83pickle
Everything posted by 83pickle
EA81 doesn't start after running out of fuel
83pickle replied to 83pickle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Had it mentioned to me that I might not have enough compression and while trying to start it, the fuel washed away the oil lining the cylinder. I replaced the plugs out of principle and dropped a few ounces of oil down the cylinder. Still didn't get it to start though. I checked the gap specs and saw that it is 1mm to 1.1mm. The plugs I pulled out where at 1.28mm - 1.3mm. That is what I put the new ones unfortunately. I need to charge the battery back up so when that is done, I will set the right gap and try again. -
"stop lamp" light, no rear illumination
83pickle replied to tizzle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had somewhat of the same issue. Something caused the plastic housing to melt and the contacts sunk down too far. No one had replacement sockets so I just added some solder to the contact to raise them up out of the plastic and haven't had a problem since. I only bring that up due to everyone mentioning wattage. That could have been my issue. -
Fuses and links are good and look surprisingly new. Solenoid didn't test that well plus the secondary coil connection was corroded bad. Replaced it and still not starting. Checked the cap and rotor, those are still good. Took all freaking day to do the solenoid; 1 each way for a bus (no one is around for rides anymore), the positive post on the coil shears off while attempting to tighten, another 2 hours to replace it, rained, and still nothing. Tomorrow I will work my way to the spark plugs and check spark there. Really hard to do with one person. Will have to see if I can kidnap a buddy and tie him to the bumper and troubleshoot with me. Spark plugs are the last thing I can check, if they check good then I am out of ideas. -
Filter up font was good when I checked it as well as the fuel pump was delivering fuel properly. I will rule out the electrical before I get under the car again, smelled like gas for hours when I changed the filter. -
I am leaning towards that as well. It's too late tonight to mess with it as I have no garage. I want to get a checklist going to start with in the morning. Solenoid Distributer (cap and rotor was replaced same time as fuel filter) Spark at plugs Is there any sort of carb screw settings I should attempt? -
This is the second time I have encountered this. I run out of gas, pour a gallon or two in the tank, and kill the battery trying to get it to start. This isn't frequent mind you, last time this happened was middle of last year. I have recharged the battery for an round of trying to get it to start. I used some starter fluid in the carb but don't even get a chug attempting to start. Last time I was in this pickle, GD was out helping getting it started and discovered bad spark cables after I had replaced the fuel filter at the tank. Replaced then, bit of starter fluid and fired up with little coaxing. The cables could not be bad again, I checked. Since this is the second time, was sort of side affects of running out of gas causes? I really didn't even run out of gas this time, I stalled taking off in an incline but must have low enough to cause this. I am leaning toward electrical problems but why it rears it's head whenever I happen to run out of gas is baffling. What sort of troubleshooting should I attempt? Can I get a voltage reading from the solenoid with the key in the "on" position and work my way from there?
I tend to not to fully explain things out of trying not to go on and on. Ferox hit it on the head really. I want a street car. I'm interested in acceleration and handling over top speed. And at the same time looking stock but upgraded if that makes sense. I do plan to get a replacement car while the pickle is up on blocks. It will get stripped down, body work and fresh paint and trim. I plan this project taking 5 or so years. So with that I know I will have to outsource to professionals for things, but want to learn the things that are practical to do yourself. Hopefully that conveys the basis of the project I want to take on.
Well then the motor can go on the back burner. This will definitely be a learner as I go project. Gives me the motivation to learn how to weld, fabricate, and lastly excuse to buy lots of tools. So should I refrase my question as to what year has the best performance / ease of aquirement ratio? Really what I am after is a parts list of sorts. I know what I want in the end, willing to pay for it, and wanting to learn.
83 Pickle project planning
I posted this in the retrofits section as that seemed the proper place. http://www.ultimatesubaru.org/forum/showthread.php?p=1084297 -
The supercharger was in reference to the no debate remark. I have seen too many punks go on about their turbos. I am open to suggestions on the best motor to supercharge. I'm sure upgrading the internals would be a good idea as well.
