Everything posted by johnd911
How do I remove this trim piece?
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, putty knife? or screwdriver?
My 93 Legacy wagon has a body colored trim piece that sits at the front of the rear wheel opening. It covers the body between the rear door and the wheel arch. I have to remove it because I see rust stains running out from under it. It is plastic and I don't want to break it. Any ideas? do I pry?, there seem to be no screws holding it on etc. It sits right above the rockers and goes up about a foot. Thanks
Phase II 2.5 reliability?
johnd911 replied to Philbiker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow does one tell the difference between a I and II ? What years did the phase II come in? So are you positive that only external leaks happen on the phase II? thanks
will 91 2.2l fit a 93 perfectly
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hope the 91 was as bulletproof as my 93 motor has been.
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks, a cheap spare would be nice since the car has minimal spots of rust and is in great shape, highway driver etc.
.I have a chance to get a low mileage 91 2.2l . My 93 2.2l awd wagon lefacy has 350,000 and a spare engine would be nice. I was wondering if the sensor connections, exhaust, etc. would bolt right up and if the computer would match up to the engine. OR if I should just look around for a 93 engine. Please respond asap, the owner of the engine needs a fast answer.
my 338,000mi. legacy uses 1 qt. oil/1000mi. whoopee
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI swear that after 4000 the fleet oil comes out just as viscous as it did when it went in.
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there a way to include a picture of my odometer in this post. The 15/40 diesel oil is great for the summer, when I drain it every 4000 miles, it comes out as thick as when it went in. Dino oil drains really a lot "thinner feeling" after 4000 miles. Other than belts, an alternator and just recently a starter, and plugs and belts, everthing on the engine is fine. Had some rare check engine lights appear at 10 below, now that the temp is in the 20-30 degree range, the light has not reappeared. Original struts, exhaust, no body rust (a few tiny surface spots I touched up), original O2 sensor and all other sensors. A couple of wheel bearings and cv boots. Sheesh, isn't this normal for a domestic by 50,000mi.? I will need a replacement soon and NO WAY IS A 2.5l SUBARU in my future. Either a used 2.2l wagon until they stopped making or another make .
I think this is great-am I right? no other engine problems , ever. no noise, no leaks, just normal wear and tear belts, idlers etc. I use diesel Rotella in the summer and 5/30 in the winter. No way will I consider a 2.5 a replacement when I do get rid of this 93 2.2l. Am I lucky, or are all well maintained 2.2's this bulletproof? I have friends whose Neons are shot by 80,000mi.
Whats the best Outback under $10,000?
johnd911 replied to captainehh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat would make the ccr head gasket repair last longer than the subaru repair? If it's a crappy design to begin with.
need "check engine" light help
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't read my codes yet, when I looked under the dash i only saw one black connector. Will read my codes in the next few days, the light hasn't appeared for over a week now-it is 15 degrees warmer now (20 degrees F.) ALSO: my air bag light has been on constantly for 3 months now.-ANY IDEAS why?
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXanyone know how to read the codes on a 93 legacy. the car talk link dealt with a gl. If it is the egr valve, where is it on a 93 legacy?
3 times in the last 3 weeks (below 20 degree weather here in Buffalo) my check engine light would light up, if i shut the engine off and immediately restart the car, it would not reappear. I have a 93 legacy. No driveability problems, perfect ice cold starting, no change in gas mileage etc. Any ideas on what could be the problem? Is the computer smart enough to sense something going before it goes? thanks also, is there a way of getting codes out without going to the dealer etc. I know I once found a page that let me find tranny error codes by counting lights.
cracked radiator
johnd911 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI fixed mine with some screening and JB weld, I also run a very low pressure radiator cap, so low that if you squeeze the radiator hose you can just see a tiny amount of coolant go into the reservoir. Even on 90+ degree days my 350,000mi. legacy doesn't overheat.
