Bro
Posts posted by Bro
  1. No, that's the pilot bearing. The input shaft bearing is in the front of the transmission and supports the splined shaft that the clutch sits on. I don't know of any other names for it, but maybe there are.
    So then you guy's are telling me that it's a tranny bearing ?
    I am doing a single range to dual range swap,as soon as the rain stop's.
    So this should fix the noise ?
  2. EA81, bit of a rumble when clutch pedal released, quite noticable in the cab and while driving. Depressed pedal makes the noise go away.
    Have searched here and numerous motor mechanical sites and have been told 50/50 GB/Clutch. and then I read that if the noise is there in neutral with clutch depressed, it's the clutch, and if the noise is there with the clutch pedal released, it's the trany.
    What do you guy's/gal's think ? I'm sure someone here has experienced this.
  3. just to add what I did, I only used one stock jack on a concrete block (for height) under the tranny and the engine was supported by the engine hoist. Lift both until the engine clears the mounts, undo the 4 bolts etc that joints it to the tranny, slide forward (raditaor removed) lift it out. (disconect everything to the engine beforehand of course:))
  4. If its an e81, you just have to carefully 'peel' it off, pulling out and upwards if i remember carefuly. You have to be careful not to kink it, or it wont go on again.
    Yes, EA81, MY83 Wagon. I have a parts car here that I might experiment on first, but would prefer someone who has removed it sucessfully, or what tools/techniques they have tried !
  5. Bro
    You can make an inline fuel return by going to a gas refiller e.g. BOC and buy a t peice, two 5/16 barbs and the smallest barb they have. Solder the end of the small one shut and drill it out with a 1mm hole. And youll need some hose camps aswell. I can take a photo if you need it just send me your email addy.
    I thought the Weber had the T piece ? Please send me the pic
    quombone@hotmail.com :) Thanks
  6. I have a Weber 32/36 with the return line deaded.And that it should be returned, but to WHERE ? I have read through umpteen posts and am yet to find an answer to were this fuel return line should go. Can someone supply a pic/a link/ or something to make me understand where this return line should go !
    I asked my local SunSpares Subaru repairer and have heard people talk of using the Hitachi return that just screws in, I have 2 Hitachi's here and don't know what their talking about ???
    I AM LOST :banghead:
