turn signal and cluster wtf
Thanks peoples. I appreciate the feedback
Yes its both left and right, kills the gauges unless the hazard switch is pushed. If you push the hazard switch then the turn signal switch the dash is ok. The turn signals never work regardless
Thanks. So I gotta track down wiring issues fml. Why couldn't it be a simple problem (anything but wiring) lol. And yes it is the cluster lights AND gauges that go out.
Oh damn, sounds like............fun?
i have a 2001 outback if you turn the turn signal on it will take out the dash lights and gauges.after a little time they come back on. the four ways work and if you unplug them you have no turn signals but the gauges work. i tried a new turn signal switch and ignition switch. there was no change please help thank you.
How easy is it to bust into an EA82?
I have an ea81 but I too can start it with just about anything, and can pull the key out while running
Bout to get started
this is what im starting with, made the front push bar and fiberglassed and altered the stereo surround(which needs finished)
Bout to get started
ok so trying to figure out how to upload pics......
Bout to get started
also...... eventually wouldnt mind upgrading the engine just not 100% what i wanna go with yet, havent heard of any problems with the 81 besides lack of power but maybe turbo would help??? biggest job i think will be the body work but maybe not. ill keep the build progress posted.
Bout to get started
Well got my new axle and wheel studs in today, waiting on my new drums/rotors to get hear. Won't be long now and I'll start lifting and bodywork on my 83 wagon. Got some cool looking 6 bolt steelies from a Isuzu rodeo to go with, yay:banana:
drum and rotor size?
If its non vented can I put vented on it?
went to local parts cons for new rotors and drums for my 83 wagon, they couldnt figure out which ones i needed cause i guess there are options in date of manufactur???? or some crap. will any drum/rotor for an 83 work or whats the difference:-\
Latest Brat score! 1982 DL Brat
Nice brat. Not to take focus off of your new ride but u said the bull bar has notches for the chrome bar, what is the chrome bar for? Mine is toast and I'm not gonna replace it if it's just cosmetic. Anyways nice car.......truck....... Ya I want one lol
To add to a previous Q about 4wd indicators [solved]
I just loosened the two bolts that hold the shifter assembly to the tunnel and tapped everything back (there is some adjustment) now my 4wd and 4wd low lights work
love at first scoob
Thanks! Ill check into that!
