Everything posted by bella
Can sommeone tell me were is that sensor and how can I verify it? Thanks
What is PHV....an adjustement???? Thanks:)
Weak and ineffectual brakes......
bella replied to bella's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So,....should I bleed the brake pump(the MC) too????Because tomorrow I want to do this action. Thanks P.S. When I press the brake pedal a very easy anomaly is happen with my engine...is not working so fine at idle state...any guess??? There is a vaccum leak?? -
How har could be to strip myself my carb.I have for sure many dirty things on it because I run out for gasoline and.... It is so complicate for a beginner???Because if it is, I'll give up.. Thanks.
Until now I have use : -20w40-summer -15w40-winter ..and the oil exchange at 7.000 Km...it's better to use 20w50 ?? Thanks.:cool:
Anyone has use Dura Lube on the engine....It's worth to try(my engine has 230.000Km)??? Thank you all..
Help...won't idle under 1000rpm
bella replied to xjosh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My car won't idle under 1800-2000rpm but thi is happend after I run out of gasolin and all the dirty from my fuel tank was in the carb....So I don't no if this help Good Luck -
Thank you guys..... Any other informations will be apereciated...... -
Please :confused:tell me how exactly bleed the entire system. What is the procedure. Thanks. -
Hello, This is my problem:yesterday I have changed my brake pads. Because I didn't now how to push back cylinder to make more space for the new pads, I depleted it from brake fluid and late I learned that cylinder must be rotated to recede into the background. Now after brake aeration(only on that side with depleted cylinder-front right side-This could be the problem,...Should I bleed the others 3,...and the brake pump????? ) my brakes are more, more weak and ineffectual that before....Please give me an advice...Thank you allot.:banghead:
Alternator "T" wiring connections help
bella replied to RUMBLOKE's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Connect the two wires no mater how but don't start the engine. Pot your key into the contact and if your lights (oil, brake, battery) are on, is a good connection. ..otherwise change the two wires between. P.S. Please don't start engine before your connections are fine because I broke an alternator doing this...Good luck -
Hi all, I am from Romania:banghead:.....Here, a Clutch Kit for my car is around 350$ so I want to buy one from US. Anyone can tell me if kit from this Link is good for my car..because if is not, from Romania to US is a long way: (http://oem.thepartsbin.com/parts/thepartsbin/wizard.jsp?year=1986&make=SU&model=LOY-4WD-001&category=I&part=Clutch%20Kit&dp=false) Thank you allot. P.S.If you need mor informatinos I can provide
Probablly because I run until my Fuel tank was enpty(stuppid me), the garbage from him is now in my carb....and now if I not mentein it around 1700rpm is stop. What ca I do...a friend tell me to go on the highway and run at high speed for 10-20 miles..... Sorry my english....I am tierd and sad:confused: I wait for your advices.
I have a friend which will go to Santa Clara in few days. I want to get for me a Subaru manual(in Romania is not exist)....What is the best(most complete) manual to help-me understand and even fix some stuff. I have a postal address from AUTOZONE, is ok?
Thank You and if anyonne has others sugestions......
Can I see with a digital multimeter if my induction coil is ok???What should I see on multimeter??
This morning I left to work with my car. After less than a mile my engine has stooped. The truth is that my gasoline indicator is showing me that is empty but my problem is that when I tried to start the car is starting and is dieing immediately. Now I am to work and tonight I will put some gasoline but the question is:If I have no fuel why for all that my engine starts even for 2-5 seconds? I really need an advice because tomorrow I want to go in vacation. THANK YOU. P.S. If I take off cap from the air filter and with engine stopped I accelerate, I'll be able to see in my carb if gasoline is coming.............?
Could you be more specific??? Thank you.
What exactly sould I search for.......
Please someone tell me if my type of gar has this capabilities. Thank you.
What in the God name are ECU codes....Are computer generated errors or what????...My car can generate???? :confused:Sorry if this is a stupid question.
Things are like this: -gasoline consumption is around 10%(in the city) and 7,5-8%(outside)-1 liter of gasoline is around 1.2 USD -LPG consumption is 12% and 9,5%-1 liter of LPG is 0.6 USD The only problem(until now ) is that the car lose about 6-7% from his power, depending of what you expect from..... Best regards all.....
Finally the LPG is installed on my car, and is working great.....
Unfortunately my metal plate containing only tire pressure....
