oobnuker
Posts posted by oobnuker
  1. You CT guys can use my discount at my local dealer.Contact me and I'll save you some big bucks.Art,I hate to tell you now,but I could get those for $170.....sorry bud.
    bikepo-feel free to contact me.I've got a heap of stuff you can probably use,cheap.
    Like oobnuker said,those other holes are for "reserve".Stop down for a little Subaru education sometime.I have a workshop off of I-95 at exit 40 in Milford,right across from the truck stop.Glad to see another CT member.
    Cheers,
    Paul
    Funny thing about buying the exhaust - I was going to register the car for the first time, and I was under the assumption that I would need to get it inspected and therefore need the exhaust replaced as it was all rotted out. Well, the CT DMV and their bastard marriage with whatever vendor was doing their emmissions testing was coming to an end amidst all sorts of corruption and other BS. So I bought all that crap, brought the car back to OEM spec, went to register it - and the lady at the DMV just handed me the plates. No inspection, no exhaust, no emmissions testing - nada.
    It took about a month before I had hacked that exhaust to pieces in search of a little more power...
    $500 down the drain...at least I didn't pay anyone to do it for me...
    Oh well - live and learn.
  2. This is my second post regarding this lovley motorcoach. By the way thanks for your help on the first problem...a simple vaccume leak was making the car undrivable...with a little info from you fine folks the suby rocks on. Now that the beast runs ok it is time to quiet it down...it has about twelve leaks from a horrensiously rusted exhaust. I'm not sure how the exhaust should look for this car however. I think the last guy home brewed a cheap system together. There is no cat in the mid pipe...should there be? The idiots at auto zone say so but i try not to trust them. Also the existing y pipe flanges are two hole ones hoever the block has an additional two threaded holes. Are they supposed to be four bolt flanges? Also if I do replace rather than patch the existing front pipes should I get the funky double layered jobs that the car has now? Does the second layer really do anything?
    Thanks -
    Bikepo
    The "second layer" is probably heat shielding. No real biggie there.
    There IS supposed to be a second cat in the mid-pipe. Only two holes are used. If they strip out, you can have a shop cut and rotate the flange 90 degrees and put studs in the un-used holes.
    I can tell you right now, that I replaced everything from the Y-pipe back and it cost something like $500 for just the parts. The mid-pipe is $270 or something ridiculous. Most shops won't touch the car if the stock/original cat is not used or if they are not replacing it. Add insult to injury in the fact that most junk yards will not deal with exhaust related parts if they involve the cats...
    Are you sure the front pipe is leaking? It might just be the gasket between the Y-pipe and the heads. If the front pipe is not leaking, not sense in replacing that....
  3. Welp, I need a new air filter - I bid on one of them. There are like 5-6 auctions going. If no one else buys one, I'll let everyone know how it works out. Auction ends in 13 hours. I hit it for the lowest bid (because I am broke and cheap), so I am going to just ride it out, but I don't expect to get outbid...
  4. when i had maf i cut and ground the mounting ears off my hot wire
    so teh cone filter would slip over the end of the maf ... no adapter looks better
    and just barely touches the inside fender
    I was thinking about this. I'd have to do rough cuts with a hacksaw and then grind the rest off with a Dremel - but I only have one MAF and I don't want to screw it up.
    Hence my interest in this low-buck solution.
    Also mounting directly to the MAF creates another issue - mounting the unit itself. With the ears ground off, how did you mount it so it doesn't bang around and ruin the thing?
  5. yeah, tools and parts are not the problem, time and ability are. i don't have time to be spending every evening trying to fix this thing, going from one known problem to the next. i already have the O2 sensor and the water pump but lack some of the tools to replace them. I almost tackled the water pump a couple weeks ago but got snagged when i couldn't get the crank pulley off. the O2 sensor is original and has now been made even harder to get out by the layer of CV joint grease that spewed out of the boot onto the cat effectively glueing it in place. and those are only the problems i know about. i also have a substantial rumble in the front suspension that i can't track down. my engine problem might be solved by the O2 sensor, but there could be a lot more wrong with it. In the last 2 months i've already replaced the left front suspension/axle as well as several ignition components. i also know that i have a slightly stripped thread in one of my spark plug holes which i cannot fix myself.
    so basically, i'm not up to the hassle of fixing all this sh__, and i'm not willing to dump a grand on a car with that many miles.
