2
Everything posted by 1000 Pistes
VIN code Identification
1000 Pistes replied to 1000 Pistes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1000 Pistes replied to 1000 Pistes's topic in Historic Subaru Forum: 50's thru 70's
very sorry..... I am mooving... -
I need some help to identificate the details of the VIN of some 1985(?) Wagon JF17AM21FAG204204 Any help welcomed.
To check the pressure of the fuel pump you have to press, by a bence,the returning hose of the fuel. If then it is Ok,it is a fuel pump failure. Otherwise you have to check the front lambda(oxygen)sensor.
Help with wheels for my 78 Brat
1000 Pistes replied to Grisezd's topic in Historic Subaru Forum: 50's thru 70's
If I remember well the Peugeot 504 was equipped with 14' rims(Dunlop style) and the 505 with 15'. -
my 1973 DL 4door Sedan has 4 drums and I think there is not residual valve. there is,only,a brake line spliter... I would like to put a tandem M/C using the equivalent spliter.
Using larger rotor size you must use and the equivalent calipers or caliper adaptors....
what exactly is the residual valve ?????
and still used the same tandem master cylinder without servo??? the master cylinder is 3/4 ????
Just First Generation Subaru Photos!
1000 Pistes replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
No other photos ????? -
Your 1974 DL Sedan was originally equipped with all wheel drum brakes????
Some other photos in some of the beautiful SUBARU paints of the time? I saw some samples but it's different thing to see 'em in "real" cars... http://www.uniquecarsandparts.com.au/colour_swatch_subaru_1969-75.htm Vital Orange, Herald Yellow, Canyon Gold, Beat Orange, Bub Yellow, Vibrant Green, Brilliant Red ,etc. -
Nice and rare colour.... More vews from this beautiful car???? -
No one knows something about this car????? -
I'd like to see some pictures of the early 1st Generation Leones in VISTA BLUE( colour code 41)paint. -
LEONE 70s 5gear gearbox ratios
Probably this is not recomended for highway use.... I found this gearbox into the FIA Homologation Form of the era... I need some help even to build from blank some gearbox as above. -
no replies???? -
I need some help to identificate the details of the VIN of some 1985(?) Wagon JF17AM21FAG204204Any help welcomed.
I am a little bit confused. I have in mind to build a 1973 4Door Sedan as rally car of the era(VHC). I must use the EA71 engine(fat case) and I have to use some 5speed gearbox with the closest possible gear ratios(for rally use). To build some custom gear ratios to be used with the top starter 5speed EA71 gearbox,it is very expensive to me,with unknown success(reliability). In other hand I am searching if there is some other SUBARU FWD 5speed gearbox with close ratios to be used directly with some kind of adaptor.....
