JohnVT
Everything posted by JohnVT
How strong are CV joints? On our 97 OBW, with 134K miles, I discovered today the rumble noise is the front left wheel - the outer boot is gone, and the CV is dirty... I know not good news. It's been making noise for a while - ok a long time. I looked for a cause, but at first had blamed it on the studded snow tires. Now at low speeds, the steering wants to wobble. So I plan to change it, but it's cold and work is busy. I assume this is a failure that could be catastrophic at any time?? or will it fall apart? How dangerous is it to drive? I've read lots of opinions on this board, and plan to change the front axle next week. Or should I take a day off quickly? It might get above freezing later this week (and we're north of all the snow that was in New England today). I know this isn't smart, but how much more damage can I do if I drive it more?
97 OBW shudder?
JohnVT replied to JohnVT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks Jamie - not that I've never overlooked that!, but I did also check it this time. -
97 OBW with 130K, has 4 Hakk1 studded snow tires, in LAST season of wear on steel rims. New rear struts. Hearing what I thought was snow tire noise, but can almost feel a wobble or rumble starting at 30mph. I don't SEE any wobble in any wheel when following the car, or when I turn each wheel, seems to stay same distance from the strut. Frost heaves and other "imperfections" in winter roads sometimes make it hard to tell car noise from road noise. What should I look at first. Guess it could be a balance issue. Or worse? Bearings, CV (rear??), u-joints, driveshaft, ...?? thanks for advice.
This time, the problem was that it was in the 40s and RAINING Saturday before it started snowing, and got VERY cold... So the remaining water froze the doors shut. Had a hard time getting in my Saab today too. On the Sub, deicer, or maybe a hair dryer will defrost the windows to gasket connection. Certainly these gaskets can and will tear... Although I haven't had that problem yet!! Usually pulling firmly, but not jerking, will start to release, then carefully work around.
Not sure you can adjust this hydraulic clutch... unfortunately I've replaced two clutches on my 97 OBW in 120000 miles. Not sure why, didn't think my father-in-law, my wife, or I were particularly rough on the clutch. So, yes, it is possible to need a clutch at 70K, though many last longer. The clutch kit is about $300, and it's not really an easy job (although I've gotten better at it after twice!) So it could be $800 if you need to hire someone to do it. Be sure to have the flywheel turned or replaced while you're there. good luck!
Not only is it VERY dangerous, as has been mentioned, it is also against the law in most states in the US, including VERMONT. But the last time I said something to a station attendant here, he said he got tired of telling people that. Not sure if police have time to enforce it until somebody gets blown up!! (and Vermonters will tell you we have NO crime, so you couldn't possibly have seen somebody steal a car...............................)
Foggy windows
JohnVT replied to MeepMeep's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I agree with Skip - is the carpet wet under the dash? Most probably the heater core, or nearby connections, leaking. If it was one of my older Saabs, I'd almost guarantee the heater core!! -
Well, it is slipping, at least some. It's inevitable when starting from standstill, especially pushing/pulling a trailer on a hill. The smell is some clutch material wearing away, so in that sense the smell is normal. This does shorten the life of the clutch, of course. There are other threads on this forum with suggestions for maximizing the life of the clutch.
70K should be early for the timing belt and the clutch, BUT my clutch went out at about 70K on my 97 OBW. And if you've got the engine torn down, replace the crank front and rear seal, cam seals, oil pump o-ring (on the crank shaft also), sealant on the back of the oil pump, and the timing belt. Some also replace the oil pump and water pump while the timing belt is off!! oh - and maybe the belt tensioner. None of that should add much to the labor cost, only parts. And the labor would be the same later to replace any or all of that... If you're replacing the clutch, have the flywheel machined, or replaced too. I don't deal with service shops, so I don't know how much all that would cost. (I'm stupid enough to try all that myself )
not sure if my wife or I do anything especially wrong with this clutch, although I feel it does slip on me at times, maybe because I'm used to the stiffer clutch on the old Saab I usually drive, but the first clutch on our 97 OBW lasted about 70K miles, then only about 40K. This one has about 25K on it, and I haven't noticed anything yet, but the flywheel will get resurfaced or replaced next time...
It's easier to reach if you remove the battery and the air intake on the other side... (at least it's there on the outback) I have a spark plug socket with a flex joint built on to it that my father-in-law found somewhere. That, and the extension can slide around the corner (with a little patience), and then the ratchet fits on the end with almost no clearance. It has gotten a little easier with practice!!
Hi we replaced the rear struts today. Not a bad job, even if it did take all day. We bought Sensa-tracs, hope they work out ok, and a good spring compressor. We did see some peeling of the protective coating on the springs (rear), and used a steel brush and some automotive primer to cover the spots - especially since it's about to be winter in Vermont... so, 1. can someone tell me the VINs covered by the spring rust recall? 2. does anyone know where to buy the entire strut/spring/etc. ASSEMBLED for this car? 3. I thought I read that I should make marks and be careful on reassembly so I don't mess up alignment (on rear). Are there any adjustments on the rear struts? I didn't see any. It does seem to handle better, since, as I suspected, the left rear strut had leaked, and had no damping resistance at all. thanks!
my 97 is hydraulic, so I'm sure the 96 is too. the hydraulic clutch cylinder is on top of the engine just under the throttle body. Remove the air intake assembly to see it to make sure it's moving. How old is the clutch? What's the mileage on it? You probably need a clutch; in my experience the Subaru clutch doesn't last too long - <100K.
