Everything posted by scorpiankill
Stop light checker test
I have an 87 gl wagon. It sat for a couple of months and I have recently got it back up and running. Now none of my brake lights work. I put in new bulbs (1157) in the sides but not the light on the gate. I cleaned the connections in the back and the one at the brake pedal. The brake pedal switch is working correctly and sending power. How do you test the stop light checker? Does anyone know where I can buy a new one?
Ea82 clutch lube
Not yet, I haven’t been home to look yet
Ea82 clutch lube
I have heard people say to always lube you clutch fork and throw out bearing. I have never done that and was wondering if it’s something you should or shouldn’t do? I’m changing mine out now and was just curious if anyone else has some more insight?
Air bubbles in radiator
I was looking at the head and those threaded bolt holes actually run all the way down to the head bolt. So I'm going to go get the heads check and cleaned
Ok this was my first time pulling the heads so I dont know what exactly stripped the threads. I put oil on the bolt threads and tightened them in 3 steps. I have been chasing leaks. Started with thermo gasket then throttle body then it started shooting out of the holes. I am going to take this head in to get it checked for warping and for cracks
When I was taking the head bolts off they all looked fine. It was the one on the top front of the engine. When I went to put the head back on, one of the bolts started to tighten and need more force to move it. It all of the sudden got super easy. I pulled it off and the bolt now had the threads from the head on it. I used a helicoil to fix it.
I didnt take the other head off because we needed room in the garage. Also when I changed this one I had a million problems. I had to replace the intake manifold because a bolt got stuck in it. 2 head bolts somehow stripped the threads on the block. I was thinking of changing the other. Just wanted to see what others might think of it. I'll pull it in and change it out
My 87 gl has air bubbles in the radiator. I let it bleed for over an hour so I know it's not airpockets. I have replaced lower rad hose, rad csl, driver side head gasket, throttle body gasket, thermo housing gasket. It's not loosing coolant. It's not over heating. It's not leaking any visible coolant. I put white paper under the car and the only that fell to the ground was oil. No coolant coming out of the exhaust. I originally thought head gasket but it has no symptoms besides the bubbles. It was shooting coolant out of some holes on the passenger head. On the top back corner. I put bolts in the holes so nothing is coming out. I'm at a loss of where to look for it. I'm thinking of putting in some coolant leak stuff to see if it fixes it. I figured before I try it I would ask others to see if they have some ideas
Coolant leak from hole in head
I know this is an old post but I think I have the same leak. Is it two threaded holes that are 90 degrees from each other? In the back upper corner of the head?
Oil relief valve
Thanks DaveT I know everything is being lubed up how it should so I was gonna drive it around see if it quiets down
Oil relief valve
I took out the whole valve. I saw that the small bolt hole flap was leaning to one side. I straightened as best I could. Oil is going directly onto the cam now. It should be getting more than enough lube. The sound seems like it's coming from the valve itself or the lash adjuster. When I took the cam out before all of the rocker arms fell out. I didnt put them in the right spots unless randomly guessing worked out. If they weren't in the right spot could they cause a loud tick?
Oil relief valve
The head gasket was put on correctly no holes showing and all the edges line up. I took off the valve cover and cranked it. The valve was shooting out a good amount of oil. It wasnt however shooting it directly on the cam that makes contact with the rocker arms. Its hitting the cam a few millimeters to the side of it. I'm going to loosen the bolts on the valve and see if I can slide it over to line up
Oil relief valve
I'll look today and see
Oil relief valve
It does get a tiny bit of oil because my valve covers love to leak. The cam has the tiniest bit of oil on it but I know it requires way more to be lubed correctly. The head gasket i bought couldn't be put in backwards. It wouldn't fit. I'm going to take the cam tower out in a few days
Oil relief valve
I know it's not the spring because there is no way it shrank that much sitting out while I changed the head gasket
Oil relief valve
It was find before so I figured I did something to it. My spring measures on an inch and a half
Oil relief valve
I just changed my drivers side head gasket. I put it all back together and the valves are knocking really bad. I pulled the valve cover off and the cam is completely dry. I also noticed a decent amount of air coming out of the oil fill tube. I did a little research and saw it could be the o-ring between the came and the head or the oil relief valve. I loosened the oil relief valve and made sure it was at the right torque. I wanted to know what others might think it could be. Also what I should look for on the relief valve to see if its bad
Distributor/ignition timing
I am writing this to help others. I changed my head gaskets and had a hard time getting the timing right. The fsm says to set the flywheel to the 0 degree mark. Drivers cam pointing down and out while the passenger cam is up and out. That didnt work for me. I tried lining it up with the three lines and it still didnt work. What did work was setting the flywheel to the 20 degree mark then putting the distributor in pointing to the #1 cylinder post. What has everyone else done to get it to work?
speedometer lag?
I have an 87 gl wagon with an EA82 motor in it. i just got it running and driving. i noticed the speedometer lags behind. no matter the conditions its always the same slow lag. after i reach my speed it takes about 5 seconds for it to finally catch up. i cant find anything online about a slow speedo. does anyone on here have any ideas as to whats causing it/how to fix it?
EA82 spfi code 14
i got an 87 gl wagon with a spfi set up. im getting code 14 which is fuel injector abnormal output. when cranking it spurts 2 then stops for about 5 seconds then just 2 spurts. would this be a bad injector, wiring, or a bad ecu?
2001 subaru outback manual wont shift into 2nd or 4th or reverse
well im going to a junkyard to day to take one out and inspect to see if a washer is missing or i just had them in the wrong spot.
the one in the back has a whit eplastice piece coming out of the end of it.
so i bled the clutch and nothing happened. i was just looking around to see what could be blocking it. i saw that there was 2 sensors on the back off the tranny on the side. the one that's more towards the front has 2 red wires and the one on the back has 2 black wires. i loosened the back one and i was able to shift into 2nd and 4th and reverse. do i have them backwards or are is the back one suppose to be loose?
engine off it still doesnt move i will bleed the clutch right now and see if that works. broken fork as in the one for the gear selector on top of the tranny?
