Posts posted by 95legwagon
yes every time! lol
time for a 5 speed.... in about 2 weeks
well i already got the pedals and clutch cable.... i just need this old cable for now so i can keep my car on the road....when i get it up and running and i get the funds (shortly after its done) ill buy a new cable lol
also that kept my mind at ease knowing that i can switch that tranny to cable because i think GD told me 90-96 ( non turbo) was all cable and i bought a 97 so i was a lil worried cuz thats all i could find lol.
im gunna buy a new clutch kit and probably a used flywheel....just not sure if i wanna go used or new yet.... i need flywheel bolts though...any idea where to get those?
nah bought a 5 speed n rear diff today.... this will be fun
just put a deposit down for a 97 5 speed tranny and matching rear end off same car.
this will fit on my 95 legacy wagon right?
i know about everything else just making sure it'll bolt up and uses a cable clutch..... now how about rear dif ratio? its supposed to be a 3.90 but i thought the 95 4eat was that same ratio......
im prolly wrong but someone needs to clarify this for me
thanks guys.
p.s. trans n rear diff have 193k on them but i was actually able to test drive the car at the junkyard and it shifts like a dream LMAO got them both for $350.... not a bad deal considering i didnt hafta remove them myself!
so far my costs as far as 5 speed swap are this.
tranny and rear diff. $350
shifter linkage, shifter trim n boot, pedal assy. and trans crossmember $25
mt wagon driveshaft from 95 wagon. $75
still need clutch kit and flywheel and flywheel mounting bolts (cuz they are longer) anyone got some bolts for me? im doin this on a budget and ive done well so far for parts.
wiring should be fun.
**ALSO NEED WIRING DIAGRAM FOR (95 4EAT)** where the plug is in the engine bay..... like a pinout so i know which wires to splice into where and what not lol
thanks guys!!!!
my 4eat that had a leak......finally started pissin out fluid.....it was raining today so everywhere i went there was a rainbow trail behind me.....ill hafta deal with it for a few weeks..... but on the bright side..... 5 speed swap is in order....im tired of this tranny n workin on it.
that is all.
LOL
-jarrid
Which in result is going to give you a harsh ride, as there is very little sidewall to cushion the bumps.
Sounds like you need Outback struts!
this.... x 10 i need outback struts and forester springs..... so i can get the lift i wanted
not only that but because i need such a low profile tire also..... on tire rack i found that the only 205-40-16''s they have are like $120 n up a tire because they are all super high performance tires.....
thanks for the info guys but i cant find a set of tires for the rims that wont kill my wallet.... maybe i'll pick up the rims (if i confirm they fit) n wait on tires for a lil lol
i drive about 30 miles round trip each day to and from work all highway and my 95 lego never see's below 70..... sometimes if i feel like horsin around with someone ill get it up to 100.....but that only if i KNOW my oil level is ok and its not due for a change...... but 70 usually sometimes 75 if im in a hurry
ok so my work has a nice set on 16" rims that i want and they have a universal 5 lug bolt pattern...they look like they would fit..... question is.... would 225/60/16 fit on a stock 95 legacy wagon? if not what about a 225/40/16? im worried about the width of the tire hitting either on the spring perch or on the fender liner when the wheel is turned. anybody done this?
basically whats the widest tire i can put safely on my car?
thanks guys!
i have a 95 legacy wagon with 119000 miles and my tranny has been over full for over 5 months now....no problems. just a thought. you can find these trannys a dime a dozen.... buy a used one and replace it if its giving you a hard time..... i bet the band has broken leaving no more adjustment..... i honestly wouldnt know though.....
good luck!!!
-jarrid
so i understand what yall are sayin.....why cant he take the ej22 block and just bolt all the ej25 stuff on.....it may be a loss in compression due to using the 2.5 heads on the 2.2...... but arent the blocks and internals the same? wouldnt that be the cheapest and easiest (well....if he does it himself)
and idk how much he wanted for it..... he's also got a 94? svx for sale too lol
definitly not a 95 legacy.... mine doesnt look anything like that
take that off the list lol
from the look it definitly pre 95 im saying mid -late 80's
edit : maybe early 90's......
i happen to have the number of a guy who i was told is selling a 00 rs if you were interested...... its in milford connecticut though...... not sure where derby is though......
