LuvScooby
Everything posted by LuvScooby
Thanks again for the input. I'm gonna try some 10-30, and another can of seafoam. Which stands to make more sense to you all....running a thinner oil to prime the HLAs, or a thicker oil to prime them? I guess I was of the mindset that a thicker oil would be better...less apt to drain out as quickly.
Thanks for all of the input! When I did the gaskets, I put non metal orings in the cam cases, but later put metal reinforced orings in, but there was no change in lifter clatter. I have driven several thousand miles since I put the new orings in place. I have tried seafoam, but I will try it again. I also used Lucas treatment, and that made it a little better a couple of times, but didn't last, nor did it make it go completely away at any point. I heard there was a bypass spring in th oil pump that needs to be cleaned from time to time. Can I access this without removing the pump? Anyone know where I could find a pic of it? Cam cases have been thoroughly cleaned as well as oil tubes, etc...Lifters just arent priming up properly on either side. I recently pulled into a local garage to check on a muffler, and there was a mechanic who came flying around the corner and he said "Man, that don't sound good...". I explained the whole ordeal and in the end, he was clueless.
Hello to the board...I am asking for your help. I need advice partaining to my 88xt, and the ea82 in it. I bought the car with bad head gaskets. I replaced the gaskets, and resealed the oil pump. I had bad lifter rattle. I bought Mizpah lifters, and put them in...still have bad lifter rattle. I installed a manual oil gauge. I have 25psi at warm idle, and 55psi while driving. If it matters, the oil pressure will climb over 80psi when I first cold start the engine. I have put several thousand miles on the car since the work was done, and it seems to be running ok, but the lifter rattle is so loud...its not going away. I have used all diff grades of oil, but nothing solves the problem. I seem to have plenty of oil in the valve covers, so I dont think there is a blockage, but I cannot verify this for sure...if there is a blockage, it is causing issues on both sides of the engine due to the sound of the lifters. If the oil pump was shot, would I still get these types of reading on my pressure gauge? Im about to buy an oil pump, but wanted advice from all of you before I spent the money. What do you think? I don't know anything about the cars history...if it matters. Thanks in advance for any insight.
I replaced all three of the seals you mentioned Gary. I personally have never pulled the oil pan on this car. I have no clue if it has ever been off or not. I honestly didn't look at it very closely when I was under there. I kinda wondered about the screen on the pickup. Im kinda wondering about all of the sludgy additive crap I found when I opened the engine. I guess I need to pull the pan and check the screen and look for any other debri in there. I bought the car with the head gasket issue, and was actually afraid to run it for fear of doing damage. I started it and drove it onto a tow dolly to tow it home, and drove it off of the dolly once home, and then backed it into position to work on it. I remember it didn't idle well, kinda low...had to pat the gas to keep it running. I also remember it had 'some' lifter tick, but not like now. I wish I could remember better. It definately had some issues, but at that time I just assumed it was all headgasket related. So it has run 'sickly' since I've had it. The thing that just kills me is that at one point, with the origional lifters, after the new headgaskets, I had this car in time, and had no misses, and took it for several pretty good drives, and it was very smoothe....aside from the extremely loud lifter rattle, it seemed to be doing pretty well. I know that there was still something not right, but I just cant seem to get it back to where I had it even...just a little irritating.
In reguards to the spring and the return valve...Is that the spring in the oil tube assembly? If so, I did at least remove the spring and clean the whole tube assy with contact fluid. I made sure that the tube was clear and fluid would pass thru. Is that what the relief valve assy is? I guess I can go up and pull the heads off the 'unicorn' since it doesn't look like I'll ever get it running. I can have them totally rebuilt, since theyre not turbo heads. Then I can just buy a new oil pump. Grrrrr...