    I hear you. I have gone through periods of absolutely hating my car. Particularly when I had the opportunity to drive a newer car for a couple of months...
    In the 2.5 years of owning this car, I have done 3 axles, the 02 numerous times, timing belts twice, distributor, fuel pump, EGR solenoids, alternator a couple of times, water pump, power steering pump failed (yanked it).
    On the other hand, the thing hauls me to work and back 100+ miles a day, gets 23 MPG, and will get up to 100 on the highway. The odometer broke 25,000 miles ago, the car was given to me for free as the 7th owner with 140,000 miles - now has close to 200,000.
  6. well, now in addition to all the other problems, i have a dead fuel pump
    so here is the tally
    fuel pump $200
    CV boot $250 at a shop
    O2 sensor $100 at a shop
    water pump $200 or so at a shop
    state inspection $15
    brake pads/rotors $200+
    so thats almost a grand to be put into a car with 275k miles. I have reached the "screw this" point
    I don't want to sound like an rump roast but...
    fuel pump - new generic - ~$90
    CV Axle - ~$60
    02 Sensor - ~$25
    Water pump - ~$35
    Brake pads/rotors - ~$60
    If you did all the work yourself, with the help of everyone here...you'd have saved hundreds of dollars. All of this could have been done with a cheap 100 piece toolset and a couple of oddballs (big socket for the axle, etc.)
  7. Hi,
    I am new to this car as of last December. Seems to be a decent runner, but leaks a fair amount of oil. The case is pretty oily, so I need to wash 'er down to see where new stuff is appearing from. It does seem to find it's way onto the pass side exhaust where at least it gets vaporized before hitting the ground... But since my main experience is in older volvos (122 series) where there is significantly less, well, crap all attached to the engine...
    2 questions:
    1) When I (hi pressure) wash it down, what could I drown? Obviously cover the air intake, and maybe the distributor cap - but what else on these engines doesn't want a direct hit of high pressure hot water?
    2) Is replacing the valve cover gaskets just that? Or does it involve other parts (grommets? where?) that I will only realize that I need at 11PM Saturday night with it all apart in the driveway and storm clouds threatening? And is there any advice on what attendant crap (er, accessories) needs to be moved out of the way to make the job easier? Pass side vs drivers side?
    Thanks, I really appreciate any help on this before I dive in.
    Signed, an old water cooled volvo guy that is trying to learn 'new' technology (okay, it's my kids' car...)
    - David
    The valve cover gasket set should include the grommets for the bolts. It will be tight, but you should be able to get it to go - you may have to be creative in getting the gasket to stay in place while you are trying to get it all back together.
    Make DOUBLY sure that you cover the distributor cap - there is some kind of optical sensor in there that goes screwy if it gets water in it. Other than that, I think you've got it covered.
    Check the Cam Shaft seals, Crank Seal, Oil pump - these are all on the front of the engine. The the cam/crank seals should be pretty easy to find, the oil pump is right where the filter attaches.
    Also the Camshaft carrier -> Head seal sometimes leaks. Check that too.
    Check the passenger side CV boot - right above the catalytic convertor - it tends to get dried out by the cat and crack and spew grease everywhere...
  8. took a long trip on the interstate (perhaps too long in hindsight), after 120 miles at 75-85, i made a stop and noticed smoke from under the hood. Opened it up and to my disgust i saw oil spattered all over the right side of the engine compartment (smoke from it burning off of the cat). what appears to have happened is that oil from somewhere got on the drive axle/inner CV joint boot and was being spun off in all directions. the confusing thing is that i lost no power (car ran like crap anyway), plus the oil level is right where i expected it to be after such a drive. no coolant/oil mixing occurred, and I made it another 100 miles before i stopped driving (granted at 55-60 instead of 75-85). i'm going to degrease the whole area tonight after work and maybe try to track it all down.
    any ideas on this one?