My frankenmotor will be a 2.5 block with 2.2 heads. I have researched a few subaru superchargers already. There are enough resources here for the motor, it's the suspension and tranny that seems to be sparse. -
So I am at the stage of planning my build. I know what I want out of, basically have as new as possible drivertain while keeping the body close to stock look. I know I want a frankenmotor built with the most power I can get out of it. I am going to forgo a turbo and supercharge it. My mind is set on that so no debates. What I need to know is how new can I go for transmission, suspension, etc? I am planning on having to fabricate somethings to make it happen, so not intimidated by it. So anyone that has done a similar build, thoughts would be appreciated. I plan to document this build in high detail. I love reading build posts with photos and test drive videos and plan to do the same. The build starts in July, want to get my ducks in a row now so I can hit the ground running.
No historic love for the NW?
83pickle replied to 83pickle's topic in Historic Subaru Forum: 50's thru 70's
Yeah, when I am ready to start looking, I might offer a finder's fee to some people on the board. I need to finish my 83 project first though... -
I have a second gen wagon that I am starting work on this summer. Plan to stuff wrx power and divetrain and restore the body and interior. What I really want is a mid to late 70s wagon and do a stock restoration. I never see the first gens on this side of the US. Any one have ears to the ground on this?
Got a bonus, what to do with $?
83pickle replied to man on the moon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So true... Tires for sure. If you wanted investment ideas, you would have went to a financial forum. No disrespect to the financially educated Subaru enthusiasts. -
Cap, rotor, and wires did it. I think also the rear fuel filter played a part too. It was smoking like crazy from the oil in the heads thinking it was a compression issue. I even have to turn down the idle screw since the engine is idling at 2.5k. Thanks for all the help. GD, I owe you a beer or two.
Hrm. I did get the correct box. Just checked NGK site. So unless the wires were switched some how...
I suspected the case with the plug wires and the rotor. I confirmed the new part number for the rotor and will look up the # for the wires. Thanks.
Stupid parts counter guy gave me the wrong rotor! I called back and another guy noticed two other part numbers. I should have noticed it was wrong when I was putting the new one on, it was stiff. I didn't think anything of it since the other one was stiff coming off. Now the new one is stuck on there. I might have to start cutting it with a knife. Plus the wire set has the coil way to short. This is frustrating when I can't get out there on a whim. So looks like I have to wait till tomorrow to try it when I can get a new rotor.
I learned my lesson long ago when I had my first truck, never put a drop of oil in it and snapped a connecting rod through the side of the block. I never thought of checking more frequently when I started driving longer trips. It seemed to consume more oil than I thought. The parts store called to let me know NGK wires plus a cap and rotor are in, so I am off to swap those puppies out.
So I am about a week late in posting my issue... Here is the story. I was idling talking with my ex when my car died. I knew my tank was almost dry, but thought I had more to get myself home. Once it died, I got my gas tank and put what little I had in the tank. It didn't start and thought I needed more. So I came back with more gas and filled to about a 1/4 tank. No dice. Poured some gas down the carb and started up fine, then died. I did this twice. So I thought the filter clogged. Towed it home and changed the filter. No dice again. GD was passing through and was kind enough to stop by and take a look. I have all the basics: air, spark, fuel (fuel filter wasn't the issue but nice to have a new one). Then we discovered that I had no oil on the dipstick. I recently started taking 80 mile trips every weekend so I didn't think about my oil consumption changing. So now it falls to what we think is a compression issue. I picked up a compression tester yesterday and a bottle of Lucas Oil. I have had great success with it when I had my 4runner. So I hope to try putting a tiny bit in the spark plug hole and see if that will help with the compression. if that doesn't work, I am going to use the compression tester. Anyone have any thoughts? Mainly tips on doing a compression test? It seems pretty straight forward. What sort of numbers should I be looking for? P.S. Apologies for the back story. I could never learn to summarize...
Very little heat in my EA81
Yeah I think I can source a temp gun. That's a good first step. Thanks. -
I do have dealer installed AC (i think its dealer that puts it out to the side of the engine where factory puts it in). I need to get a dry day here and start cleaning stuff out. -
I need new tunes....assistance please
83pickle replied to dudesmccool's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I agree with amplifying the door speakers, you will notice a difference. Though I always seem to go back and forth on subs. Sometimes I want it hitting hard and others I just want to compliment. One thing I try to do is get the tweeters above my legs for the front speakers. I find when you have speakers near the bottom, your legs block alot of sound. So try to get some component speakers. Has anyone done a good setup in an EA81?