Thepartsbin is where I ordered the first set of orings that I 'lost'. I ordered from them again, and they were the ones who said that they didn't have any, and didn't know when they would have them again. I placed the second order, and just never heard from them...kinda made me ill. The closest subie dealer is, I think, 30 miles or so from me, so I just took a stab with the basic orings...although I didn't want to. If I go back in again, which it looks like I'm going to, I'll put the metal ones back in for sure. I did use felpro head gaskets, because luckily I had seen a post somewhere about having to retorque other types. I knew I didnt' want any part of that. I think I'm in good shape there. I 'think'. The debri in the cam cases doesn't make me happy, but shouldn't it have to pass thru the filter before it can be pushed into the engine again? I thought it went from pan to pump to filter to engine...or something like that. Does any oil bypass the filter? I hope any oil in the cam cases has to pass thru the filter before recirculating...but like many, many other times, I might be on the wrong track again. I dont mind trying to drive it a little more, but as of now it runs poorly because I can't dial the timing in properly because of the poor valve actuation due to the lifters being down. Kinda endless circle. I fear that I am going to have to purchase new oil pump, and pull the heads again, and have them completely rebuilt, and do the whole thing again...in the gravel no doubt. Haha...maybe thats what I get for taking the chance. Any other advice? How about hand priming lifters? Whats the right way to do it?
I did let the lifters stand upright and submerged in a container full of clean oil for nearly 48 hrs. before the install. I tried to 'prime' them by pressing down on the tops while they were submerged. I could move them very little, but I dont' know if finger pressure is enough to prime them...can anyone tell me? Keep the ideas coming!
I have probably put 20 to 30 miles on it. It just isnt getting any better. I ran it upwards to 4500rpm for a little bit. I'm just perplexed at this point. I didn't use the metal inforced orings between the cam case and the head because my parts supplier said they were unavaiable. I just put regular orings in their place. Thats what they used at the Subaru dealer according to my friend. Neither set of lifters would pump up correctly, so it has to be something other than lifters, huh. The previous owner had used that 'head gasket repair junk' that you pour into your radiator, and there was a good deal of that crap in the engine...I just wonder if I have a blockage in the galleys...but on both side??? I just don't know.
Hello room. I haven't posted in quite a while, but have been ever-lurking. I wanted to update my xt woes and get the opinions of all of you. I have an 88 xt dl that I put head gaskets on last year....bought the car that way. After putting her back together, the lifters would not pump up...even with 60+psi of oil pressure. Got remanned lifters from Mizpah, and put them in. Lifters still not pumping up. Ran the engine at around 2800 for 10 minutes, and still not pumping up. Bad/loud lifter rattle...on both sides of engine. Unable to properly adjust timing because of poor lifter pressure. SO.....suspecting that I had botched something up, I towed the car to a guy who was the lead mechanic at the 'used-to-be' local Subaru dealer. He now works from home, and has a pretty nice garage at his house. He's had the car for 2 months due to some family/health issues on his end. He called me today and said that he looked at the work I have done and t'belts and dizzy seem to be dead on. He said it looks like I did everything right. He pulled the valve covers off to make sure all of the rockers were still in place, and they were, but he said he could push the lifters in by hand easily, and he said that this, of course, is not right. He said that there appeared to be plenty of oil in the valve cover and on the compenents inside to lead him to believe that there was adequate oil flow. He said there were bits of rtv type sealant in the valve cover...left over from my cam case install I'm sure...and he wondered if there were blockage issues due to that. But...these are the mizpah lifters that I bought because the other lifters would not pump up. So...clogged lifters both times??? I just don't know...I kinda doubt it. What, fellow roomies, do I do now?? My subie mechanic says he really doesn't know whats wrong either. He mentioned ''NEW'' lifters. I have faith in this fellows abilities...I told him I didn't want extensive work done on it because of my available funds. After talking with him, he genuinely seems like a great guy, and I just don't think he's giving me any BS. Whats going on here? There has to be something I've missed. What now?
Anyone done a turbo to non turbo swap?