    Sounds like the actual grease from inside the CV...Another thing to check is the dipstick - my friggen Loyale notoriously decides to pop the dipstick up now and then, letting loose a quart of oil all over everything. The O-Ring is worn to hell and just needs to be replaced for that one...
  9. This happened to me once and it turned out to be just a loose hose at the pump. The hoses are usually bolted down with little brackets here and there, so they may seem tight but might actually just be resting up against the pump.
    If it is just the pump and you can live without, these little cars are remarkably easy to manuever without power steering - I ended up just getting shorter belts and disconnecting mine and removing it.
  10. 91' loyale, my front suspension squeaks while goving over bumps etc. I had my girl friend pust up and down on the front while Ilistened for noise, it appears to be a sway bar bushing. Has anyone replaced this before? What does it take for a job like this? thanks
    It should be a piece of cake - but make sure you put the entire front end up in the air (both sides) otherwise the forces of once side will tweak the swaybar and cause you a lot of headaches. If everything is just hanging free it should be no problem at all.
  11. Great info - thanks. I'll let everyone know how it turns out.
    If you haven't gotten the pulleys swapped yet, you can swap the rear cover and stator windings from the good one to the front half of your old one.
    Remove the bolts holding the case halves together on both units. Keep the stator windings with the rear cover on the good one.
    On the backside of the rear cover, there's a small hole in-line with the brushes, use a paper clip thru the hole to hold the brushes in the retracted position. Do one at a time, and the most rearward one first.
    Put the casing halves back together and bolt them together. Now remove the paper clip. You should be good to go.
    While you have it apart, take a good look at the slip rings where the brushes ride. They should be somewhat smooth, and not pitted. A little and light touch with some fine emery paper will clean them up, if needed. Wipe them down good if you do that, the grit will eat-up the rings and brushes if left on there.
  12. How do I keep the internals from spinning? I haven't tried my impact wrench yet, but I am wondering how to keep the stuff from spinning.
    Edit: I'm thinking now if I'm not concerned about the pulley on the new alternator, I can just use a vise or big vise gripes and a pipe...But that still leaves me with getting the pulley off my old alternator...
    Still looking for anyone who has actually taken one apart.
    I may take you up on that offer for the other alternator if you're gonna be down here anytime soon. Don't want to make you drive down for nothing...
    Have you gotten the nut off that holds the pulley? If not, try an impack wrench; that will get it off.
  13. Many thanks to WagonsOnly for the alternator! It was a nice drive up to Northern CT this afternoon...
    Anyway, I didn't even look at the alternator when I grabbed it from him. It turns out it has the wrong pulley on it - Serpentine vs. V-Belt. I can't get the pulley off for the life of me, so I'm wondering if I can simply yank the voltage regulator out of the good alternator and slap it into the bum one.
    Has anyone ever taken apart an EA82 Alternator?
    I know, I know, reman. units from the Auto Parts store can be had for 50-60 bucks, but right now, I don't have that money...
    Anyone? Looking for experience taking an alternator apart.
  14. yeah there's an oval inspection window
    the caliper comes off (oh baby) via two 17 or 15 mm bolts on the engine side of the caliper, kinda tucked in there
    If it's the driver's side turn the wheel all the way to the right ( all the way to the left if passenger ). You don't have to take the caliper off the spindle to change the pads. True, there are two bolts to remove the caliper, but there is one smaller bolt at the bottom of the caliper that once you pop it out, the caliper will swing out from the top to expose the pads. Take care not to mess up the little metal thingies in there as they don't come with the new pads.
    The piston needs to be turned back into the caliper - NOT PUSHED with a C-CLAMP. There are special tools that you can use to do this, but I usually just use a common wrench to fit in between the little bumps on the face of the piston. Do not put a wrench or vise-grips on the outer edges of the piston as you'll score it all up and cause a leak. You'll see what I mean once you have it all apart.
    Jack the entire front end up if you can. This way you can consult with the other side of the car if you forget how things go back together, etc.
