira Mesa to the carburetor specialists shop in El Cajon with no difficulty and left it at the shop. This vehicle is a reliable daily driver. The reason I delivered my car here is because the car would not idle without applying a little gas pedal, and smog was due on 7/16/13. I requested that the car be inspected for diagnosis/repair and to be smog tested. Other than the idle difficulty, the car drove excellently. This shop performed repair maintenance and smog including carburetor rebuild less than two years ago for the previous smog period. When I called the shop and spoke to Shawn, he told me that the idle problem is because of a blockage in the carburetor, so the carburetor needs to be rebuilt. He also said that the engine oil had recently been changed, it is probably contaminated with fuel because of the carburetor problem, so the oil and spark plugs need to be changed. I consented, so Shawn's mechanic reportedly rebuilt the carburetor, and changed the oil and spark plugs. He said that he fixed the idle problem. NEW problems occurred... When Shawn called me he said that the car is not driving/accelerating properly after his repair because there is a intake manifold leak so the gaskets need to be replaced. I visited his shop, and paid him in full for the work that he had performed up to that point. Reluctantly I consented to his further repair advise even though this driving/accelerating problem did not exist before he changed the carburetor. He said that part of the gasket replacement is removing all of the engine coolant, and replacing it. More new problems occur... After Shawn's recommended repair of changing the intake manifold gaskets was complete, he told me that he believe's that there is a problem with his newly installed carburetor and that he will not get replacement parts until several days later on Tuesday 7/16/13. He said that he would call me on Tuesday. On Tuesday morning I called the repair shop and asked if the carburetor was repaired and if the smog would be completed. It was at this time that Shawn told me that while test driving the vehicle the engine died while he was driving it, and that it had SEIZED. He said that they tried to manually turn the engine, but that it was stuck. I have not seen the vehicle since before the intake manifold gasket replacement, but am supposed to go to his shop today. I do not intend to pay this company to perform any more repairs. I appreciate any advise on how to proceed from this point. Thank you.
I brought it in because it needed smog and it would not idle without a little gas pedal since a few days before. I specifically told him this and his initial diagnosis was that the carb needed to be rebuilt, and to pass smog it needed an oil change because the oil was probably contaminated with fuel. He also changed the plugs. It was after that the car was able to idle, but the new problem presented itself that it would hardly accelerate. After that he said that he needed to change the intake man gaskets. Then he said that he thinks there was a problem with his carb rebuild and he would call me in a few days when he got some parts in. Well, a few days came around and he reported that the engine seized. It ran pretty well since he rebuilt the carb a year and a half before. No other problems. Fluids were maintained frequently and well. no leaks.
Thanks, I will do that. I am going to look at the car in a couple hours. He said that he was driving it when it died. After that he said that they could not get it to turn manually from the crank. I do not know if they took the plugs out or not. I am going to look at the car in a couple hours. I will update after that. Thanks for the info on the water port.
I believe from what I have read is that there is no timing belt, but it is gear driven. The mechanic also said that he tried to manually turn the engine from the crank, and that it was stuck. Maybe the spark plug hole. I am disappointed because this EA81 only has about 84,000 miles on it. As far as I know he did not touch the valves.
I would like to ask for some advise. I took my GL to the carb shop because it was time for CA smog, and there was a an idle issue, but the car drove strong. Last Tuesday evening I drove the car twenty miles to the shop with no problems, dropped it off, and slid the key under the door. The next day the mechanic told me that they changed the oil and spark plugs, and rebuilt and installed the carb. He said the car idles ok, but now the car would not drive well because of an intake manifold leak. I told him that it must be the carburetor because it drove well before and the carburetor is the only thing that has changed. Regardless, I told him he could change the manifold gaskets. Now the story gets interesting. After the manifold and carb were reinstalled, he said that he took it for a test drive and that the engine stopped, and SEIZED! The way I see it is that either the carburetor was originally fine and that the manifold gaskets needed to be replaced in the first place, and that the carburetor was fine. Based on this story is it plausible and probable that something got dropped into the the engine causing the seize? Any other possibilities or recommendations?
Where does this wire go?
bluebonnet81 replied to bluebonnet81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have eliminated the wire. It is from the oil pressure sender that is no longer installed. The problem still exists though. Not sure why it won't idle all of the sudden. -
It comes out of the group behind the air cleaner and routes underneath it forward. It has a long finger like bracket that looks like its bolt fell out. The wire is yellow/black stripe with the end that slides onto a prong. -
It is an 81 GL -
I was changing the hose for the windshield wiper fluid, and when I finished the car wouldn't idle. I noticed a wire hanging near the belts so I am assuming that it fell off somewhere but I don't k ow where. All vacuum hoses are intact. Pic coming up...
Thanks everyone, I found a new one online and installed it yesterday. The first time I took it off it broke off, but I was still able to carefully pry it off with a screw driver. I attempted to repair and re-install which was a bad idea because the second time I tried to remove it, it broke off flush with mating surface. To get that out I took a bolt with a nut on it and put the head of the bolt inside and under the lip of the broken off piece that was still stuck in the bore. I then used the nut that was on the end of the bolt to pry forward with a pair of long diagonal cutters. When you re-install the new one, I recommend inserting it without the o-ring in order to get the drive gear shaft lined up (no resistance), then put the o-rings and gasket on and install.