LuvScooby replied to LuvScooby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm gonna try to get the codes tomorrow!! I'm gonna go so far as to say that, yes, someone did a full swap on this one. The drivetrain now looks just like the one in my 88DL. There is no mechanical turbo stuff left in the engine compartment...at least nothing major. There is a relay or solenoid that ticks like crazy sometimes...its on the passenger side inner fender. -
I'm pretty positive this is a post 87 engine. It does have the spider intake, and of course the multiport heads. There are no provisions for a turbo on the current engine, and the exhaust has been properly swapped to a N/A y-pipe. My fuel pump comes on when I turn the key, and I have removed the post filter fuel line and pumped gas from it when the turning the key, so I think I'm good there. Is there a way to siphon the gas from the filler neck, or is there some sort of baffle that would prevent me from doing so? I was unable to get a hose in far enough to get any gas out. I have verified that I have spark...for sure. I'm fairly positive I have compression, but would not swear to it...had a little trouble getting my compression gauge fittings to seat properly. I have no clue if the injectors are the right ones or not. I cannot remember the codes...I will try to check this weekend. The engine turns over really well...if that means anything. I've learned a great deal from the 88 that I have, and I will try to double check all of the basics on the 87 now. Maybe I made a mistake somewhere. I suspect ecu/injector issues. Stay tuned!!!! -
Hey Gary. Yep, the pump cycles. It builds lots of pressure, but never seems to pass thru the injectors. I never smell gas. There is definately bad gas in the tank, but I have no idea how much...it smells very old, but I can't even get it to hit on starting fluid. I just don't know if the ecu was ever swapped or not, or if the harnesses are correct. I have spark, and fuel at the injectors. I read the codes, but its been several months back, and I will have to recheck them. I remember that there were a few. -
Hey everyone! I'm getting ready to start back on an older project that had me stumped a while back. I bought an 87 1/2 XT turbo gl10.(Not running) The turbo engine and turbo extras have been removed and replaced with a N/A ea82. I don't have any idea who did this, or how many years ago it was done. I have done all of the tune-up items on the car, and set the timing by the marks, and replaced the fuel pump. The car still will not even try to run. I have spark, and I have fuel at the injectors, but I do not thing the injectors are being told to pulse. I do not know if the car has ever run since the swap was done. I just wondered if there was anyway I could tell if the ecu was the origional turbo ecu. Does anyone know how to identify this? This car has a near perfect body, nice interior, and is loaded with options, and I would love to be able to put it back on the road. It barely has 100k on the body...its a shame for it just to sit there as it has for at least 5 years now. Any other ideas would be greatly appreciated. I'd like to put a 2.2 in it, but surely that would be a huge undertaking.
Thanks Mike. It's a fwd. It just kinda 'wierds me out' to know that I'm running those kinds of rpms just trying to cruise to work on the interstate. I guess it's kinda normal huh?
Hey to all! I took the xt out on the interstate today just for a few miles. At 70mph, I'm turning about 4100rpms. It's a 5speed manual. I was just wondering if anyone could tell me what the ratio is on these cars? It's an 88xt...ea82 non-turbo...5 speed. If I ever get the car running properly, what type of mileage could I expect to get from it? It has 144,000 miles on it. I would imagine that the high rpms at interstate speeds hurts the mpg. Thanks in advance for any insight!!
