87 Subaru RX idle air control valve
Okay sweet I live close by to that place I'll check it out thanks for your help everyone
This looks nothing like the part I have
Testing Idle Air Control Valve Solenoid
I'm have the same problem with my IAC in 87 turbo RX any know where I can another? Auto part stores in my areas all have the wrong one
Any idea where I can get a new one? I've been looking but no luck
So the idle on my car has become very irregular, at first it just sat at about 100rpm and I tried using the idle adjustments but they had no effect And my should be right I just checked right before this started Now though all of it sudden it idles at between 6-900 rpm just constantly going up and down up and down, if I give it a little throttle it smoothes out and sounds find but will try to die unless I back off very slowly. One of my friends said to check out the idle air control valve but I can't find it, so anyone have suggestions?
1987 RX drift project
My throttle response is HORRIBLE a solid 1-2 seconds of lag sometimes and I've replaced the throttle positioning sensor once already so if anyone has ideas before I start replacing more things it would be nice
RWD 87 RX
Do you know what kind of trans I can put in to make it last??
RWD 87 RX
Okay I'll try that soon thanks for the help
RWD 87 RX
I'm looking to convert my RX to rwd and I was wondering if any one could help me out on what I need to do
DangerDussault
