Everything posted by soopsoop
passenger side rear door
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit was the latch,someone tried jamming the child safty lock and screwed it all up. went to junkyard and bought all the parts for 40 bucks and after 2 hours it was all fixed.
things don't work
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe dealer fixed it for free and free is good.
cabin air filter.
does my 2006 impreza have a cabin air filter and if it does where is it?
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfixed it finally,the child safty lock was jammed as well as the rest of the latch like someone tried to break in and jammed it.
Hawkeye Impreza Inquiry
soopsoop replied to GearSpeedKelvo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan i put a hawkeye in my 06 impreza if it doesn't have it?
back from the dealer
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot the rear passenger door open at last the child safty lock was jammed and the latch was broken went to whiteys wrecking paid 45 bucks for a used one had it installed myself in about one hour,works great now.
stupid insurance
i have extended warranty on my 2006 impreza the only problem is it costs 115 bucks for them to read the test engine light and fix the problem. so i went to autozone for free and it said third cylinder miss fire could be plugs,wires or coil, so i did the kiss pricipal and changed the wires first after checking with an ohm meter found out the no.3 wire was bad. changed the plug wires and no more miss fire and it has lots of power. but i remember the stealership swearing they did a tune up now i am wondering what else they skipped on.
why won't my aftermarket radio work?
i hooked everything up like i was suppose to, except the wire for the power antenna, why did they call it that? should have been called antenna amp wire it would have made it a lot easier to figure out. any way hooked that wire bto the 12v switched wire and i get lots of stations now thank God for usmb i read through the different topics and found others with the same problem.
aftermarket radio
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso i found a wire with the ant connector on it but the radio only picks up local stations it is a thin wire it might be an aftermarket ant extension. there is also a big black wire that looks like a ground it is not a part of the plug in harness,i will try to trace it down to seed where it goes,the radio works without it as there is a ground in the plug in,i am thinking someone added it later as an auxillary ground.
aftermarket radio
i am putting an aftermarket radio in my 2006 impreza it had a jensen radio in it but the p.o. took the knobs with him when i pulled the jensen out i got all the wires figured out and the new radio works except it won't pick up many stations i think it is the ant wire. the only wire i couldn't figure out is a big black wire that goes to a ground,but the radio works so i am not sure i will tinker with it in a little bit . and i am going to find out what bulb goes behind the tempurature gauge i am thinking a t5 . and i fixed the back door passenger side it opens and closes and locks and unlocks like it is suppose to. thank God for whiteys they had three 06 impreza at their wrecking yard. 26 bucks later i had my parts.
throwing belts
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell it is close to 180,ooo miles and it is still running. the only problem i have had since then is the wheel bearing in the drivers side rear,it went out and my roadside assistance only paid for 25 miles(what the hello). so i fixed it at les schwab for 300 bucks. i think i will change the passenger side rear myself. by the time i get it into the dealer and have them diagnose it would be a lot more,damn insurance.
2006 impreza back door passenger side.
i finally got the door open,it wasn't pretty but nothing is broken,what a pain in the rear. the problem is the latch assembly is toast,the stealer want almost 150.00 bucks for a new one,where can i find a used one? it looks like someone else tried to fix it and jammed the cheap plastic gears or what ever is inside. i am going to call larry h. miller where i bought the car to see if they can at least get the part for me it is still under warrenty or what they call a warrenty.
slow in the morning
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi took all the cables off and replaced them with larger cables. it was probably corrosion but problem solved.
2006 impreza rear noise
it was the rear drivers side bearing it could move in and out at the top of the tire about 1 to 2 inches and the road side assistance only paid for 25 miles of towing and larry h miller was 67 miles away plus it would cost 100 bucks for the insurance company to come to the dealer to ok the repair and have the car sit for a week while they get the right parts i couldn't afford that so i had les schwab fix it for 365 bucks fat lot of good the "extra insurance" did me, damn . but it is fixed now it doesn't look that difficult i will fix the other side myself because if on side is bad the other can't be to far behind.
rear axle bearing drivers side
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have road side assistance but it is only good for 25 miles and 20 bucks a mile after that and it is 67 miles to the dealer then it will cost 100 bucks for the deductable and they will take a week to fix it and i would have to pay for a rental and they would reimburse me eventually so since it is at les schwab in colfax they will charge 300 bucks to fix it and i can pay them next payday and it should be done tomarrow. i figured that was cheaper. why did i pay for the extended warrenty,it is a ripoff.
my rear axle bearing went belly up are they easy to change? or is it a hub assembly? i tried u tube but all they tell me is about legacy and mined is a 2006 impreza.
found out what the rear noise was. the rear wheel bearing on the drivers side is going out, it started to make noise leaving work and it got bad so i pulled into les schwab in colfax and they put it up on a lift and grabbed the rear tire on the drivers side and they could wiggle it around about two inches or so. i am going to call larry h. miller in spokane to see if they will fix it ...again. if they change one should they change on both sides?
what antifreeze
i need to change my antifreeze in my 2006 impreza someday or just add more,do i have to use subaru antifreeze and conditioner or is there a suitable substitute?
i have a 2006 impreza that has a noise coming out of the rear of the car. it sounds like a wheel bearing and only does it when its cold,could it be the wheel bearings or something in the rear diff? the car has awd and four wheel disc brakes.
brake problems
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe first posting was about a 91 legacy that car was totaled in a wreck(woman on a cell phone hit the front of my car). the 88 is about a freebe car i just got.
rear passenger side door won't open
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow do i pull the panal off when the door is closed.
what is the operating system?
i have a 2006 impreza and was wondering is it obd2 ,can ,or what?
front bumper cover
i have a 2006 impreza that i bought used and the front bumper cover is broken. can this be replaced or do i have to replace the whole bumper?
Doors and hatch won't unlock
soopsoop replied to joalrabr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit is easy once i get the screw out up by the top front corner,that's going to be the tricky part
fog lights
soopsoop replied to soopsoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit was a ground wire. they also have an aftermarket radio with a dvd player in it and a switch to watch dvd while the car is moving it took the switch out and the ground wire out it looks a lot better now.