Hey Tom! I just went to 'thepartsbin.com' this morning, so you might try again. Maybe it will work. http://www.thepartsbin.com/catalog/products.php?year=1988&make_text=subaru&model_text=xt&category=engine_mechanical&subcategory=valvetrain See if the link above will take you there. I'm no computer guru, so I may have done it wrong. If it doesn't work, go to the site, enter you vehicle info, scroll down to 'engine mechanical', and then look under 'valve train'. That's where they are. I just bought 2 myself. Be aware....you have to order two(2)....they don't come that way. Just don't want you to get only one in the mail...that kinda sux. I think you definately want to do this when you do the t-belts and o-pump. You have to have the belts off and cam pulleys and inner belts covers, so this is the best time to do it. There are 8 housing bolts...4 are outside of the case(2 on top...2 on bottom) and 4 are inside the case(2 on top...2 on bottom). The 4 in the case are near the outter edges, and kinda close to the corners. The case shouldda been assembled with some type of sealer on the 'head' side, and may be hard to get loose. If you back your bolts most of the way out, you can 'tap' the case with a 2x4 and maybe even have to hit the 2x4 with a 'Thor' sized hammer. When you see it start to loosen, you can reach in carefully and pull out the rockers before they fall out.(and they will). If you are able to pull each one out, you can mark them and put them back where they came from. If they do fall out, I don't really think it matters...its just best if ya get em back where they were. Well, that's enough to get you dirty, and make your back sore...haha...good luck...just take your time. Oh yeah...watch out for the side of the cam lobes....they are very, very sharp....I got a pretty good cut from one of them!!
ea82 lifter questions....
Well, I decided to start the car this afternoon...just to see if anything had changed. I still have to replace the o-ring in the other cam case too, but I just wanted to see...It's still very loud, but it seemed to be running better. It idles at around 1100(manual tranny). I think that's too high. The distributor was clockwise as far as it could go, and the timing was near 35degrees(timing light). I know it should be around 22 or so, but it was so smooth that I took it down the road. I can tell that I am at least running on all 4 cylinders now, whereas acceleration was much better, and there was no flat spot in the higher rpms. I only went about 10 miles because the car is not registered now. The temp was good, and it accelerated well, just still loud as heck. When I got it home, I turned the dist enough to bring the timing to around 22degrees. I took it down the road again, but it wasn't as powerful as before. Wonder why? What do I have off? Ahh...I didn't reset the timing with the plugs in the trunk...crap! I can't remember exactly how to do it. -
Ha Ha...okay...I found my o-rings. I didn't rtv the old ones...I wouldn't have untill I found out it was acceptable to do so....I was just wondering if it was okay...Thanks a million for the warning! The old o-ring broke into pieces when I took it out. It was definately flat and crunchy. I took the carrier off without taking the fan, pulleys, belt covers or anything else(except the intake boot). I thought I could save a little time. Let me recommend NOT doing this. I have come to despise pulling the fan and crank pulley, etc....but I broke my rear timing cover while trying to reinstall the carrier. Well, I actually had the carrier back on, but I broke the cover while trying to reseat the gasket on the back side. So I will have to take all that crap off anyway. I even managed to get the belt back on the pulley, but alas, I am afraid it may be a tooth off. I knew better. So class, do it like you know you're supposed to...I just wont get it done this weekend. I sure hope this fixes the problem. -
Wow...thanks for the great ideas. The car had bad h-gaskets on both sides when I bought it. I towed it home, and ran it very little. I don't recall any specific lifter noise....at least not nearly like the noise that I have now. I seem to have noise on both sides. Also, when I first put the cam cases back on, I did NOT replace the metal o-rings...they were not in the felpro gasket set I bought. I bought some thru 'partsbin'....but now I cannot find them. I wonder if I could carefully seal around the ones that are in the cases now with rtv? I know that's hokey...but I have the passenger side torn down now, and I really dont like the thought of leaving it apart while waiting for the o-rings to arrive. After origionally putting the heads etc back on...I had a miss, and finally found out that I had no compression on the rear passenger cyl. I feel its because the lifters are not pumping up enough to operated the valves. I took the hlas out the first time, and they could not be depressed by hand...not any at all. I put them