    You may have to scoop some brake fluid out of the master cylinder to make room as the fluid gets pushed back up into the system when you push the pistons in. Don't expose any of the bits in the bottom of the master cylinder or you'll end up having to bleed the brakes. Not a bad idea to bleed them now anyway though...
    It's not a hard job at all, just be patient.
  15. If you look up where the Y-Pipe meets the heads you should be able to see burnt out spots around there if the gasket is shot. If you still have the timing belt covers check them for melting too - that would be a good indicator. Also CAREFULLY check the exhaust studs for tightness - this is a pretty common failure on these motors. I stress carefully because if you trash the threads by over tightening you will have to either helicoil them (good luck with that - never worked for me 5 times I tried it), or you will have to use the unused pair of holes on each head and have a muffler shop chop your Y-Pipe and re-weld it 90 degress off.
    In general, look where any of the joints that you may have created meet and look for soot deposits indicating a leak. Often a fresh exhaust clamp will loosen up after you first put it on and a few heating cycles...
    Thanks for the help, car is non turbo, recently installed new exhaust 2" from cat back, which is why it is now more of an issue cause it's louder, it is worse when cold (i think) and i'll check the y pipes and gaskets for leaks but, what is the best way to check for these leaks??
    Yes the air injection system is still hooked up.
    It has also been suggested that a vacuum leak (somewhere, in the mass of vac lines that is a EA82) may be a contributing factor, what do you think?
    james
  16. Seconded on the exhaust leak. My entire exhaust (all 3' of it) is a patchwork of do it yourself pieces from the autoparts store - leaks like sieve. Causes all sorts of pops and burbles just as you described. Check around the Y-Pipe to Head - those gaskets SUCK as they are paper with steel mesh inside. The paper burns away over time (like a week) and all you are left with is a nasty leak. I love the way the car sounds when it is whole, but it doesn't stay whole for more than a week, so I stopped bothering.
    I have the same problem. Its an exhaust leak most likely.
  17. If the moaning is just when doing real low speed stuff while turning the wheel (like pulling out of a parking space), it could be the power steering pump/fluid.
    Hey Steven
    In my experience when tires get close to the end of their life they often (almost always) develop balance problems, try rotating the tires and see if the shimmy changes or moves to a different part of the car.
    CV joints certainly can cause vibration, even before they give you any other signs of wear, but when they do start “talking” to you its normally a clicking sound when turning sharp and slow.
    Low speed moaning with a higher speed vibe sounds like it could be wheel bearings, the fronts aren’t to spendy and are pretty easy to do if you have a few tools. Maybe some other board member there could help diagnose/repair it with you.
    Good luck
    Gary
  18. This is probably the most annoying thing I have ever come across with my Loyale. I managed to strip out the threads on the distributor shaft, so the set screw would walk out every now and then. Why they did not engineer a key-way or something to keep the rotor inline whether the screw is present or not is beyond me. It is a tiny screw like you said, but that stupid little screw will leave you on the side of the road cursing. Bumping the engine so you can rotate the shaft ever so slightly to get to a "clear" spot where you can jam your hands in there and blindly go about attempting to put that screw back in....
    This happened to me about 4 times. I eventually replaced the distributor with another junker, but the inherent problem is still there. The screw can fall out and the rotor free wheels on the shaft leaving you ANGRY.
  19. Rad then maybe ill give it a try. You remember what you payed? Ive seen em on ebay for like $20.
    Check this out: http://bankruptsoul.org/gallery/displayimage.php?album=5&pos=25
    This is my side-exit cherry bomb (Actually Thrush, but whatever). It's a 2", and it's the shortest length I could find - I think 25". Most auto parts stores seem to have these, so you could save yourself some shipping be checking around. Sounds awesome.
  20. i have my front covers off, but not the entire covers. works fine for me. lotsa peepl leave themoff. may make them break earlier, because of the elements gettin to them, but when they do, it'll be easier to change them.
    I ran them with the front's off for a while, but I honestly think it's better with the cover completely removed. Oil and grime and crud used to collect in the remnants of the covers. Now there is no where for that stuff to go but out and down.
    Also note I have had the belts break twice on me - once with full covers, once with half covers, but NUNCE (None, nada, never, nil) with no cover.
