Everything posted by bella
Thank you:)
One more question......inner tie rod can be replaced without dismount steering rack?? 10x:)
Man, you really are a Master:). Thank you so much and all guys for replyes and HOPE that will be the problem. Thank you all for your time.
Can you PLEASE give me few details......there is on marketplace a repair kit or what?? I have a steering box picture bu I don't now what is the inner tie rod.... Thanks a million.
So I MUST buy a new Steering box?
As I mentioned in attached image I have a clearance on my driver side tie rod. So is not ball joint from my tie rod end and from what I now is no way to use adjusting screw because it cannot be clamped(is maximum clamped).:mad::mad: So, what can I do now. From what I now, in the driver side is no bushing or something like in passenger side. Please help... Thank you all.
1986, Leone, Sedan, EA82, 1.8GL, Carb, 4WD. Thanks.
My problem is that with engine at idle speed(850-900 rpm), if I press brake pedal, RPM falling down around 6-700 rpm even if engine is warmed up.Could be vacum leack??Or what...?? Thanks 1 million.
If your spare tire is located in engine compartiment, so under her is second dipstick. Good luck.
Carbd EA82 w/ Erratic Idle Speed
bella replied to DirtyMech's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try to ceck O2 sensor...... -
240.000 Km on my Leone:)
There is no plate there.
http://www.economysuperstar.com/milesfox/subaru/rx/vin.htm Here is a description but my VIN does't mtch. My VIN:JF1AC5BL0CD622389. -can anywone tell me in what month of 1986 was my car build? Thanks
Just bought my first Subaru!
bella replied to danbennett2u's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wellcome and good luck. -
How To Keep Your Subaru Alive pdf file
bella replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah...Great book:banana: -
What other car rimms will fit a Gl?
bella replied to Gl-boost's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If I'm not wrong Peogeot 405 rims will fit. Or try this:http://www.economysuperstar.com/milesfox/subaru/wheels.htm -
Thank you...you too:). Just a bad contact........lucky me.:banana:
10x...this week-en I'll ceck to see what is wrong..
Water leaking in my car....but how???
bella replied to bella's topic in Old Gen.: 80's GL/DL/XT/Loyales...
10x man....other opinions???? -
I have same problem with water behind the driver, on the floor.....:confused:Could be something about sunroof???....or his gasket?? Thank you.
My car(Leone, Sedan, 1986, EA82) has self-locking system, driven by driver door(factory installed). My problem is that the rear door on driver side is not open/close with this system(is working if I lock/unlock with my hand). Now, anyone deal with this problem??..I hard to fix??...How is work this self-locking system, is electrical or mechanical. Thanks.
Thanks man.....I'll buy 2 pcs. to be sure. Wheel cylinder successfully changed, and are 17.5 mm diameter. Thank you all.
No problem......I hope this will help at least beginer people....
I thing this is a decent book for old Subaru owners. Enjoy. Link:http://www.sendspace.com/file/j4klee Attached is a screenshoot of first page.