in a vice, and they all depressed that way. I then popped the caps off and pulled the 'spools' out and flushed each one with contact fluid. I then put each one back together, and made sure each one went back where it belonged. They just never pumped back up. I thought that maybe I had damaged them or something so I ordered 'new' ones, but once I pulled my old ones back out, they seem to push in as easily as the new ones...so now I am doubtful that I messed them up...they just never pumped up. Also...does anyone have any secret to getting the cam cases on without dropping the rockers? I swear...the first time I reassembled the heads...in the car...I was able to hold them on with grease and somehow get the cases on without knocking a single rocker off, this time....no such luck. Man that is so irritating! I guess I need to wait untill i get more o-rings anyway... -
Greetings to all! I am in need of advice. Recently bought an 88xt/dl with blown head gaskets...of course... I replaced the gaskets myself, but developed a severe case of lifter CLATTER!!! I have done several oil changes, tried thicker oil...thinner oil...additives, but nothing has cured it. I resealed the oil pump, and bought an aftermarket gauge, and I have loads of oil pressure. I took the lifters apart when I had the heads off, and I cleaned them really good. I soaked them in oil, but thats about it. They are not pumping up. I bought another set of lifters from Mizpah, but when I pulled the old ones out of the passenger side, they moved very freely, and I don't think they are bad. Is there a priming procedure that I need to perform on these lifters? I think all of my o-rings are in place between the head/cam carrier, although there are a couple of places where it looks like there are oil ports that have a very flat surface where no o-ring could possibly go. I'll try to get some pics tomorrow. I saw somewhere online while looking at remanned suby engines that some engines required ''pressurized oil primer'' performed before operation. Can anyone feed my brain on that one? Thanks in advance for any ideas!!
Grrrr!!! There is no drain for the gas tank. I have also tried to get a hose down into the tank, but that doesn't work either. I don't know if there's some sort of 'block' to prevent this or not. I guess I'm gonna have to drop the tank. I also pulled two injectors and fitted clear rubber hose on them, and cranked the engine. There was no gas whatsoever, so I at least know that much.
I cannot find the resistor pack anywhere!! I'll keep looking. I snapped a couple of pics, but I don't know how to down size them to post them. I'm afraid they'll be HUGE!! Also was unable to drain the tank due to no drain plug, and I couldn't siphon the old gas out either. It seems as if there is something in the lower portion of the filler neck that keeps hoses of various sizes from passing, or so it seems. Man, I don't want to take this tank off.
Seafoam....I've heard of it, but haven't seen it. I will look for it this weekend for sure. Now when you say 'reset' the timing with the green plugs plugged, do you mean to just crank it over for a few seconds? If so, does it matter if the spark plugs are in or not? I'm sorry if these are basic tasks, but I just want to make sure I'm doing the basics right. I guess I should do a search for the procedure. Any info you have time to type out is a great help. I'm learning...hehe... I don't ever remember seeing that resistor bank, but now that I know what it looks like I can try to hunt it down. I tried pulling one of the injectors out several months back, and it didn't want to come out. I didn't try to make it. I'll try it again, but I think I'll try to drain the tank thoroughly first then add some fresh gas and some seafoam. Thanks so much for your suggestions!
I have used the green connector to check for codes, so I'm okay with the location. I don't think my fsm tells anything about the need for the green plug while timing, so I know that has not been done. The timing belts were wrong when I got the car...they were new, but were on wrong. I set the flywheel on the center of the 'lll' marks and set the passenger cam mark to the mark in the cover. I rotated the crank 360 and lined the other cam up to its mark too. When the flywheel is turned to 20deg., my pass. cam is 45deg left of straight up, and the other sprocket mark is 45 deg right of down. Isn't that right? I could be confused. I will have to get an adaptor to run a comp. check, mine won't fit. That's on the list of things to do. The list grows and grows...haha...keep the ideas flowing, thanks!
I didn't check timing with green connectors plugged. I have heard of this procedure, but I don't know how to do it. What will be different with the connectors plugged? How do I check the timing with them plugged? That is something I am not sure of. I checked the fusible links, but I don't know about the resistor pack...I'll look for it. Thanks.
