Everything posted by bella
Brake liquid light warning!!!!!
Thanks.......other guess????
So....no ideea??????? Thanks
Is fluid light and if I follow your procedure light goes off....but why is happen this? Thanks PS:'86, Leone GL
Here, in Romania is winter....if my care stay one week when I start engine, my brake light(dash light) is ON. If I open and after that close my brake fluid container cover, light is off. Is there a problem??My brake liquid level is ok. Thanks
Will a wet distributor cap cause tach oddities? (jumping & incorrect readings by 2x)
I hade same problem but because my alternator diodes. Paul
i need help with my brakes fast
Your Cylinder act as an screw.....so just turn him to right and will depress by himself.Hope will help you.
Bushing pictures
Thank you verry much..
Bushing pictures
Ayone can send me pictures with stabilizer link bushing ??? Thanks.
My engine not start....
Wright,wright,wright.
Yes you ca start engine on LPG even if is verry cold but is not recomended because LPG is more "dry" than gasoline and can hurt your engine.Also when my carb was working, my car starts at first try in the winter, now I must do 2-3 tryes befor start=>damage my battery and my electromotor(I hope this is wright word). Paul
Ok.How I do this and what values should I have to be ok. Thanks
Everything started since I run out gasoline:banghead:. After that change my gasoline filter, my mechanic has clean my carb but still not starting than after 8-10 attempts. I have dual fuel system(gasoline and LPG), and if I try to start on LPG is starting normal but winter is coming and in the morning I MUST use gasoline for starting the engine. So, what do you think guys?.....One more thing, after engine is warm, if switch from LPG to gasoline my engine not die but is not working so good and it has less power on it wich is unexpected. Thank you.
85gl sw help with clutch cable
On autozone.com is an online repair manual....try there...there are pictures of how to do. Paul
HELP!!!!! Im going through alternators like oil changes UPDATE!!!
Agree with you....also double ceck ground contacts. Good luck.
Valve cover rocker gasket(LH/RH)......
Thanks and hope you will solve the shaking problem.
Another request please. Here in Romania is very possible to buy from store a wrong spare because.....I don't now:banghead::-\.So can anyone post a scheme or a picture on how is looks like this gaskets???? I'll appreciate allot. Thanks guys.
Thanks man you too:banana:
My car is too accelerated...
When I drive my car and take my hand off my acceleration(let say at 2000rpm) indicator came verryyyy slow at idle speed(800 rpm). Why is that???And ofcourse my consuming is big.Same beahivor on gasoline and LPG.
I whant to replace it myself and I whant to now how hard it is?....I will lose oil in replacement process.....something need to be adjusted or I just unscrew nuts amd replace gasket. Thanks.
Verry bad oil leak....
Thank you all guys......you are great. This morning I leaved my baby at the mechanic.
Compression test made and is OK.
Please guys HELP me.....I have a verry bad oil leak from behind my crankshaft(driver side) at timing blets side....oil leak trough my PVC case of timing blets(only from passenger side:banghead:)...also I have oil leaks at Valve rocker cover gasket. What should I doo???????Is verry bad wright? I lose 4 Liter at 100Km. I can give you more details if needed. Thank you.
my car is shaking....
Wheels are OK.
I've tryed to start off from a dead stop in third and second gear and if I not accelerate engine over 2000-2500rpm.....is almost stop and car shaking verry bad. So, my clutch need to be replaced or if I adjust him will be OK...I jus wonder...could be the clutch cable too tight. Thank you so much.
