Everything posted by Starlite
Loyale 89 front bushings
Has anyone ever put a block heater into an EA82?
Best and easiest option is to install a hose heater. But why a battery heater? I have never heard of that before.
H6 2007 vibration
So i have change passenger front axle and got a vibration when in Drive or Reverse. Google it and found out it is a known problem with aftermarket shafts. But If i only change the outer joint Will i still get a vibration?
Pulling to right.
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo this will be the second time at the same shop. But do you think the specs looks okay on the second picture? Have start to see sign of tirewear on the outside of the right wheel. One guy told me there should be more minus on the right camber than the left. Now it says -0°33 on Left camber And -0°14 on right camber. Should be -0°14 on left and -0°33 on right.? And what makes right sai (kpi) go high?
Pulling to right.
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCost me about 130 dollars so i will make them do it again.
Pulling to right.
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf i let go the steering wheel the car pulls to right.
Pulling to right.
Hello i have a Legacy 3.0 2007 saloon wich pulling to right. Before the first wheel alinment the steeringwheel was as it should be but when i let it go the steeringwheel pointed about 5° to the right and the car goes at the same direction. Had a wheel alignment but there was not much to do because the rear link adjuster was rusted. Well i changed it with new bushings and bolts and new strutst and shocks back. At the front i replaced all the bushings at the transverse link, new front stabilizer and new bushing stabilizer. Had a new wheel alignment but still no good. Now the steeringwheel points 5° to the left when i drive straigh. And if i centerd the steeringwheeel the car goes to right. this is the wheel alignment specs in Swedish. Vanster=Left Hoger=Right
Connectors under steeringwheel
- Connectors under steeringwheel
Hello i found a green and white connectors in my My07 legacy 3.0 under my steeringwheel. Is the green connector supposed to be connected or not? The green os connected and the white is not.- Fuel pressure 2006 3.0R
Starlite replied to screwbaru2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI might having the same problem. When turning the engine on it rotate about 8-10 times before start and sometimes only 2. But i also having this misfire sometimes only in the starting procedure. Runs great when driving with no misfires and no lack of power. Where do i find the check valve on my 2007 3.0?- What head gasket to use?
Now im getting tierd. Second time headgasket failure. Next time i will change engine to another one from my spair part car .....with headgasket failure.- What head gasket to use?
Today when driving i hear this woshing running water sound from the heater core. Open the hood and noticed the coolant level on the expansion was about 1-2 cm higher than usual. Open up the radiatorcap and expected an explotion of coolant but nothing.- What head gasket to use?
Two times i have changed the headgaskets and i see this again. There was nothing in the begining but now its increasing and i have to ad about 1dl cooland once a week. Its just the same as the last time i changed headgaskets.- Ignition timing adjustment issues
Is there a way to test them?- Ignition timing adjustment issues
Update. Well i found out the problem. As in swdeden we say Handhavandefel (mishandling or personal screw up.) The setting on the light gun was not set correctly. Now it runs and timing is right. But now having this hard starting problem. At the morning when going to job it crank onte time and start. One hour later when start it crank crank crank crank crank and then start but runs bad for two seconds. Like poor fuel delivery. Cts sensor is new. Maf sensor is changed from a donor car. What is the most common problem?- Tapping noise from heater?
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont think there is some debrie in the fan . This is something else and when i shut down the car i can hear some strange noise from the heater.- Tapping noise from heater?
I have this noise from the heater on my 3.0 2007 legacy. Play it loud and you will hear it. https://youtu.be/qlw3ubT2gz0- Legacy 3.0 2007 misfire
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIm running the tourque app and noticed the O2 volts bank2 sensor 2 is pending. The graph is not smooth as the Bank 1 sensor 2 so there is something wrong there.- Oil leak Ez30d
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont realy know..its hard to see but its all soaked in oil and dust.- Legacy 3.0 2007 misfire
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe symptoms i have is.. Misfires when warm but not all the times. When driving and make a kickdown a white cloud will appear behind the car. Do a kickdown again and no cloud appear. And this happen only one time when driving the car. Do not leak or dissapear water from the coolant overflow. It did before and i cahnge the radiator cap and it stop. Throwing pending code p0174. Do not overheat, never have. Me myselfe believe its a cracked head or headgasket. 16000km (9900 miles) Have changed the mufflers and noticed alot of water in them. There is no coolant smell in the exhaust.- Legacy 3.0 2007 misfire
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat symptom did the car have? Was this a 3.0?- Ignition timing adjustment issues
Yes i have done this, marked on the dissy where the dots is. Btw there is impossible to install the flywheel in the wrong position. Its only goes in one way, have tryed that when installed the flywheel.- What head gasket to use?
Update. Headgaskets was installed and heads resurfaced ,engine runs but have this timing adjusting problem. Today i noticed water on the oilcap. Wth i think not again, second time i replaced the headgaskets and the problem is coming back again. Heads look good with no visible cracks. Is there somwhere else water can leak in to oil?- Legacy 3.0 2007 misfire
Starlite replied to Starlite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFinaly i have a pending code. P0174 powertrain system too lean (bank 2) Found another thread about this code and that guy changed a faulty AF sensor.- Oil leak Ez30d
My engine is leaking oil from this thing (both sides) What kind of a sensor is this? - Connectors under steeringwheel
