Everything posted by plumbermat
- Loyale not starting a week after timing belt swap
Swapped out fuel pump and filter to no help. Tried to start it and something made a pop sound in the fuel filter general area. Back to the drawing board. I did notice, however, when everything is zeroed in with the cams and all, the distributor rotor is pointing to the #4 cylinder rather than the #1 cylinder. Could this be the problem?
Hello fellow Soobers, thanks for reading. A couple weeks ago, the belt on the driver's side went, so I towed it home and swapped it out. (Cursing my air conditioner the entire time.) Bought the kit and replaced both belts and pulleys provided. I had help from an old timer with Soobs, and followed Milesfox's video on timing belts which was extremely helpful. It started right up and ran like a champ. The following week, however, it started to have a very hard time starting. Now it won't start. It tries, but won't turn over. Everything still lines up as it should, and the belts are still tight. I have since just started replacing things that have been an issue on other similar threads on this wonderful site, but realizing now that I am wasting my money fixing things that aren't broken. I have replaced the ignition coil, pcv valve, distributor cap, spark plugs and wires. I believe its a fuel problem. How to Keep Your Subaru Alive is a great book that helps, except for EFI topics.... Any leads would be very appreciative, thank you for your time.
Dash/Tail Light weird issue '94 Loyale
I had this exact same problem with my 91 loyale. Blowing fuses immediately. My problem was a couple wires touching each other behind my stereo. Isolated them and never happened again. Hopes this helps!
91 loyale exhaust issue, revisited
Hello, got some advice a couple months ago, but after replacing several front axle and bearing assembly parts, it was back burnered. My exhaust sound like a marble is rolling around above the front exhaust pipe right above the gaskets which i replaced. I hope I can post a vid on here... Any advice is much appreciated, I value your time.
91 loyale 4wd non-turbo exhaust tips needed!
Great thanks! A bit off subject, my buddy was looking at it while it had been parked at a slight incline for about an hour. 10 secs after he left, with it still running from looking, I left w my kids in R going steeper up the paved hill, it bogged and a huge cloud of SMOKE came out from underneath, not the engine area. I popped it I N, coasted back down the incline quickly, E brake; still running, layed down looked and it was billowing for about 10 more secs, and stopped. The R upward made a ticking sound as well. I popped the hood and spare, checked the tranny stick and it was low. Ran to napa got some Lucas, I hope that's good, filled it bit by bit starting it up in between, it hasn't smoked since then, last Sunday. It scared the crap outta me, she seems fine, I have tested R since, getting it up there, but too scared to test a hill again.
- 91 loyale 4wd non-turbo exhaust tips needed!
What does it cost you to run your car where you are?
Messed up on math. 325 mi per tank but I don't empty it every time, so I should consider it a 14 gal tank instead of the specs
I meant SOUTH
I live in Mount Vernon, WA state an hour north of Canada. I drive a 1991 loyale 4wd 5sp wagon. I get 20.44 mpg I think that's 8.69 liters per km 325 miles on a 15.9 gal tank 523.4 km on a 80.18 L tank...... Yeah I almost fill it weekly. (At least we didn't mess with the day measurements ) Yearly insurance - $632 USD Yearly Registration - $52 Every other month oil change - $18 One quart of oil in between - $2.80 (buddy @ Shell refinery) Every other year brakes - $38 About every other year tires - $160 @ $4 a gallon, I spend $11.54 every day to drive
My Soob, which I Purchased 3 months ago, it's exhaust is concerning me. It is a really clean car, I am in LOVE! I just want to prolong the life of her. I I do lite offoading, since it is also my commuter. This is the problem. It knocks loud when warming up, and when accelerating. When warm, the noise dies down, and is periodic. I pinpointed the noise when changing the oil, noticing it on the passenger side of the front muffler assembly exiting the motor. Remedies? Replacement? I am trying to avoid purchasing a catylic converter, but the only parts found online include it. Any help would be greatly appreciated, thanks for reading!
