Everything posted by Rhen2016
Too much rust?
Rhen2016 replied to vtwinjunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a similar rust problem and was worried about the frame integrity. NY State rust belt car. Found this product online-- https://www.theruststore.com/Rust-Converter-Gallon-P40C10.aspx Used a wire brush to remove some of the superficial rust and applied the product as per directions. After drying, noticed a few areas that needed a second coat. I'm happy with the result, and feel relieved that the rust is arrested. I didn't feel the need to top coat with POR-15, but if you have the time that would be an awesome way to finish the job.
a/c shuts off, then works if I start the car again
Rhen2016 replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe pressures look good. Use a feeler gauge and measure the clutch/cover distance. Too tight and the clutch may not release/cycle. Too wide and the clutch stops engaging as you drive.
Rhen2016 replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"how much refrigerant did you put in the system?" ----what's the reading on the low pressure side?
Discount Subaru Parts
Rhen2016 replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLately I've been using www.parts.com for my Forester and other cars. $13.07 plus 10.99 and 2.00 shipping/handling for part 809218370. They stock parts for most Makes and Models.
replace battery and car won't start?
Rhen2016 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDidn't see grossgary's update. Ok, so it was due to a blown fuse.
2010 outback overheating
Rhen2016 replied to Norazburu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst off, only use a OEM thermostat. If it is the head gaskets, then you can check the decks for warpage using a machinist's straight edge. If out of spec ( >0.0025") , then a machine shop will have to machine the heads flat. From your description of things, overheating and 'puking' coolant out of the overflow tank points to head gasket failure.
Rhen2016 replied to Norazburu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEver had the engine overheat before this happened? If so, the heads could have warped causing a premature head gasket failure. Was any work done on the head gaskets before?