Question for Legacy owners with 200,000+ miles
i used to warp front rotors on my automatic wagon (345,000miles) The best life i have seen is with Brembo rotors and ceramic pads-no more warped (actual warpage) rotors, my other car is a 911, so I do drive HARD and there is minimal engine braking in an auto. Original tranny went at 300,000 mi. (my fault, it took me 1 hr. to get my car out of a snowbank before a girls boyfriend came home-long story). Original starter just went, front axles get replace from Autozone (lifetime warranty) whenever the boots tear. One ball joint has gone, 3 RR wheel bearings , original exhaust, small rust on rear quarter panel by wheel well, original struts, burns 1qt./1000mi. i tow 2 jetskis in the summer. Alternator went once, original emissions and pcv valve. I add r-134a every spring (wal-mart conversion). No GM, Ford, Chrysler would ever have lasted this long (prev. exp.) I hoping for 500,000mi. before I'll look for a replacement. I will never get a 2.5l Subaru, ever. i use diesel oil (Rotella etc. in the summer ).
what headlight bulbs to buy?
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.talkaboutautos.com/group/rec.autos.driving/messages/525825.html excellent article that shows the Wagner Britelites to be a top rated bulb. the US silverstars (also confirmed elsewhere) are nothing more than everyday Osram blues in europe. So according to this article with links to a Brittish bulb test, the Wagners seem the best in the 30% category, (they are Phillips bulbs). I'd like to get my hands on those 50% brighter euro bulbs!!!!
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust installed one (1) Wagner hibrite, it's made by Philips in Germany. in my dark and wet driveway, no difference that is visable between it and the wal-mart GE blue ($8 dollar bulb). putting my high beams onto my garage door 50 feet away, no visable discernable difference in brightness or visable light at all. Looking at the headlights head on from a distance, I see no difference. From what I've found on the net, these Wagners (aka Philips premiums) are supposed to be the brightest zenon bulbs that you can get in the stock wattage. So, I'll just leave the 2 different bulbs in there. I drive in Buffalo NY.
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwho's got the silvania silverstars? autozone? wal-mart? napa? thanks for the replies
i need new 9003 halogens for my 93 legacy. Wal-mart has plain GE's and GE super blues? anyone have good luck (better light than stock) with any aftermarket bulbs? in the stock wattage? ( I don't want to melt my lenses with higher than normal wattages. Thanks
@#$$% wiper arms!!
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA Doug Flutie photo, a "Go Leafs" bumber sticker and maybe a Canadiens sticker, these should give me immunity. I put the flag decal on after 9-11.
@#$$% wiper arms!!
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got relatives in Toronto and used to visit there alot, so far I've had spray paint sprayed on a flag sticker, a flag broken off with antenna and a lot of rude comments similar to what some British are saying about Bush today. We get tons of Canadians coming down to see the Bills and Sabres play, but I have yet to here of anyone doing anything to them. As long as it's just a middle finger or torn flag I can live with it.
@#$$% wiper arms!!
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've tried using good summer arms in the winter, but doing mostly highway driving, I noticed the wind chill (at 65mph) just freezes the arm flex points (little hinges) after a using the washers. Dicing with semi trucks and driving mostly highway miles in the winter make the winter blades alot better for keeping a clean windshield. Today I noticed a fine scratch caused by some debris under my drivers blade, square staring me in the face is a scratch in the form of an arc right in front of my face. Almost impossible to feel with my fingernail, can it be "polished" out? and how? I can't have the glass replaced cause it's only 4 months old and there are no cracks or anything. The insurance company already replaced it. Sheesh, it's one thing after another....
@#$$% wiper arms!!
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXabsolutely positively an unknown product here in Western new York, I checked everywhere. I'll have to cross the border, "lie" about the purpose of my trip, and hit the Canadian stores. Does Wal-Mart etc. carry them, or do I have to look for a Canadian Tire store. I'll have to remove the US flag off my car, previous visits "annoyed" many anti-US people and I barely avoided alot of car damage.
@#$$% wiper arms!!
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI checked on the web, they are called Sure-Wipes, made in Canada. I called all the stores you mentioned here in Buffalo, no one ever heard of them. I'll have to cross over to Fort Erie or Niagara Falls, they are JUST WHAT I NEED!. Should I try any auto parts store? Thanks for the info, it's probably cheaper to drive over, charge them and drive back than to pay shipping etc.
@#$$% wiper arms!!
johnd911 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXadditional? do you mean added to the current spring? or replacing the current spring. I went to a buch of auto stores and they were clueless about other springs. Please elaborate.