i got a 95 legacy wagon ej22e
mods: spectre cold air intake routed into the bumper through pass. fender.
and fart can exhaust (lol)
and i run synthetic
i get around 25 highway and 20 city.
im also hauling a constant 200lbs of stereo in the back......
i have also found that if i put in injector cleaner or dry gas i burn up the tank QUICK.....
i usually get in between 200-235 miles per tank ( 10 gallon tank)
just replaced fuel filter and did tune up with ngk platinums and some pep boys wires and noticed a couple more mpg ( as long as i dont have my foot buried in it )
also noticed when im pulling alot of current from my alternator it uses a good amount of gas im guessing from increased drag on the engine....i use every bit of the 85 amps it puts out..... i got 4 guage wiring off the alt to the front battery and to the 2 batteries in the hatch.
hope this long a** post helps
thanks appreciate it!!!
-jarrid
which brand fuel filter should i use? what do you guys use? what brand do i stay away from?
gunna replace mine tomarrow and do the tune up
it needs it hopefully the fuel filter is the culprit of a small but annoying problem......i let off the gas and itll bog down quick n then be fine but it does it every time i hit the gas then let off lol and when its cold it doesnt have alot of power till i get it rolling almost like its having a hard time.....
95 legacy wagon 119000 miles 4eat. all the fluids are good except the oil which is also getting changed 2marrow.
also i know to get ngk plugs but what about wires? what brand?
thanks guys
-jarrid
i dont mean to state the obvious but i didnt see where you posted about this being broke (see thumbnail) is this something you overlooked by any chance? i saw where the bolt came out but did you see this was snapped? that is definitly capable of causing some problems lol
-jarrid
oh and fl is front left meaning driver side. always remember left is driver side and right is pass. side. like you were looking from the driver seat.
thanks guys!!! reallllly appreciate this.
and i work at a salvage yard so its a lil cheaper for me
all this info really cleared things up for me.
and yes i am hell bent on doing it to this exact vehicle lol
thanks again!
-jarrid
95 legacy wagon ej22e.... doin a 5 speed swap come july....need to plan ahead lol
what do i need all in all for a list of parts? i have an idea but just wanting to know if i missed anything...... im getting the pedal assy. , tranny crossmember, and shifter /shift linkage tomarrow for $25
now i know that i need a short throw shifter to clear the console for the a/t shifter.....could someone shed a lil light on that also?
any tips tricks? also how hard is it to remove flexplate bolts? and what ft lbs do i torque to putting the flywheel on?
my list:
driveshaft for mt
misc. wiring done.
tranny and matching rear diff.
new clutch kit and flywheel and pressure plate.
hydro or cable? not sure..... shed some light?
clutch alignment tool... which one? spline count?
also are all awd front axle splines the same for all trannys that will fit my car?
what to stay away from at all costs? easy mistakes?
anyone have any of these parts thatll ship to ct for a reasonable price? doin this on a budget.
GD i bet you would be the one with the most info on this lol
any info is definitly appreciated!
thanks!
-jarrid
edit: also what years wrx tranny will fit? anything id have to get with it (special)?
sounds like an iac (idle air control valve). not opening when its cold to keep the engine rpms up to keep it running.
its a valve and its for cold weather starts and it goes bad on alot of vehicles....well not BAD but gets gummed up.....one can be had at a junkyard for cheap.... hope this helps!!!
-jarrid
i got my legacy with the tow hooks cut off already and the spring protectors installed already so mine was good to go!
thank you everyone!
definitly think i know which one it is now! like grossgary said w/b
ive read that other places too and i remember seeing that!
thanks again
16x flashing light is not a fun fix..... its a few hour job depending on how rusty bolts are lol
duty c solenoid most likely.
i did a write up on it.... will probably help you
question about trans swap
Posted
well it was a 97 legacy (non outback) so im guessing 2.2..... didnt really look at it to be honest..... it was @ the junkyard and was already running so i drove it around in the yard and all the gears work and shifts realllll smooth from 1-5 and reverse.....so i put a big yellow cone on it and they are removing it for me with the rear end for $350 total cost..... deal? i think so
having the flywheel resurfaced....is that usually expensive or not? doin this on a budget....im broke....get paid $300 every week and i pay all the bills for 2 people (me n my gf) so moneys kinda tight for this
